The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 423 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
post #12661 of 12678 Old 01-09-2017, 03:57 PM
vlad335's Avatar
Quoted: 59 Post(s)
Here is a problem I am having and wondered if anyone could help. (Pasted in quotes) I have a Samsung KS8000 and Denon X4000. Problem is with Oppo UBD-203 HDMI audio out into the Denon x4000.
Received my Oppo UBD-203 player and I am kinda underwhelmed with the way 4k/HDR looks. I have the Oppo video out in HDMI 3 with a brand new certified 18ghz cable and the audio HDMI out from the Oppo going to my Denon x4000 receiver. (older receiver that doesn't pass HDR)
When I have the HDMI UHD COLOR setting turned on for HDMI 3 and select the Oppo on my Harmony remote, my amps triggered by the Denon immediately shut off. (I have 3 power amps connected to the Denon.) I can pull the trigger cable out of the Denon and get the amps back on but this is a PIA. The only sound I am getting is from my front heights which are connected to the receivers amplifier and not to an external amp. When the Amps go off, M2 on the display goes out. Looked this up and this is monitor 2, the HDMI output. I had Monitor 1 connected but thought maybe ARC was contributing to the problem. ( No difference)
If I set UHD Color to ON with my running Comcast cable box on HDMI 1, the amps shut down for a second then come right back on. This has video passed through the Denon though
Why cant I get this setting to work with my Oppo UHD player where it really matters? It is obviously passing audio signal but for some reason something is telling the Denon to shut down the triggered amps?
Is there no way to just get HDMI audio and not feed a video signal as well?
vlad335 is offline
post #12662 of 12678 Old 01-13-2017, 04:42 PM
budda109's Avatar
Quoted: 35 Post(s)
ARC question. I can't figure out how to get sound from the ARC connection? I hooked up one end to the UBD-8500 player on the ARC port , one on the X4000 ARC port. What should I see on the display of the X4000? When it's playing thru the ARC cable? HDMI control setting is on my TV, my AVR and my disc player. Main HDMI goes from player to TV. Audio only/ARC goes from player to AVR. I tried to use a HDCP 2.2 to 1.4 converter but that had a picture short fall. So it's back to tiring to get the ARC cable to work. Thanks
budda109 is offline
post #12663 of 12678 Old 01-14-2017, 02:08 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5499
There is no HDMI(ARC) jack on the UBD-8500, rather HDMI(ARC) refers to passing the audio from the TV's smart apps (eg. Netflix, Hulu, Vudu, YouTube, etc.) back to the AVR over the same HDMI cable that connects the AVR (using HDMI(ARC) jack on the AVR) to the TV's HDMI(ARC) jack. So for your use case, HDMI(ARC) doesn't even apply as you're passing the audio from the UBD-8500 to the AVR so if the HDMI cable is connected from the UBD-8500 to the BDP input on the AVR, it should work.
budda109 likes this.
jdsmoothie is offline
post #12664 of 12678 Old 01-14-2017, 02:15 AM
jdsmoothie's Avatar
Liked: 5499
What trigger setting on the AVR are you using? Does the same issue present if you don't use the Harmony, but rather simply use the individual remotes? Perhaps you need to program in a longer pause between powering on the TV and the AVR.
post #12665 of 12678 Old 01-14-2017, 08:05 AM
vlad335's Avatar
Quoted: 59 Post(s)
Thanks for the reply. Not sure what you mean by the trigger setting. The only setting I can find is ON/OFF for each input. Obviously they are all set to on.
Same thing happens if I use the Device remote or even physically turn on the unit. Also, if all the devices are on, ready to watch a bluray and I change the UHD Color setting on the Samsung, BAM! The amps turn off.
Maybe you have to output video on this receiver to get triggered amps to work?
I wanted to find someone local who had a different UHD player and posted a request in the bluray players forum but the post was merged into the Oppo thread. Doubt many saw it. Think I may just go buy a Samsung UHD player and see if it does the same thing.
Oppo pretty much stopped responding to my emails so the only thing I can try is another player.
vlad335 is offline
post #12666 of 12678 Old 01-17-2017, 02:32 PM
ArthurL's Avatar
My apologies in advance for posing these questions.
The "amp assignment" mode on my x4000 is currently set to "9.1 (SB/FH/FW)". In this mode, I only get 2.0 sound when using my turntable.
