The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 429 - AVS Forum | Home Theater Discussions And Reviews
 415Likes
post #12841 of 12870 Old 09-05-2017, 12:19 PM
rbpeirce's Avatar
Universal remotes are known to do this so you would have to reprogram it to only power on the Main zone as one activity and only power on Zone 2 as another activity.
The setup for the remote says it is leaving everything else off but clearly that is not the case. I need more guidance, specifically, how do I turn on the AVR without turning on main (or, it turns out, zone 2)?
As an experiment I tried turning on the Zone 2 TV without activating the AVR. Then I turned on the Genie/AVR/TV setup in the media rom and discovered the zone 2 TV also received a signal. This is less of an issue since I get sound from the TV but I really don't want that on either.
Clearly this is worse than I thought. I need to figure out what commands only turn Main and only turn Zone 2 on, but not both. I hadn't noticed the zone 2 issue because the TV is normally off. I only noticed main because the surround sound system was activated while the TV was off.
I did discover I can turn zone 2 on and off on the AVR itself, but I don't know the remote command to do that. AFAIK you can't do that with main, but there must be a way.
The Harmony 880 seems to do the right thing with respect to the source (Genie, DVD or AirPlay) and the destination (turning the two TVs on or off) but not selecting the correct modes for the AVR.
rbpeirce is offline
post #12842 of 12870 Old 09-05-2017, 12:22 PM
jdsmoothie's Avatar
Quoted: 15029 Post(s)
Liked: 7248
Please read my previously edited post.
jdsmoothie is online now
post #12843 of 12870 Old 09-05-2017, 12:48 PM
rbpeirce's Avatar
I did. I saw I could manually turn main and zone 2 on and off by pressing the correct buttons on the AVR, but I can't figure out how to make the remote do that.
I posted a similar question on the remote forum, but so far you are the only one offering any advice.
rbpeirce is offline
post #12844 of 12870 Old 09-05-2017, 01:07 PM
rbpeirce's Avatar
It is a timing issue. I just need to figure out by how much to separate the commands. Main isn't an issue because the TV in zone 2 is normally off. In zone 2 I need to turn the AVR on and then turn main off. With enough delay this works. I currently am probably using too much but it gets the job done.
rbpeirce is offline
post #12845 of 12870 Old 09-05-2017, 01:14 PM
jdsmoothie's Avatar
Liked: 7248
My post refers to using the remote, not the front panel.
post #12846 of 12870 Old 09-05-2017, 02:25 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 985
There are many ways to do this on a universal. If Main turns on, you're using the wrong power command.
Denon has the following power related discrete commands:
Power (power toggle for Main)
Main On
Main Off
All Power On/Off
All Power On
All Power Off
Zone X Power (power toggle for Zone X)
Zone X On
Zone X Off (where X is Zone number for each zone)
However, each discrete input command (DVD, CblSat, Blu-ray, etc.) for Main and for each Zone also acts as a discrete on.
So the simplest approach is to not send any power commands at all but just send the discrete input command for a specific Zone or Main. In my macros I use the input commands for ON and All Power Off for turning the entire unit off. This approach may not be feasible on Harmony since you have very limited control over the content of the activity macros.
Generally, you want to avoid using Power toggle commands in macros. Rather use the On or Off commands and discrete input commands since they will consistently perform the desired function for the desired zone no matter what state the AVR is already in.
If your Harmony does not have all of the above commands, I can post the pronto hex which you can then email to logitech to add to your remote.
Then I recommend you make Main and each zone as entirely different devices, and when configuring power options, select that each has seperate commands for on and for off. Then your activities will send the appropriate power commands just for the desired zone. The AVR will not power down entirely until the activity for the main zone is run or until you send the All Power Off command in device mode or perhaps another Master Off activity.
mdavej is offline
post #12847 of 12870 Old 09-05-2017, 03:01 PM
rbpeirce's Avatar
I understand, but I am trying to set up a Harmony remote to control everything.
rbpeirce is offline
post #12848 of 12870 Old 09-05-2017, 05:40 PM
mdavej's Avatar
Liked: 985
It's useful to know which remote commands give the desired results so you can replicate on Harmony. Knowing that pressing Zone 2 then Power sends the zone 2 power command as desired is exactly what you were looking for. If you aren't interested in my codes, then you can simply learn the appropriate codes from your Denon remote.
mdavej is offline
post #12849 of 12870 Old 09-05-2017, 09:58 PM
jdsmoothie's Avatar
Liked: 7248
I'll say thank you for the OP for supplying an alternative to my "manual" approach to having the Harmony remote learn the command from the Denon remote.
post #12850 of 12870 Old 09-06-2017, 06:17 AM
rbpeirce's Avatar
True. Thank you. If the codes aren't already there I can always train the Harmony remote from the Denon remote. I forgot that option.
rbpeirce is offline
post #12851 of 12870 Old 09-12-2017, 07:11 PM
pg_rider's Avatar
Quoted: 78 Post(s)
Liked: 33
Help! Tried searching to no avail. I've somehow gotten my X4000 into an "Installer Locked" / "Web Lock is on" state. All the menus are grayed out and I get the Web Lock is On statement if I select them. And, when I log in via the web interface, I see "Installer Locked!" (see photo).
I think I may have done this today while using the DeRemote app on my iPhone. I dropped it and maybe it enabled the lock somehow? I'm trying to avoid a Reset to solve this -- help!
