The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 397 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
Old 12-09-2015, 08:16 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Originally Posted by ambesolman View Post
Thanks jd, that was actually my first stop. I try not to clutter this thread with things you've already covered. The FAQ is too good not to refer to since it pretty much covers everything.
Short of trying the firmware update, I'm out of ideas.
Would there be any reason to send for repair since the other networking features work and I'm having no hdmi problems?
Sent using Tapatalk since the mobile version is still
1. Okay, just checking as many folks often overlook the information in post 3.
2. Regarding repair, I wouldn't no, rather more likely an iOS issue of some kind. Try doing a "network reset" as noted in post 5 if not already tried.
ambesolman likes this.
jdsmoothie is online now
Old 12-09-2015, 09:20 AM
ablevy's Avatar
On my list of things to do. My thought is since the original remote works correctly, is to train the remote again to match what the Denon remote is sending.
ablevy is offline
Old 12-09-2015, 10:33 AM
Liked: 0
Hi there. I have an X2000 in quite a large living room with B&W 685 speakers in a 5.1 setup and find that it just doesn't fill the room with sound and I have to turn it up quite far (-10db) to get a decent output but it does sound a little stressed at times.
I was thinking of trading it in for the X3000 or X3100w which I can get on a decent deal... what are your thoughts on this, would it make much difference? The power supply on the x2000 is 500w and it is 600w on the 3000 which I thought should help things.
The first page says that the 3000 is a bigger chassis but the specs suggest that it is the same depth? I can only just fit the existing receiver in my av rack.
Thanks guys
lotusmad2001 is offline
Old 12-09-2015, 10:51 AM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 895
Thanks guys
Won't make a difference. You normally only use a handful of watts most of the time anyway. You only get +3db if you double the power.
ambesolman is offline
Old 12-09-2015, 01:43 PM
jdsmoothie's Avatar
Liked: 5508
Thanks guys
Trading up to a higher model won't make any difference using the higher model's on board amps. If you want more volume, you need to trade up to a model that has at least FL/FR pre-outs so you can connect a much more powerful amp (eg. Emotiva XPA-2, 300W). The X4000 is the lowest 2013 model with main zone 7.2 pre-outs and the X3100W is the lowest 2014 model with 7.2 main zone pre-outs.
https://emotiva.com/products/amplifiers/xpa-2
Old 12-09-2015, 02:07 PM
Liked: 0
Thanks so much for your replies. I had a suggestion on another forum saying it could be the receiver. What else could it be? At -40 i can barely hear it at all. I use star wars episode 1 pod race scene as a reference and cant get it to sound all that :/ as in my all in one system in the bedroom blows me away and it is quite basic?
Jonny
Old 12-09-2015, 02:27 PM
ambesolman's Avatar
Liked: 895
Originally Posted by Ntennon View Post
Ok lets try some troubleshooting.
A. Since you said that all network connections failed, can you see the Denon alive with the static ip you have set using one of the tools I mentioned in step 2 as well as your iphone/ipad?
B. To see the Airplay function in IOS 8, Turn ON the Denon, go to Music on the iphone, play a song, and Slide up on your iphone to access the Control Center. At the control center normally you should see the Air Drop and the Airplay options together with Bluetooth, the flashlight, airplane mode etc
Air drop is the only option
Still no dice
Old 12-09-2015, 02:45 PM
Quoted: 627 Post(s)
Liked: 313
Jonny
Enable dynamic equalizer. That should blow things up a notch.
donktard is offline
Old 12-09-2015, 03:13 PM
Liked: 1
Still no dice
Are you able to access internet radio with the Denon?
Ntennon is offline
Old 12-09-2015, 03:22 PM
Liked: 0
Jonny
Already enabled that :/
Old 12-09-2015, 03:49 PM
Quoted: 627 Post(s)
Liked: 313
How big is the room though?
About what you mentioned, at -40 its awful quiet, yeah its same way with my X5200. I usually listen from anywhere from -20 to 0. -25-20 being moderate. -10 if material is unusually quiet and 0 when I am going loco.
Though if you hear clipping you should restrain yourself.
donktard is offline
Old 12-09-2015, 04:03 PM
ambesolman's Avatar
Liked: 895
Yeah, pandora, etc.? All that stuff works fine. I'm about to the point where I'm just going to hook up my old airport express and be done with it
Old 12-09-2015, 09:08 PM
marius's Avatar
Quoted: 28 Post(s)
x4000 owner here. Is there a way I can have one HDMI port output native resolution and have the other output upscaled 4k resolution? Tried to get this going for a couple of hours with no avail.
thanks
Simon
marius is offline
marius's Avatar
Quoted: 28 Post(s)
thanks
Simon
marius is offline
Old 12-10-2015, 03:04 AM
Liked: 0
Its about 5 metres deep by 6 but has an open bit that leads to the kitchen. Is clipping quite obvious? When i whack the volume up it just sounds really harsh in certain bits of the film like im pushing things too far, i was told that you should base your actual wattage of your power supply and divide it by your channels hence why i thought it would help to go up a model.