  1. What "amp assign" mode will allow me to use the sub (2.1) when using my turntable?
  2. Will changing the "amp assignment" mode require me to re-calibrate my system?
Many thanks in advance!
ArthurL is offline
post #12667 of 12678 Old 01-18-2017, 03:39 AM
jdsmoothie's Avatar
Liked: 5499
1. Has nothing to do with the AMP ASSIGN, rather if you are using the STEREO surround mode, simply ensure your FL/FR speakers are set to SMALL/80Hz in the Manual Setup.
2. Yup, although as noted in 1 above, not required.
ArthurL likes this.
post #12668 of 12678 Old 01-18-2017, 07:26 PM
kaiforce's Avatar
Quoted: 106 Post(s)
Liked: 127
My x4000 gives me this error when I run audyssey, happens right after it does the SW bump bump bump bump. The initial subwoofer check is loud, but the bump bump is considerably quieter. Do you think caused by the sub being too quiet or something else? I am missing a center channel and a surround left, so perhaps it doesn't like that. Was hoping I could do L R and a single surround, it was supported on my old Pioneer, hoping its still possible. If not that's alright and i'll re-run audyssey when I get everything setup next year. Thanks!
kaiforce is offline
post #12669 of 12678 Old 01-19-2017, 04:11 AM
jdsmoothie's Avatar
Liked: 5499
Although you can do a single "Rear" surround (ie. 5.1 with no center), you can't do a single surround (ie. 3.1 with no center). Disconnect the single surround and run Audyssey again.
kaiforce likes this.
post #12670 of 12678 Old 01-20-2017, 06:41 AM
johnnymacIII's Avatar
Quoted: 160 Post(s)
Liked: 51
I've got the x4000. Does anyone else get a soft popping sound come through all of their speakers when powering down? I also get a soft pop through my sub, with every click of volume up or down on my remote. I've already checked and rechecked all of my speaker connections and done a hard factory reset, but that did not fix anything.
johnnymacIII is offline
post #12671 of 12678 Old 01-20-2017, 03:14 PM
pbarach's Avatar
Quoted: 318 Post(s)
Liked: 193
I get a soft popping sound when I turn off the system. I am using an external amp for the front L&R , so I power that amp down before turning off the x4000 or else I get a VERY loud pop from those speakers.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #12672 of 12678 Old 01-20-2017, 05:39 PM
ArthurL's Avatar
Thanks jdsmoothie, I finally got some time to try this and it worked!
ArthurL is offline
post #12673 of 12678 Old 01-21-2017, 03:43 AM
jdsmoothie's Avatar
Liked: 5499
Excellent!
Thanks for reporting back.
post #12674 of 12678 Old 01-24-2017, 12:13 PM
JMak00's Avatar
Quoted: 100 Post(s)
Ooops, wrong thread... Apologies
JMak00 is offline
post #12675 of 12678 Old 01-24-2017, 01:50 PM
jdsmoothie's Avatar
Liked: 5499
You can delete your post by selecting the "Edit" button and then the "Delete message" radio button.
post #12676 of 12678 Old 01-24-2017, 09:43 PM
t231's Avatar
Quoted: 27 Post(s)
Hi everyone,
Itunes stopped seeing my denon in airplay some months ago and I've not been able to resolve it... Nothing changed on my setup other than I received the new denon firmware (fixing pandora), and regular itunes updates -same router/ windows laptop etc.
I've already tried adding/removing the denon from my network, uninstalling/reinstalling itunes, power cycling computers/routers/receiver multiple times, and changing the friendly name of the denon.
What's most frustrating is my laptop can "cast" to the denon using windows media player just fine, however navigating over 6k songs in windows media player is frustrating.
Any tips?
t231 is offline
post #12677 of 12678 Old 01-25-2017, 03:29 AM
jdsmoothie's Avatar
Liked: 5499
Originally Posted by t231 View Post
Hi everyone,
Any tips?
Have you reviewed post 3 item 11(a)? Otherwise try resetting the microprocessor as described in post 5 of this thread.
post #12678 of 12678 Old 01-26-2017, 05:22 PM
sonixmon's Avatar
Hi everyone,
Any tips?
I had problems getting the denon app to work since the firmware and remembered reading another post saying setting the units IP to static helped in the past. Even though I had my Denons IP reservered in the router I went ahead and set it static to the same address. Since then the App and Crestron connected started working again. Give that a shot!
sonixmon is offline
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