LSA One Monitors, LSA LCR Center, LSA On Wall surrounds, dual Hsu VTF-3 subs, Denon AVR-X4000, Adcom GFA-6000 amp, UTurn Orbit turntable, Samsung UN75HU8550
pg_rider is offline
post #12852 of 12870 Old 09-12-2017, 07:20 PM
pg_rider's Avatar
Quoted: 78 Post(s)
Liked: 33
On the receiver menu itself:
pg_rider is offline
post #12853 of 12870 Old 09-12-2017, 08:33 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi pg_rider, I don't use DeRemote app but check if the app has a setting to hide panel/lock tabs or setting like my controls.
JChin is offline
post #12854 of 12870 Old 09-13-2017, 03:10 AM
jdsmoothie's Avatar
Liked: 7248
I'll do some checking on this, but a reset may be your best option.
post #12855 of 12870 Old 09-13-2017, 06:23 AM
pg_rider's Avatar
Quoted: 78 Post(s)
Liked: 33
Thank you! But crap -- does this mean you've never seen this configuration behavior before? lol
pg_rider is offline
post #12856 of 12870 Old 09-13-2017, 10:47 AM
jdsmoothie's Avatar
Liked: 7248
I just checked with an installer friend of mine and he said he's never seen it before. Just do a reset.
post #12857 of 12870 Old 09-16-2017, 01:50 PM
Liked: 1
I just bought 3300w receiver, and apparently when i press power button on remote, I cant completely turn off the receiver....seems like zone 2 is still on? I am so frustrated with this receiver now......I will send it back if I dont resolve this.....
On screen of the receiver it says main zone off, zone two on.....I dont want this freaking receiver the use electricity when I turn the power off, what kind of bs is this?
paridparid is offline
post #12858 of 12870 Old 09-16-2017, 02:33 PM
Liked: 1
ok figured it out, you have to press zone 2 on remote and than turn off on remote button,,,,very weird...who needs these zones anyway....not gonna give my grandma freaking amp signal...
post #12859 of 12870 Old 09-17-2017, 10:44 AM
jdsmoothie's Avatar
Liked: 7248
If you rarely (never) use Zone 2, you can disable it from the remote. Refer to p. 228 of the Owner's manual.
DoctorM likes this.
post #12860 of 12870 Old 09-18-2017, 09:26 AM
Francesco Villa's Avatar
Hi all, I need a little confirm on zone 2 for my x4000.
I'm setting up a 5.1 zone 1 for a projector and, in the same room, I'd like to set up a 2.0 zone 2 for TV (i.e.: I don't want to fire up the pj just to see a movie).
Zone 1 and 2 will never work together... can you guys please confirm that this is possible?
Thank you for your help
Francesco
Francesco Villa is offline
post #12861 of 12870 Old 09-18-2017, 09:31 AM
jdsmoothie's Avatar
Liked: 7248
Francesco
Yup. Connect the Zone 2 HDMI output to the TV.
post #12862 of 12870 Old 09-18-2017, 09:38 AM
...and use two of the assignable speaker outputs for zone 2 speakers, right?
post #12863 of 12870 Old 09-18-2017, 10:22 AM
jdsmoothie's Avatar
Liked: 7248
Correct. Note however, that in order to pass the HDMI source audio to the Zone 2 speakers, the source must be stereo 2.0.
post #12864 of 12870 Old 09-18-2017, 10:46 AM
Mmmmh, this is very annoying. No workarounds here? Manual switch in the setup menu for each source, every time?
post #12865 of 12870 Old 09-18-2017, 11:29 AM
mdavej's Avatar
Liked: 985
Denon has a gazillion discrete codes for everything. I just send the appropriate command from my universal remote, no digging into the menus required.
mdavej is offline
post #12866 of 12870 Old Today, 10:52 AM
Thank you so far.
And if I had a stereo amp? Will zone 2 downmix to stereo if I use RCA pre outs?
post #12867 of 12870 Old Today, 11:00 AM
jdsmoothie's Avatar
Liked: 7248
Thank you so far.
As stated previously, the source must be 2CH.
post #12868 of 12870 Old Today, 11:39 AM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
I have to shake my head any time I hear of someone trying to use zones. They just don't ever work in a spouse/family-friendly kind of way.
People try to jump through all kinds of hoops to make it work... and it almost never does. I know there's a few edge cases where it does just enough for some folks, but most folks have overly optimistic hopes for it... and they're almost always disappointed. Hate to sound negative, but it's a sad truth.
That and only a few of the AVRs ever have the internal circuitry/logic necessary to handle transcoding from different sources (as in, 5ch down-mixed to 2ch and the like).
wkearney99 is online now
post #12869 of 12870 Old Today, 12:37 PM
jhachey's Avatar
Quoted: 44 Post(s)
The value of multi-zone really comes down to what you want to do in the additional zones. For me, Zone 2 is a pair of speakers on my back patio. I pretty much only use Zone 2 to stream music from my server and it works like a charm. I guess with wireless speakers like the Denon HEOS system, I probably wouldn't need a Zone 2 these days, but it was fantastic when I set it up four years ago.
I have occasionally hauled out a small TV onto my patio to watch some sporting event and had to tweak my cablebox settings to deliver 2-channel stereo. Not really difficult, but certainly not very user-friendly either. Not something that my wife, who isn't interested in the nitty gritty of our AV system, would know how to do.
wkearney99 likes this.
jhachey is online now
post #12870 of 12870 Old Today, 12:41 PM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
Amen to that. The WAF (wife acceptance factor) should not be ignored when attempting to implement AV solutions.
For the back yard music I went with a Sonos Connect:AMP and their remotes. Made it brain-dead simple to use. Unfortunately we've since moved to using Amazon Echo devices everywhere and there's no "good" solution for that just yet. There's "ways" but none quite perfected yet...
Although, voice control could be the savior of overly complicated AVR matrix setups.... Haven't revisited the idea lately, could be worth another look...
assistance , dead , Denon , Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1 , receiver , support
