The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 380 - AVS Forum | Home Theater Discussions And Reviews
post #11371 of 11375 Old Yesterday, 04:47 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 4445 Post(s)
Liked: 2384
Forum sponsor Monoprice sells several different types of HDMI/Cat 5/6 converters.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #11372 of 11375 Old Yesterday, 04:55 PM
rbpeirce's Avatar
Originally Posted by rbpeirce View Post
Thanks. That's something I had not thought of! My Zone2 TV is a direct connection. I can run it to the Zone1 output. In fact I can connect both TVs to Zone1 and run a fan test on it. If I can make one turn off without turning off the other, the HDMI/CAT-5/HDMI device is probably the problem. The next question is what brand do I replace it with?
That was incredibly easy to set up and to test. One can never be absolutely certain but it sure looks like the problem is the HDMI/CAT-5/HDMI device. So, if anybody else is using these, what is a good one?
rbpeirce is offline
post #11373 of 11375 Old Yesterday, 05:05 PM
rbpeirce's Avatar
I use Monoprice almost exclusively for cables of all sort. However, if they sell several converter brands it would still be helpful to know which might be best.
Re: Monster power conditioners, I am working with a system that came with a house I bought. The only thing I added was the X4000 to free up a 987 to move to another system where an older Denon AVR had failed. The big advantage of the power conditioner is I can turn everything off with one button, although a power strip would do the same thing.
I have Panasonic plasma TVs, which are incredibly hot, Boston speakers, which aren't my favorites, and so on. As long as everything else continues to work, the HOT TVs are the major issue right now.
rbpeirce is offline
post #11374 of 11375 Old Yesterday, 11:52 PM
CBdicX's Avatar
Quoted: 468 Post(s)
Liked: 75
No, you can't switch it off but you can set the HDMI Audio Out to "TV" vice "AVR" although not likely to make any difference if not using the HDMI inputs.
Thank you for your reply.
I read on the Net that the 3313 has some heat problems, is this correct and will i need to address this by adding fans ?
Please keep in mind i only will use the 3313 to drive 2 subwoofers.....
PS, i will get a 3313S, i see in the US it a 3313CI, what is the differents between the 2 models ?
CBdicX is offline
post #11375 of 11375 Unread Today, 02:55 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2384
No clue ... never heard of a 3313S, rather the European counterpart to the 3313CI is the 3313 (no "S").
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
