The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 371 - AVS | Home Theater Discussions And Reviews
post #11101 of 11116 Old 05-01-2015, 04:36 PM
johnnymacIII's Avatar
Quoted: 93 Post(s)
Originally Posted by Comp625 View Post
x4000 owners, I'm hoping you can help me.
My 5-month old receiver's Front Right channel loses sound every so often. At first, I thought it was a blown speaker until I swapped in another one to no avail. Also, the test tone plays but it's very faint (you have to hold the speaker up to your ear to hear it). Wires look good, and I rewired to no avail.
However, I accidentally jarred the receiver and sound from the FR channel came back.
Shortly after, sound disappeared again but an aggressive knock against the right side of the receiver case (toward the back) brought back sound.
Is something loose and can an amateur fix it? Should I call Denon? FWIW, I bought it as a refurb from AC4L.
Sent from my XT1096 using Tapatalk
Definitely don't open it up. Call Denon and they will set you up with an authorized repair center. Hopefully the repair center is close enough to drop the unit off. If not, see if you can get them to pay for shipping. When I had to send my unit back to A4L from NC to FL it cost me $88 via UPS ground, but that was including box and packing as well.
johnnymacIII is offline
post #11102 of 11116 Old 05-01-2015, 08:35 PM
Quoted: 55 Post(s)
Liked: 1
Do you guys have any idea if open box denon x4000 from best buy still comes with 3 yr manufacturer warranty?
tapsilog is offline
post #11103 of 11116 Old 05-01-2015, 08:45 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 138
It should. Ask them to confirm. It's only when it has a "used" status that you lose the warranty.
Soulburner is offline
post #11104 of 11116 Old Yesterday, 05:45 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3767 Post(s)
Liked: 2186
Yes. Open box from an authorized dealer still has 3 year warranty.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #11105 of 11116 Old Yesterday, 09:42 AM
Quoted: 55 Post(s)
Liked: 1
Is best buy denon authorized dealer? I just took home open box x4000. How i am gonna get the 3 yr warranty? Should i call denon?
And also they dont have the rc 1185 remote for x4000 instead they gave me rc 1192. Is that remote will just work fine?
tapsilog is offline
post #11106 of 11116 Old Yesterday, 12:42 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2186
Yes, Best Buy an authorized dealer and is Denon's largest customer. Your Best Buy invoice with date of purchase is the only item needed for warranty service if required. The RC-1192 remote is used with the newer X2100W and X3100W AVRs and although some commands may work others will be missing as the X4000 is a higher level model. You would be better served purchasing a Harmony remote and downloading the RC-1185 commands to it from the Logitech website.
post #11107 of 11116 Old Yesterday, 12:57 PM
Quoted: 55 Post(s)
Liked: 1
In see. Thanks. Any harmony will work? Is this the recent firmware version for the x4000, 5530-8776-1610?
tapsilog is offline
post #11108 of 11116 Old Yesterday, 01:04 PM
mhaider's Avatar
That's the firmware version on my X4000, I was able to connect with the update server Thursday night and was told I had the latest version
Sent from my LG-V500 using Tapatalk
mhaider is offline
post #11109 of 11116 Old Yesterday, 01:27 PM
Quoted: 55 Post(s)
Liked: 1
tapsilog is offline
post #11110 of 11116 Old Yesterday, 01:56 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2186
Yes any Harmony. There are many models available depending on how many other components you also want to control in addition to the AVR.
post #11111 of 11116 Old Yesterday, 02:44 PM
Quoted: 55 Post(s)
Liked: 1
Thanks. I think i got a defect unit. When doing a test tone from avr 0.0db the surround left speaker doesn't make any sounds.all others are okay. Hmmm
tapsilog is offline
post #11112 of 11116 Old Yesterday, 02:54 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2186
Whenever you get a "used" unit, the first step is to reset the microprocessor to return all settings to their factory defaults. See post ##5 of this thread or look at p. 225 in the Owner's manual.
post #11113 of 11116 Old Yesterday, 04:16 PM
Quoted: 55 Post(s)
Liked: 1
Thanks again. Did the reset and all is working fine now. And you are right the remote they gave me are missing all major buttons i guess. Is it possible i can ask denon for replacement?is it cover with the warranty?
tapsilog is offline
post #11114 of 11116 Old Yesterday, 05:26 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2186
Not likely but doesn't hurt to try ... although some who have gotten open box units from Best Buy have simply negotiated an additional $50 off the sale price to acquire a new remote.
post #11115 of 11116 Old Yesterday, 11:17 PM
BLeClair12's Avatar
Quoted: 17 Post(s)
No idea what's going on here, but I'm in need of some assistance.
I've had my X2000 for a year now and have never had even a hint of an issue.
Tonight, I watched a movie on my PS3, put it back on TV for a while, then switched over to my Xbox One and played a game for a bit. When I switched back over to my cable input, my screen was black. And I can't get it back. I've reset the cable box, shut everything down and restarted. Nothing. All of my other inputs and devices work. I moved the cable box to a different input on the receiver, nothing. I get sound after I change the channel for the first time, but no video.
I plugged the box directly into a different TV and it worked perfectly fine.
Sounds like an HDMI handshake issue, but how? Why now after a full year?
BLeClair12 is offline
post #11116 of 11116 Unread Today, 03:05 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2186
HDMI handshake issues with cable/sat boxes can present out of the blue when there is a firmware update to cable/sat box. Go through the HDMI HDCP reset procedure I list in the Troubleshooting section of post ##3 of this thread linked below ....
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