Old 12-10-2015, 03:17 AM
jdsmoothie's Avatar
Liked: 5508
thanks
When using different sources, yes, you can pass the upscaled source from the Monitor 1 output and the native source via the Zone 2 output, otherwise, when passing the same source, no.
Old 12-10-2015, 08:00 AM
ambesolman's Avatar
Liked: 895
Anything else y'all could suggest before I add the airport express back in as a work around?
Old 12-10-2015, 08:05 AM
Squirrel!'s Avatar
Quoted: 511 Post(s)
Liked: 275
Dude, -40 is nothing. That is the level I have mine to turn on to when powering up. On average -20 to -25 is normal listening level around here.
Main: Mitsubishi 73736 DLP|OTA|fireTV|Sony BDP-S1100|Denon AVR-4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|2 - DIY Class G 540w 12" Subs|2 Aura Bass Shakers|APC H15|Harmony 720|TP-Link Archer C7|Linksys SE2500|50+ OTA Channels
MBR: Vizio VF550M|OTA|fireTVstick 2|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|Dayton Audio SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Belkin Bridge|Harmony 550
Squirrel! is offline
Old 12-10-2015, 09:24 AM
marius's Avatar
Quoted: 28 Post(s)
darn ok this explains it. Yeah I was trying to use the same source. Thanks.
Simon
marius is offline
Old 12-10-2015, 09:25 AM
Liked: 1
Can you see the Denon being connected on the network under the static ip you have setup using the Fing app from your iphone/ipad?
Ntennon is offline
Old 12-10-2015, 11:08 AM
ambesolman's Avatar
Liked: 895
Yes
Old 12-10-2015, 03:08 PM
Liked: 1
Yes
The only other thing I can tell you to try is to leave and then rejoin your wifi network from your iphone by going to wifi setup on your iphone, select your connection, select forget this network. Turn off the iphone turn off the router, turn off the Denon. Then Turn on the router, then find your network from your iphone and rejoin and finally turn on the Denon in that order.
Ntennon is offline
Old 12-10-2015, 03:45 PM
ambesolman's Avatar
Liked: 895
I'll give it a try, thanks!
Old 12-11-2015, 10:24 AM
pec82's Avatar
[QUOTE=ambesolman;39627370]Anything else y'all could suggest before I add the airport express back in as a work around?
Did you try DHCP reservation?
pec82 is offline
Old 12-11-2015, 11:09 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
It all depends on the speakers and room. -40 is my TV watching volume and it isn't quiet. -30 is my movie watching volume. We don't turn up movies more than that because it's simply too loud.
And everything is calibrated with XT32.
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
Soulburner is offline
Old 12-11-2015, 11:33 AM
ambesolman's Avatar
Liked: 895
[quote=pec82;39659730]
Forgot about that. I'll try digging into the router settings this weekend. Thanks!
Old 12-12-2015, 07:18 AM
Liked: 0
the only other thought I had was, my speakers have a minimum impedance of 3.7 (they are rated at 8ohms) but I cant seem to find out if the x2000 goes that low in which case they are not being driven properly?
Or am I just going mental with all the stuff I'm reading on forums Auddysey sets my center up at +2 which I increased to +3, should any of the levels go that high? I alkways thought that anything over 0 is bad.
Jonny
Old 12-12-2015, 07:45 AM
jdsmoothie's Avatar
Liked: 5508
Jonny
Denon AVRs (to include the X2000) are rated for 6-16 ohm speakers, but should be able to handle lower impedance at moderate listening levels. A speaker setting of +2 means your speaker is not very efficient, although isn't necessarily a bad setting because it is over 0. A master volume setting of -10db is a personal choice, and as noted previously, if doing so doesn't produce any distortion, shouldn't be a problem for the AVR. General rule of thumb is you don't want to raise the volume above 0db/80 to ensure there is still enough headroom available.
Old 12-12-2015, 08:12 AM
Liked: 0
would I notice a big difference jumping to a X4000 or 3000 in terms of headroom or is it just a load of nonsense? I was under the impression that AVR's with larger power supplies cope a lot better when all channels are driven?
Old 12-12-2015, 08:30 AM
jdsmoothie's Avatar
Liked: 5508
Your question has already been asked and answered. If you want more power, either purchase a more powerful external amp (eg. Emotiva XPA-2) or more efficient speakers.
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
