The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 383 - AVS Forum | Home Theater Discussions And Reviews
post #11461 of 11481 Old 07-29-2015, 01:28 PM
jnnt29's Avatar
Quoted: 21 Post(s)
Liked: 60
Pandora should be back up and running again on all Denon and Marantz models.
No firmware update is required, rather simply logon and use as before ... apparently Pandora made changes on their end.
I have confirmed that my Pandora is once again working. Thanks JDSmoothie for your update. JT
My meager set up
Denon AVR-X4000, Emotiva XPA-3, Panasonic DMB-BDT360
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Panasonic 65VT60
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
post #11462 of 11481 Old 07-30-2015, 08:41 AM
ngordonmd's Avatar
Hey everyone. I was hoping someone might be able to help me with a problem I am having with my parents x4000. I have set up a 5.1 system for them and used the other 2 channels (rears) for zone 2 in their kitchen. My dad uses his iphone to play all his music, so I set the zone 2 input to network so that he can stream via his iphone. However, every time I start playing music, the main zone automatically turns on and sound plays through zone 2 and the main zone. Why is the main zone turning on automatically and is there a way to fix this? Thanks.
ngordonmd is offline
post #11463 of 11481 Old 07-30-2015, 08:47 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4806 Post(s)
Liked: 2507
This is just how it works. The main zone is "hijacked" until Airplay is playing in Zone 2 and then the original source can be reselected in the main zone.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective? Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #11464 of 11481 Old 07-31-2015, 05:56 PM
Daanger411's Avatar
Attempting to hook up an LP120 record player, which has a built in amp (line-in) mode as well as phono mode to my Denon X1000 and I'm getting nothing when using either of the aux (cbl/sat or Media Player) assignable sources. I thought by buying a record player with this capability I would be stepping around the lack of phono-in on the AVR. Is this not the case? Has anyone else had any luck getting a powered record player to work w/ their X1000?
Daanger411 is offline
post #11465 of 11481 Old 08-01-2015, 01:25 AM
traianescu's Avatar
Quoted: 20 Post(s)
please, anybody here with x4000, post the config.dat (the backup) of this avr.. as i received back from the service the receiver and i am missing the mic for the calibration, i can't use for a while dynamic eq and the subwoofer till i will have back the microphone..
please, just post the backup config of x4000, doesn't matter if it will sound bad as the calibration will not be in my room
Yamaha Aventage RX-A3040 - KEF R500 / T301 - SVS PB12-PLUS
traianescu is offline
post #11466 of 11481 Old 08-01-2015, 01:33 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2507
As long as the record player has a built-in pre-amp which is working correctly, you should be able to connect to any of the analog inputs on the AVR. Try connecting the LP120 to another component to confirm it is working correctly.
post #11467 of 11481 Old 08-01-2015, 01:35 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2507
A backup file is mostly gibberish so won't be of any use to you. Unless you run Audyssey, you will be unable to use Dynamic EQ.
post #11468 of 11481 Old 08-01-2015, 01:55 AM
traianescu's Avatar
Quoted: 20 Post(s)
right now, i can't run audyssey without the mic.. that's why i'm asking for a config.dat of x4000
post #11469 of 11481 Old 08-01-2015, 01:58 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2507
Understood, although again, unsure as to why as it will serve you no purpose. You can purchase a replacement mic directly from Denon or for about $25 on eBay.
post #11470 of 11481 Old 08-01-2015, 02:29 AM
traianescu's Avatar
Quoted: 20 Post(s)
of course, i will receive mine mic
but in one week for now.. i just need to use dynamic eq and subwoofer channel for a week, as dialogs without calibration are bad.. now i have to turn very loud the volume to hear the dialogs
do you have any 2.1/5.1/7.1 backup of x4000, please ?
post #11471 of 11481 Old 08-01-2015, 02:54 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2507
Ah .. you want the actual hard copy file. No don't have one. However, if you are having dialog problems, you'll want Dynamic EQ OFF anyway and simply increase the volume of the center speaker a few db.
post #11472 of 11481 Old 08-01-2015, 03:09 AM
traianescu's Avatar
Quoted: 20 Post(s)
no center speaker actually to x4000 are connected 2 front speaker and the subwoofer.. so the only way to turn on the dynamic eq/volume is to have an audyssey config..
nobody have a backup of config.dat for x4000 ?
post #11473 of 11481 Old 08-01-2015, 05:50 AM
Vidgamer's Avatar
Quoted: 56 Post(s)
Zone 2 HDMI
Is "Zone 2 HDMI" just a split copy of the main HDMI signal or is there something special about it? I wanted just a straight split -- thinking about doing a project....
Vidgamer is offline
post #11474 of 11481 Old 08-01-2015, 06:15 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2507
Zone 2 HDMI is exactly what the name implies ..... it can pass a totally independent HDMI signal than what is playing in the main zone, or it can pass the same signal as is playing in the main zone.
post #11475 of 11481 Old 08-01-2015, 07:55 AM
rec head's Avatar
Quoted: 21 Post(s)
Liked: 43
The best thing I did was get a Bluetooth receiver. It is SOOOO much easier than using the Network input. I'm linking the one I have that works great. It easily covers both floors of my house. I use Android, my wife Apple and we both prefer this method to any other for streaming. Sure you won't want this for critical listening but for everything else it is awesome.
http://www.amazon.com/Miccus-Home-RT...tooth+receiver
rec head is offline
post #11476 of 11481 Old Yesterday, 03:12 AM
traianescu's Avatar
Quoted: 20 Post(s)
nobody can help me with the backup file (config.dat) from denon x4000?
post #11477 of 11481 Old Yesterday, 06:35 AM
Quoted: 85 Post(s)
Hello. Is the internal pink noise in the channel level settings mutable on the X500? Like, if I wanted to level each channel while playing a test track in the BD player?
Optimus_Fine is offline
post #11478 of 11481 Old Yesterday, 08:15 AM
mhenrickson's Avatar
I just purchased the x3100w and have a question. The unit allows me to change input names. I replaced the default "CBL/SAT" input label with "DIRECTV". However, when it shows up on the display it only shows as "DIREC". Is there any way to change this so the entire label is shown on the front display? It seems silly to allow inputs of several characters only to display five.
mhenrickson is offline
post #11479 of 11481 Old Yesterday, 09:00 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2507
Unlike the X4100W and higher models with dual line displays that can display the full maximum 12 characters of the source name, the X3100W only has a single display line so must fit in the same information on just one line. However, if CBL/SAT (7 char) fits, then DIRECTV (7 char) should also fit. Also note that when you press the INFO button on the remote, the full maximum 12 character name should display on the TV.
Also note, this is the 2013 Denon AVR thread .... please post more questions on the X3100W in the 2014 Denon AVR thread linked below ....
The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ
post #11480 of 11481 Old Yesterday, 09:31 AM
Directv does display in full when I switch inputs. But only shows Direc when actually using that input source. I also noticed that it displays "CBL/SAT" when switching, but only "CBL" when using that input. Weird.
post #11481 of 11481 Old Today, 08:24 AM - Thread Starter
batpig's Avatar
Quoted: 1982 Post(s)
Liked: 2121
No that won't work because the internal tones mute/override any external audio.
What you could do instead is use the browser interface from a laptop or tablet and tweak levels that way while using the external tones.
batpig is online now
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
