The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 425 - AVS Forum | Home Theater Discussions And Reviews
 403Likes
post #12721 of 12743 Old 04-14-2017, 03:51 AM
jdsmoothie's Avatar
Quoted: 13396 Post(s)
Liked: 6219
Originally Posted by NoFateDenon View Post
ah, gonna have a look later today
can you do that for every sound mode like PL2 Cinema?
or is more like a general setting
because if i listen to internet radio, the mode is set to stereo, with this mode, all the speakers volumes are the same, like i want...
thnx
Yes, although with the release of the 2014 and newer models, there is now an Option - Channel Level Adjust setting that allows you to adjust the volume of each speaker/sub independently for each source.
jdsmoothie is offline
post #12722 of 12743 Old 05-02-2017, 05:15 PM
Liked: 3
I just added some new gear and quickly set up my equipment in my new house (equipment list below) and am having some sound issues.
JVC X5000
Oppo ubd203 (HDMI OUT to projector, HDMI AUDIO OUT to Denon X4000's "Bluray" Input)
Denon X4000
Issue is, when there is no sound coming from the oppo the receiver seems to kinda disconnect the signal and the display no longer shows the speakers etc.
But then when a sound is played, it takes a second or two and kicks back in to gear, showing the speakers on the display and input signal (dolby digital) again.
quite annoying when flicking through menus and ya dont hear the little beep till about the 3rd or 4th click. then when you stop it turns off again.
may be a simple setting in the denon but i cant find it :/
Any help muchly appreciated
*Edit...
Not sure if it makes any difference, but i also have an nvidia shield connected to the oppo's hdmi in.
STAIN0 is online now
post #12723 of 12743 Old 05-02-2017, 08:05 PM
jdsmoothie's Avatar
Liked: 6219
JVC X5000
Denon X4000
*Edit...
Try using each of the other HDMI inputs on the X4000 to see if one works better than the current one.
STAIN0 likes this.
post #12724 of 12743 Old 05-02-2017, 10:41 PM
Liked: 3
yer will give that a go tonight.
have read a bit about handshaking issues and powering on order. Had never heard powering on in the wrong order can cause issues.
post #12725 of 12743 Old 05-03-2017, 09:48 AM
NickTheGreat's Avatar
Quoted: 396 Post(s)
Liked: 270
I have one or two of my HDMI's that just don't work. Or not well. And going to another one fixed the issue.
Kinda angers me that I paid that much for something that I have to find "workarounds" for, but I really only need 3 or 4 inputs. And I got a good deal on it :
NickTheGreat is offline
post #12726 of 12743 Old 05-04-2017, 02:12 PM
bill288's Avatar
JVC X5000
Denon X4000
*Edit...
I had the same problem. 2 solutions. 1st in oppo video output set to custom (UHD 24 HZ). or 2nd take the output from oppo directly to another HDMI input on tv and take the audio oppo output to where you had the oppo connect on avr, and it also solves problem with SACD play back. you do not have change the oppo video output this way. both worked for me. its the 1.4 hdmi on denon with the problem.
STAIN0 likes this.
bill288 is offline
post #12727 of 12743 Old Yesterday, 12:46 PM
Marc Alexander's Avatar
Quoted: 1699 Post(s)
Liked: 1377
Originally Posted by javanpohl View Post
So I've had my Denon 4000 for about 3 months now... aaaand I just last night learned how to toggle through the surround modes. (just in case i'm not the only doofus out there, you have to hold down the sound modes buttons, not just press them)
I just installed a X4000 in my den and I couldn't figure this out for the life of me! I have the Marantz AV7702mkII and assumed they would operate the same.
Thanks for the help… 3 years later!👍
Squirrel! likes this.
Marc Alexander is online now
post #12728 of 12743 Old Today, 01:40 AM
Liked: 0
Question [Help] Did my Denon receiver just die? I'm scared
Hello,
I've been a longtime lurker of the AVS forums and many threads here have been of great assistance to me - especially those by batpig, since I own a Denon receiver.
Now, I'm in desperate need of some help, because, apparently, my receiver just died.
What you should know:
  • Purchased a brand new Denon AVR-X2000 in late August of 2013;
  • Connected the receiver to a brand new set of JBL speakers using brand new speaker wires and Monster QuickLock MKII Gold Flex Pin Connectors;
  • Plugged the receiver into a Monster GreenPower Digital PowerCenter MDP 800 and plugged that into a grounded wall outlet (like every wall outlet in my then relatively new apartment - of 5 years);
  • The receiver has always had ample ventilation room in the top and back and no problems with temperature;
  • The receiver had been working flawlessly up until a few minutes ago, and never experienced any hardware or software failure until then (it was constantly updated to the most recent firmware via Ethernet cable).
What happened:
  • I had just turned on the receiver, my TV and an nVidia Shield TV to watch some Hulu, using a Logitech Harmony Hub and Smart Remote;
  • Because of that, the device was at idle temperatures (very low, considering I'm in Brazil and we're approaching Winter here);
  • After a few minutes (no longer than 5), I heard a loud pop and the receiver turned itself off. The front panel LED started blinking red;
  • Nothing "strange" was going on at the time: no thunderstorms, no blackouts. All other devices kept working just fine;
  • After the initial shock, I turned off all devices (including the receiver - LED was off), waited a couple more minutes and turned them back on again;
  • The receiver turned on normally (constant green light) but soon after that, I heard a "bzzt" noise coming from it and a tiny poof of smoke emerged from the top part. The LED reverted to blinking red;
  • I immediately turned everything off again and I'm now scared to even try to turn the receiver back on.
