The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 382 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
Old 07-19-2015, 07:19 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
Originally Posted by jnnt29 View Post
Uh-oh, my X4000 has the dreaded shut down with fast blinking red power light. It has happened twice in three weeks and all connections are clean. I have a feeling it is going to continue to increase in time. I'll have to see when it was purchased. I know it is still under warranty. JD which repair shop is close to NJ?
I have replaced all of the speaker wire to my surrounds and zone 2 speakers. I also did 6 Micro processor reset to make sure I cleared the old configuration and any Gremlins. Reran the setup and Audyssey with hopes of keeping the dreaded blinking red power indicator at bay. Keeping my fingers crossed. This is really a great AVR and sounds great!
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
Old 07-24-2015, 03:28 PM
poochpa's Avatar
Quoted: 45 Post(s)
Can any owner of an AVR-X4000 tell me, when playing music via net/usb, whether the track info displayed on a tv screen shows, in addition to elapsed time, the remaining or total track time? Thanks.
Mike
poochpa is offline
Old 07-24-2015, 05:56 PM
pbarach's Avatar
Quoted: 322 Post(s)
Liked: 194
Mike
no, it doesn't.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
Old 07-25-2015, 08:03 AM
poochpa's Avatar
Quoted: 45 Post(s)
Mike
Originally Posted by pbarach View Post
no, it doesn't.
Okay, thanks for letting me know.
Mike
poochpa is offline
Old 07-25-2015, 03:48 PM
hungryJonJon's Avatar
Just picked up my E300 today post warranty repair after I lost all video output. I'm having a weird purple tint issue on only certain devices.
Chromecast and Verizon cable box work perfectly fine. PS3 and Roku are working but with a purple tint. I tried swapping the devices between physical HDMI input connections but the purple tinting seems related to the input device and not the port. I also tried swapping cables between cable box and PS3 and Roku, also no change. I tried resetting settings on PS3 and Roku, no luck. Tried HDCP handshake reset and microprocessor reset, no luck.
Searched the forum but 'purple' is not relevant in this thread... how can it only be me? haha.
Any suggestions? As always, thank you guys in advance for all your help.
Attached photos. As you can see in the PS3 photo, my Optoma HD131xe projector is properly displaying it's set up menu though the PS3 is showing crazy purple.
ID:	850074   Click image for larger version
ID:	850082   Click image for larger version
hungryJonJon is offline
Old 07-25-2015, 04:11 PM
jdsmoothie's Avatar
Quoted: 12144 Post(s)
Liked: 5532
On the PS3 ensure the "Deep Color Output" setting is OFF. For the Ruku, it could be an HDMI handshake ... did you do the HDCP reset procedure with it as well?
jdsmoothie is offline
Old 07-25-2015, 04:43 PM
I tried deep color on and off, no luck. I just tried HDCP handshake reset again for PS3 and Roku individually, no luck. After I had no luck with the Roku I plugged in my MacBook Pro using the same cable and it worked fine. argh.
I'm not so worried about the Roku but the PS3 is my Blu-ray player. I'm going to borrow a friend's generic player to see if that works.
I didn't use my devices while the AVR was being repaired so this is really frustrating.
Old 07-25-2015, 04:47 PM
jdsmoothie's Avatar
Liked: 5532
If these sources worked without issue prior to the total video output quitting issue presenting, I'd take the AVR over to your friend's house and connect his sources to it. Sounds like it needs to go back for repair.
Old 07-25-2015, 07:26 PM
Thank again for your quick replies and help. How disappointing but I think I must bring it back too. I'm going to try my PS3 on a different TV tomorrow morning and if it works fine... well, not a good sign.
Old 07-27-2015, 09:14 AM
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
My X4000 keeps locking up. The behavior is different but the solution is the same. Sometimes it will just lock up. It will not accept IR commands and the power button on front does not work. Sometimes the volume bar will not leave the screen. The solution is to unplug the X4000. When I plug it back in it goes right back into the mode it was in. There does not seem to be anything specific that causes it.
I have tried doing a factory reset and reloaded my settings. After that didn't work I upgraded the FW. I hadn't updated because up until this started I didn't really have problems or reason to. My next step is to factory reset again and reload. I really don't want to set up the receiver again. Any ideas?
rec head is offline
Old 07-27-2015, 09:17 AM
Gracepreacher's Avatar
Quoted: 173 Post(s)
Liked: 25
Is there a way to back up the settings on these? I have an X1000 and want to be prepared for any troubles down the line...
