*Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
Old 04-16-2013, 07:57 PM
spacecowboy's Avatar
Quoted: 56 Post(s)
Liked: 37
Anyone besides me having weird HDMI issues using the XBOX 360? I get no video, and sporadic to no audio at all. I did the firmware update on page 1 of this thread successfully and swapped out HDMI cables - all to no avail. My PS3 plays movies and games flawlessly through the same HDMI ports. The only thing that works is running the HDMI from the projector straight into the XBOX. Only then do I get video with audio coming from the projector speaker. Is there some incompatibility with the Pioneer and the XBOX, or is my SC-1522 defective. Thanks for any input.
"Excuse me...What does God need with a Starship?" (Captain Kirk - Star Trek V: The Final Frontier)
spacecowboy is offline
Old 04-16-2013, 08:19 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Make sure you power on projector first, receiver next, then Xbox. If your receiver is powered on first, you may encounter this issue as I do occasionally.
Sent from my RM-820_nam_canada_246 using Board Express
jackoolme2004 likes this.
Foxbat121 is offline
Old 04-16-2013, 09:11 PM
Quoted: 56 Post(s)
Liked: 37
Thanks for the tip. Unfortunately, no go. I did as you said and I get the short XBOX start up sound, but after that I get no picture, no sound.
Old 04-16-2013, 09:32 PM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
Dammit, I love this receiver but I think it just kick the bucket. I got pictures but no sound coming out. It was working fine last night, I try to finish my movie from last night but nothing, zipp, nada, no sound coming from any Hdmi source. Apple TV, cable box, ps3, bdp62. Picture is there though. Any one know how to do a hard reset?
Working again after I hard power disconnect.
What a relief
datranz is offline
Old 04-16-2013, 09:52 PM
Needis's Avatar
Just curious, build date on my box states july 2012.
Needis is offline
Old 04-17-2013, 12:30 AM
sososteve's Avatar
Anybody have an idea on how to hook up the included FM antenna? It looks like a wire with a metal piece at the end - am I supposed to just pug it directly to the nub coming out of the FM antenna port on the receiver? Seems ghetto, could really use some advice!
sososteve is offline
Old 04-17-2013, 12:49 AM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Yes, that's how it suppose to be. Fortunately, I still have an antenna from old receiver and it has the nice plug. Can't believe Pionner wants to save a few pennies here for a $1500 receiver.
Old 04-17-2013, 04:29 AM
Pioneer_Elte's Avatar
Quoted: 64 Post(s)
Liked: 56
You will need to get an adaptor/transformer that has a coax plug on one end and two terminal screws on the other end for the FM wire.
Use the link below to get an idea of what you'll need to look for or look up Radio Shack part # 15-1253.
http://www.radioshack.com/product/index.jsp?productId=2062054&znt_campaign=Category_CMS&numProdsPerPage=60&znt_source=CAT&znt_medium=RSCOM&znt_content=CT2032189
This would be the cheapest solution. If you have your receiver in the basement or another location with poor FM reception, I would suggested getting a powered FM antenna to boost the signal.
vivatech likes this.
Pioneer_Elte is offline
Old 04-17-2013, 09:03 AM
Jithtproject's Avatar
What am I doing wrong?
I just set up my 1522 like these:
Blu ray thru hdmi: works fine.
DVD changer thru component and coax digital input: works fine.
Optimum set top box thru hdmi : I get video but no audio.
I changed hdmi cables at least 4 times.
I got new cable boxes twice.
I made sure cable box had hdmi output for audio.
I used different hdmi inputs on 1522, still no audio.
Do you think, it is 1522? Do I need to change my receivers?
I am tired of trouble shooting.
Any other suggestions.
Cable box works fine when connected to TV directly in other rooms.
Jit
JHT
Jithtproject is offline
Old 04-17-2013, 09:17 AM
Quoted: 56 Post(s)
Liked: 37
Jit
I am having a similar problem with my XBOX 360. Perhaps there is something random going on with how the 1522 handles the HDMI handshake with different devices. I swapped out cables, but still no go. I may have to return it to Costco and swap receivers. I'll let you know if I have the same issues.
Old 04-17-2013, 09:19 AM
Quoted: 64 Post(s)
Liked: 56
Jit
Just a thought. Do you have the receiver set to get audio from the tv via ARC? If the receiver is expecting to get the audio signal from the tv, that could explain why you're getting no audio but you are getting video.
I haven't had Optimum in over 4 years so other than the thought above, I can't be of more assistance to you.
Old 04-17-2013, 09:44 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi spacecowboy, go into Xbox 360 display menu and try turning off "Display Discovery" and see if that helps.
JChin is offline
Old 04-17-2013, 09:57 AM
Sorry, I forgot to mention that I have a front projector with HDMI going thru.
JHT
Old 04-17-2013, 10:03 AM
Needis's Avatar
I have issues with the xbox audio using my old amp too.
Needis is offline
Old 04-17-2013, 12:04 PM
jackoolme2004's Avatar
Originally Posted by GusGus748s View Post
I don't even know why I bother re-posting this.
https://www.dropbox.com/s/wcvouknssbseg0m/MCACC_SUB_EQ_1_3.pdf
I tried the intruction above since im having same issue with the Bass but my problem is in SPEAKER SYSTEM i dont have option to pick Normal(SB/FW) when i push the right menu to change mine is set to 7.1ch Front Bi-Amp and no choice of Normal (SB/FW) is there something im missing?
jackoolme2004 is offline
Old 04-17-2013, 12:17 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
You do not need to change the speaker system. When you run MCACC, the AVR automatically knows how to speakers are set up. Unless, you have the front in passibe bi-amp, which you will have to change. I just want to also remind you this set up was done for the 1222, which is similar to the 1522. The 1522 has a few features that work a little different.