I googled the issue and came across a few posts mentioning that I should unplug all audio cables and test the speaker wires by turning on the receiver with one cable connected at a time, but considering I literally saw smoke coming out from the device, I'm afraid to even turn it on again - cables or no cables.
So, what do you guys think? Is it dead? Any help is appreciated.
Thanks in advance.
EeK9X is offline
post #12729 of 12743 Old Today, 02:12 AM
jermar's Avatar
Quoted: 39 Post(s)
Sorry to hear of your problem. I would not plug in that Denon again either. Four years is a short life, but your receiver may be toast. The only way to be sure is to take it to a repair shop for an estimate. If it just needs a new power supply, it might be worth repairing. I would shop for a new one.
Sony 65"A1E, Marantz 7005 Pre, Rotel 5ch X 120w, Axiom & HSU sub.
jermar is offline
post #12730 of 12743 Old Today, 03:13 AM
jdsmoothie's Avatar
Liked: 6219
You're going to have to turn it on again to troubleshoot, but first unplug all cables including speaker wire and source cables. If the unit still powers off ... it's likely toast. Before calling it quits, you can try doing a few microprocessor resets as listed in post 5 of the Denon 2013 AVR Owner's thread linked below ...
post #12731 of 12743 Old Today, 04:42 AM
skmastaz's Avatar
I'm having an issue with my X2000. Two nights ago everything was working perfectly and wonderfully like always, then yesterday morning when I tried to turn it on I got nothing. Upon close inspection I noticed the standby light wasn't on anymore, no lights at all. So I unplugged it and plugged it back in hoping that would fix everything. It didn't. So I then unplugged all my speakers and inputs and tried plugging it back in again that way. Still dead.
Am I hopefully just doing something stupid and missing something? Any other suggestions?
skmastaz is offline
post #12732 of 12743 Old Today, 05:13 AM
Squirrel!'s Avatar
Quoted: 577 Post(s)
Liked: 326
Probably a power surge popped an internal fuse. Have you checked the outlet for power?
Main: Mitsubishi 73736 DLP|OTA|fireTV|Sony BDP-S1100|Denon AVR-4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|2 - DIY Class G 540w 12" Subs|2 Aura Bass Shakers|APC H15|Harmony 720|TP-Link Archer C7|Linksys SE2500|50+ OTA Channels
MBR: Vizio VF550M|OTA|fireTVstick 2|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|Dayton Audio SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Belkin Bridge|Harmony 550
Squirrel! is offline
post #12733 of 12743 Old Today, 05:57 AM
skmastaz's Avatar
Yeah, I tried a couple different outlets, even on different breakers just because. So should I pop it open and check on fuses?
skmastaz is offline
post #12734 of 12743 Old Today, 06:05 AM
Squirrel!'s Avatar
Quoted: 577 Post(s)
Liked: 326
Not in warranty anymore. Might as well.
post #12735 of 12743 Old Today, 10:38 AM
Liked: 0
Hi, jermar and jdsmoothie,
Thanks for the suggestions. I tried unplugging all cables and plugging the receiver into a different outlet, using a different surge protector.
Immediately after plugging it into the outlet, without even turning it on, a lot more smoke came out from the bottom left part of the device (when looking at it from the front and above) and the red LED started blinking. The smoke would only stop after I unplugged it from the outlet.
So, I guess it's really toast? What kind of repair costs can I expect from such a failure?
I've already started shopping for a new receiver (the X3300W), but I gotta say I'm somewhat disappointed with Denon, not to say a little traumatized. I take care of my devices, and to see this happen without reason is very frustrating. Would you still recommend that brand after my experience?
EeK9X is offline
post #12736 of 12743 Old Today, 02:13 PM
pbarach's Avatar
Quoted: 353 Post(s)
Liked: 206
If there is any good news about an x2000 emitting a puff of smoke, it may be that although it IS toast, now it can MAKE toast.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #12737 of 12743 Old Today, 02:17 PM
Quoted: 162 Post(s)
Liked: 75
I guess every manufacturer has products that go bad early from time to time. It kinda stinks but on the bright side of my crazy mind I'd be thinking "yeah I get a new receiver now"! That's how this nutty mind works of mine.
Sent from my Pixel using Tapatalk
Hetfieldjames is online now
post #12738 of 12743 Old Today, 03:43 PM
jdsmoothie's Avatar
Liked: 6219
Oh boy ... it's Atmos time!
post #12739 of 12743 Old Today, 03:47 PM
Quoted: 162 Post(s)
Liked: 75
Now for the first time since I've been in this hobby I have no interest in Atmos or DTS-X. In fact I'm only doing 5.1, a long time ago I did 7.1 but I have no need for that either. A simple 5.1 started I'm running and it's a pleasure.
post #12740 of 12743 Old Today, 03:49 PM
jdsmoothie's Avatar
Liked: 6219
Adding 2 or 4 "height" speakers would increase that pleasure.
post #12741 of 12743 Old Today, 03:49 PM
Quoted: 162 Post(s)
Liked: 75
And more drain on my wallet. 😀
post #12742 of 12743 Old Today, 04:02 PM
jdsmoothie's Avatar
Liked: 6219
Just by entering this forum .. that's a given.
post #12743 of 12743 Old Today, 04:03 PM
Quoted: 162 Post(s)
Liked: 75
Yeah it is. This is a fun hobby but expensive.
assistance , dead , Denon , Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1 , receiver , support
