The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 417 - AVS Forum | Home Theater Discussions And Reviews
 359Likes
post #12481 of 12490 Old 09-20-2016, 06:51 AM
Zacrobmer's Avatar
Originally Posted by Zacrobmer View Post
Loose jacks is my concern. I just did a settings back up and am going to do a hard reset and reconnect everything again.
Thanks for the assistance.
So as a last update on the X2000....
The last reset/rewire lasted about 2 months before everything came back, static intermittent speaker loss etc. I finally made the time to put it back in it's box and send it to Panurgy for repair/service.
Panurgy received the X2000 last Monday (Sept 12th) and last Friday (Sept 16th) I received notice of a missed FedEx package. Picked it up yesterday (Monday) and they apparently figured the X2000 was not worth fixing, and sent me a re-furbed X-2200w.
I hooked it up and it works fine, but I will not be able to run Audyssey until Saturday or so. So far seems like decent upgrade, and seems to "sound better" which even my wife commented on; which makes me wonder if there were bigger internal issues with my X-2000.
Zacrobmer is offline
post #12482 of 12490 Old 09-20-2016, 07:33 AM
jj-34's Avatar
Originally Posted by jj-34 View Post
Some news about my video connection losses with my PJ :
I have installed a powered hdmi switch between the Monitor2 hdmi output of the Denon X4000 and the long cable to the PJ, switched the amp's video out back to Auto ..... and it works
Well it's not very reliable and only works sometimes.
Now before sending the unit back, Denon told me to save my config settings and do a full reset.
Only problem is that I cannot perform the save function, when I use the web control function and then the save menu, after depressing the "save config" button nothing happens at all.
I already had to set my IE10 to compatibility mode to get the save option, anything else I need to do ?
I have no playback of Internet nor iPod/usb going on.
jj-34 is online now
post #12483 of 12490 Old 09-20-2016, 07:37 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 10229 Post(s)
Liked: 4742
Suggest using Chrome instead as I've never gotten IE to work.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Authorized dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, SVS, Oppo
Ask me how to get a FREE HEOS 1 HS2 wireless speaker.
jdsmoothie is online now
post #12484 of 12490 Old 09-20-2016, 08:13 AM
jj-34's Avatar
Tried Chrome, but this time when I press the Save Config button I get this error msg : unable to find the DNS address of the goform server
What is this goform server and why does it need it ?
jj-34 is online now
post #12485 of 12490 Old 09-20-2016, 09:31 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4742
Don't know. Not familiar with that message.
post #12486 of 12490 Old Today, 01:24 AM
jj-34's Avatar
What browser do you use ?
jj-34 is online now
post #12487 of 12490 Old Today, 01:33 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4742
Chrome ... which is why I suggested it.
post #12488 of 12490 Old Today, 01:53 AM
jj-34's Avatar
Waouhhh Are you up all night or just a very early bird ?
I also tried Firefox and don't even get the Save/Load button ....
Must be something wrong in my W10
By the way having tried many many times the save procedure in IE11 I once got it to work, then after a long time ( was it 15 minutes ? did not time it ) I got a 952 KB config.dat file but that seems to be completely blank ... ?
And now whenever by cheer luck I get it to work again it immediately keeps asking me if I want to download the very same file ... That X4000 starts to be getting on my nerves
jj-34 is online now
post #12489 of 12490 Old Today, 02:09 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4742
Early riser.
The SAVE procedure will take about 12 minutes or so and it is very possible it will be an "all zeroes" file which is why it's important to check the validity of the file using a HEX editor. Simply try again until a valid file is saved.
post #12490 of 12490 Old Today, 02:21 PM
Dan in St. Louis's Avatar
Quoted: 100 Post(s)
Liked: 34
Beware of UPPER/lower case issues. Enter the commands exactly as listed in the attached instructions.
---- Dan in Saint Louis
Dan in St. Louis is online now
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