So you are trying to set it up as 7.1 biamping the front and also have Front wides?
GusGus748s is offline
Old 04-17-2013, 12:22 PM
jugger's Avatar
Liked: 55
I get this sometimes with my directv receiver where there is picture but no audio. I have to turn off the pioneer receiver and turn it back to get the sound. This happens when changing inputs and not on power up. Sometimes after 3 minutes (if left on) the audio will come back. Only one time I got scrabbled sound from my PS3. It is starting to make me wonder.
What a relief
RC-64 Center, RF-7 Fronts, RF-82 Sides, RW-12D, QTY=2, RSW-15, RS-52ii Rears, Pioneer SC-1522-K, Panasonic 65VT60, 65"
jugger is offline
Old 04-17-2013, 12:25 PM
Quoted: 56 Post(s)
Liked: 37
It worked!!! Thank you JChin! You saved me the hassle of a return/setup. I had "Display Discovery" enabled, so I turned it off and it works now. Also a big thanks to FoxBat and everyone else passing along info to get the most out of this receiver.
Old 04-17-2013, 12:38 PM
I replaced one more cable box. Got sound and picture, no problem. Changed channels etc. No problem. After watching a movie turned off everything and restarted everything. Same problem again. No sound !!! I am going to get a new receiver and see. Otherwise I am back to my 10 year old receiver.
My Costco has few in stock. Thank god.
JHT
Old 04-17-2013, 12:55 PM
Thanks for the reply....i have 5.1 set up and biamping the 2 fronts left and right speakers... the Macc sets my speaker system to 7.1ch Bi-Amp with Front Bi-amp Center : Normal SUrr: Normal SB:Normal Surr Pos: in rear
Speaker setting
SW: Yes
Front: Large
Center: Large
Surr: Large
SB: No
XVOVER: 80hz
my speakers are Energy CF-70 fronts And Center CC-10 withj C-5 Rear speakers and enregy 10 inch sub.
Old 04-17-2013, 12:56 PM
Speaker setting
SW: Yes
Front: Large
Center: Large
Surr: Large
SB: No
XVOVER: 80hz
Old 04-17-2013, 01:15 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Speaker setting
SW: Yes
Front: Large
Center: Large
Surr: Large
SB: No
XVOVER: 80hz
Ok, I see what you mean now. The only thing I can think of is which channel are you using to biamp your front speakers? At the moment I am getting ready for work so I can't get into the back of my AVR and manual to see the biamping option. Hopefully, someone else can help you. If not I will try it out when I get back from work.
Old 04-17-2013, 03:18 PM
mooonshine199's Avatar
I've got a Logitech Harmony One remote, and I'm wondering if and how can I set up a "activity" on it's main screen to go directly to Pandora on the 1522? I've looked and can't seem to find anything on this. I'm sure it's possible because I can do this on my Android phone, but there doesn't seem to be a button for Pandora on the remote, just "Net" which toggles through inputs. Any ideas? Thanks!
mooonshine199 is offline
Old 04-17-2013, 03:32 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
you can create a Pandora input command from HEX code. There are many posts about how to create IR command for Harmony from HEX code already here.
Old 04-17-2013, 04:35 PM
henryld's Avatar
Go to the Remote Control section here on AVS or Remote Central site for answers to your question.
henryld is offline
Old 04-17-2013, 06:20 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
No need to go to remote section. I already posted detailed instructions in this thread.
Old 04-17-2013, 06:47 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Whenever you use bi-amp, there will be no other options because the fw amps are occupied.
It looks like MCACC auto set all speakers to large which is a common complaint. Unless your speakers can really go full range, you will be better served by setting them to small for better bass. If you decide to leave fronts as large, set subwoofer to Plus.
Speaker setting
SW: Yes
Front: Large
Center: Large
Surr: Large
SB: No
XVOVER: 80hz
Old 04-17-2013, 07:26 PM
cmetz2's Avatar
Originally Posted by cmetz2 View Post
Given other discussions on this forum, it sounds to me like Pioneer's quality control isn't all that great, and so both are possible.
UPDATE: I bought another one, with a very different build month, and I have exactly the same buzzing/humming sound from the same place. So with two units behaving identically, that points much more towards it being a problem with this receiver's power supply design and my home's power.
Still, interesting that the older Denon's power supply doesn't have an issue.
cmetz2 is offline
Old 04-17-2013, 08:47 PM
I just brought new 1522 from Costco. I will swap it out tomorrow and see my problem with hdmi audio issue is resolved or not.
JHT
Old 04-18-2013, 07:01 AM
IronWaffle's Avatar
Quoted: 30 Post(s)
I'm a bit lost what to do. MCAAC insists that two speakers (R and SR) are reverse phase. I've triple checked and they're wired properly.
Thanks in advance for any ideas. Hopefully there's a "duh, why didn't I think of that" solution.
Pioneer Elite SC-LX701 Receiver | Oppo 203 4k Blu-Ray | Samsung 65JS850D UHDTV
PSB Imagine T2, C Centre & Imagine S Surround | SVS SB-2000 Subwoofer
Mac mini (2012) iTunes Server | Logitech Harmony Smart Control & Hub
Amazon Echo Dot | Samsung SmartThings Hub
IronWaffle is online now
Pioneer Sc 1522k 9 2 Channel Av Receiver