Gracepreacher is offline
Old 07-27-2015, 09:19 AM
Quoted: 173 Post(s)
Liked: 25
Input buttons trigger power on?
I've recently noticed on my X1000 that when I select a connected input on the remote, the receiver comes on. Is there a way to remove this feature to avoid accidental (think small children) "turn ons"? I looked through the manual and see that this is normal behavior, but did not figure out a way to turn it off. Anyone know?
Old 07-27-2015, 09:23 AM
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
Yes. My settings are backed up. Check the first posts in this thread for instructions.
rec head is offline
Old 07-27-2015, 09:41 AM
Quoted: 173 Post(s)
Liked: 25
Will do! Thanks.
Old 07-27-2015, 10:51 AM
jdsmoothie's Avatar
Liked: 5532
Normal behavior which cannot be disabled. Suggest you get a cheapie $10 universal remote just for the kids as an option.
Old 07-27-2015, 12:54 PM
jdsmoothie's Avatar
Liked: 5532
Pandora has stopped working on the Denon and Marantz 2014 and 2015 models due to a change Pandora made yesterday. Can one of you 2013 model owners try to access Pandora and report back if possible or if you hang up at the log on display? Thanks.
Old 07-27-2015, 01:35 PM
cjett7's Avatar
Mine seems to be working properly.
cjett7 is offline
Old 07-27-2015, 01:55 PM
jdsmoothie's Avatar
Liked: 5532
Model?
Old 07-27-2015, 02:49 PM
cjett7's Avatar
Model?
Oh yeah, I guess that might help.
It's the X-4000 with the latest firmware, if that matters.
cjett7 is offline
Old 07-27-2015, 04:16 PM
jdsmoothie's Avatar
Liked: 5532
Yes, thanks, Just wanted to confirm you had a 2013 model, so then the issue apparently is only impacting 2014 and 2015 models.
Old 07-27-2015, 05:16 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
Mine is not working and it is a x4000. Glad to see it wasn't my unit per-se
My set up
jnnt29 is offline
Old 07-27-2015, 07:02 PM
jdsmoothie's Avatar
Liked: 5532
Hmm .. one works the other doesn't. Any other 2013 model owners that use Pandora that can confirm whether the on board Pandora feature is working or not?
Old 07-27-2015, 07:32 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
Mine goes to the log in page with my ID and Password displaying and when you select ok it says please wait and noting happens. I'm on the latest firmware.
My set up
jnnt29 is offline
Old 07-27-2015, 08:16 PM
MDSlacker's Avatar
Liked: 0
Hi - X-4000 owner on latest firmware, joined just to comment and give something back after all I've received here over past 12 months (thanks). My Pandora behaves just as stated above: I see login page, am asked for password, I hit Ok, get please wait... then nothing happens. System doesn't hang - the authentication just doesn't complete.
MDSlacker is offline
Old 07-27-2015, 08:22 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
There is a post on the Denon support page indicating that there is a known issue with Pandora.
http://denon.custhelp.com/app/home
My set up
jnnt29 is offline
Old 07-27-2015, 08:51 PM
cjett7's Avatar
Well I had to go and look again. Now mine is not working either. At around 1 or 2 this afternoon I had it on to show my visiting son it and my new Fire TV. It authenticated as normal and started playing. Tonight it wants me to enter my password and then hangs and nothing else.
No explanation why it worked earlier. I don't use it much anymore because I belong to Amazon Prime and use Prime Music most of the time.
cjett7 is offline
Old 07-27-2015, 10:48 PM
Gandu's Avatar
Quoted: 59 Post(s)
Liked: 82
X-2000, same for me.
Gandu is offline
Old 07-28-2015, 03:30 AM
jdsmoothie's Avatar
Liked: 5532
Okay, thanks folks. So the issue affects all 2013 and newer models then. No more replies required.
Old 07-29-2015, 05:51 AM
jdsmoothie's Avatar
Liked: 5532
Pandora should be back up and running again on all Denon and Marantz models.
No firmware update is required, rather simply logon and use as before ... apparently Pandora made changes on their end.
WERA689 likes this.
Old 07-29-2015, 02:28 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
I have confirmed that my Pandora is once again working. Thanks JDSmoothie for your update. JT
My set up
jnnt29 is offline
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
