The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 404 - AVS Forum | Home Theater Discussions And Reviews
 311Likes
post #12091 of 12101 Old 01-30-2016, 10:50 PM
Legit's Avatar
Liked: 1
Originally Posted by Legit View Post
It starting shutting off when I hit 60ish on the volume.
I decided to tear into this thing to check and see if I could see anything visual. I tore it all down! hahaha
The only thing I saw was a fuse by main power wires coming in that was not snugged all the way in. (it was in, but went in deeper)
The damn thing works now! This can't be for real?
So last night I wired some 100w 6ohm resistors on the two front channels and left it cranked on 85 for 4 hours and been using it all day with no hiccups!
Still in disbelief this thing is back 100%.
Vidgamer likes this.
7 cycle gas dryer and a 12 speed blender
Legit is online now
post #12092 of 12101 Old 02-01-2016, 02:00 PM
Lyons07's Avatar
Quoted: 88 Post(s)
Liked: 26
Help with Android MX64 and X4000
Hi,
I just got this new Android TV Box MX64, it's replacing my MXIII. I used the same setup Samsung TV Connect One box to my Denon. Everything was working great, but this new MX64, starts to work then it goes from HDMI to analog. I've tried different HDMI's cables and different inputs on my Denon, but it keeps switching from HDMI to analog. Can someone explain how to fix this, if there is a fix? I'm lost!!
Thanks, Jerry
UN60HU8550 HS01 SEK-3500 Denon X4000
Lyons07 is online now
post #12093 of 12101 Old 02-02-2016, 06:50 AM
JayMan007's Avatar
If this occurs regardless of the HDMI source selected, try doing a "soft reset" by powering off the AVR and unplugging the power cord for 10 minutes. If no joy, review post 5 of this thread and do a microprocessor reset a few times in a row. If yet still no joy, time to call Denon for warranty repair.
I had done the "soft reset" (prior to posting) and first time out of that, it had the same issue.
Whats odd is that it hasn't happened since. Yeah!
Thanks All.
JayMan
JayMan007 is offline
post #12094 of 12101 Old 02-02-2016, 07:28 PM
Legit's Avatar
Liked: 1
Weird one
I just noticed that when I shut my x4000 off and then turn it back on, the audio is gone from cable box. The only thing that fixes it, is turning the cable box off and back on? I have the HDMI and CEC stuff turned off. Any idea?
Legit is online now
post #12095 of 12101 Old 02-03-2016, 02:38 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 7377 Post(s)
Liked: 3397
This occurs because you have interrupted the HDMI handshake, requiring the signal chain to be reinstated by powering cycling the cable box.
Legit likes this.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
Authorized dealer: Denon, Marantz, Yamaha, Onkyo, Sony, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
post #12096 of 12101 Old 02-04-2016, 02:34 PM
carlbarry's Avatar
I finally got a "big" screen TV, Samsung UN46F7500.
Here's my problem: I have my AVR-X4000 plugged into the ARC input on the TV. When I turn on my Sony Blu ray, the TV turns on. I use the Sony to listen to SACDs, and don't need or want the TV on. If I turn off the TV, the Blu ray turns off.
Is there a setting to eliminate this? Or should I just not use the ARC input?
carlbarry is offline
post #12097 of 12101 Old 02-04-2016, 02:40 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3397
Turn HDMI CEC (BraviaSync) on the Sony Blu Ray to OFF.
carlbarry likes this.
post #12098 of 12101 Old 02-04-2016, 03:59 PM
carlbarry's Avatar
Thank you! I knew you'd know the answer!
post #12099 of 12101 Old Today, 07:47 AM
de8212's Avatar
Quoted: 163 Post(s)
Originally Posted by de8212 View Post
Does anyone have a specific recommendation for a pre amp so I can connect an old record player to my x3000? I'm looking inexpensive as possible as I would probably rarely use it. But I certainly don't want a piece of junk.
Still curious about this. If anyone has one that they use and can recommend it.
And just so I am 100% clear, I would plug the turntable RCA's into the inputs of a pre amp and then from the outputs of the pre amp into the RCA inputs of the x3000? For example, on the back where it says "5 CD"?
de8212 is offline
post #12100 of 12101 Old Today, 07:51 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3397
Correct.
There are several inexpensive pre-amps listed on Amazon that get good reviews to include the one below ...
http://www.amazon.com/Pyle-PP999-Pho...rntable+preamp
post #12101 of 12101 Old Today, 08:07 AM
de8212's Avatar
Quoted: 163 Post(s)
Correct.
thanks. Yeah, I saw them and read alot of reviews over the weekend. I was just hoping someone here had personally used one with one of the denon receivers but I'll just go ahead and grab one.
de8212 is offline
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
