*Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
Old 04-27-2013, 11:44 AM
thatguyhileman's Avatar
I believe they may be referring to going into the standing wave settings and raising the sub trim by 3db or so. I could be wrong, but I think that's it. Someone correct if I'm wrong.
thatguyhileman is offline
Old 04-27-2013, 07:53 PM
DragonflyMed's Avatar
Originally Posted by phenyle View Post
Can someone confirm that this reciever is "not" capable of outputting two independent HDMI sources, i.e HDMI out 1 and HDMI out 2 can display two different HDMI input sources. This is a big deal for me and the only reciever i have found that can do this at a decent price point is the denon 3313ci
I'm quite certain you can display different sources through second hdmi output. It mentions it in the manual clearly about optional setups.
DragonflyMed is offline
Old 04-27-2013, 09:59 PM
miicho's Avatar
Help pls should i get this receiver or the onkyo 818?
miicho is offline
Old 04-27-2013, 10:03 PM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
Without a doubt. For one you got digital amps, 9 channels. And no hdmi problems like the onkyo has.
miicho likes this.
metalguy is offline
Old 04-27-2013, 10:07 PM
miicho's Avatar
Thank you for your advice, now does the xt32 really make a difference?
miicho is offline
Old 04-27-2013, 10:09 PM
basshead81's Avatar
Quoted: 219 Post(s)
Liked: 5907
i would stay away from onkyo...
miicho likes this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 04-27-2013, 10:11 PM
miicho's Avatar
I'm gonna have to run to costco tomorrow.
miicho is offline
Old 04-27-2013, 10:14 PM
basshead81's Avatar
Quoted: 219 Post(s)
Liked: 5907
spend some time resesrching it instead of taking one members word on it. from the research i have done, some folks hsve good success and others say its not that impressive. it all boils down to how far your room acoustics are off. imo buy a reciever that is reliable and has all the features you want. there is plenty of after market room correction software options that you can add down the road if needed... such as minidsp, antimode, bhd...fwiw i have read alot of folks with audyssey avr's that still end up with one of the above mentioned because audyssey did not do that great of a job.
miicho likes this.
Old 04-27-2013, 10:21 PM
miicho's Avatar
Well i'm no audiophile not even close but i really want to upgrade and both the 818 and the Pioneer are within my budget, so i was looking for an educated opinion from the folks here at avs, I'm leaning more towards the pioneer now, i just wanna be sure i make the right decision.
miicho is offline
Old 04-28-2013, 08:45 AM
osv
osv's Avatar
Originally Posted by JChin View Post
Hi f1snob, on the remote use "Signal Sel" and set to Digital.
i had the same problem, thanks for the post.
the problem manifests itself as no audio, even when input is setup correctly, because the input setting is being overridden.
perhaps they'll fix it in a firmware update.
osv is offline
Old 04-28-2013, 06:55 PM
petiteface's Avatar
@miicho
I have recently done a comparison between 818 and the pioneer 1522.
Pioneer Pros
1. Spectacular upscaling (zero adjustment required and it provided a much better image of my satellite, netflix and DVD) - smooth, sharp, beautiful colors. So if image is your primary requirement, the Pioneer is it. It not even close on this front. Even though the Onkyo has a great upscaling chip, despite my best attempts, tuning the color to pleasing levels was just not feasible. The skintones are just off and horrible.
2. Looks - Looks much nicer than the Onkyo.
3. Price - If you get the costco deal, you have a $200 cheaper receiver compared to the Onkyo ($100 if you go with the onecall open box deal for $699)
4. Pioneer reliability is generally considered better (I have my 10 years old vsx-45tx still working just fine), although the Onkyo 818 has been pretty decent
5. 9 channel amps (not an issue for me)
6. Runs cooler - May be a factor if you are placing it in a tight space.
Pioneer Cons
1. I think the Onkyo has a better sound for my preference. I know there are folks who prefer the digital amp sound of the pioneer, but I am not one of them. Onkyo has a more open sound, easier tuning with xt32. But for music, depending upon your speakers, the clean sound may be a bit grating. The high frequencies in the Pioneer seem more rounded.
2. Warranty - Pioneer has only a 1yr warranty, while Onkyo has a 2 year warranty
3. weight - Onkyo appears to be a more substantial amp since its heavier with more robust panels.
From my perspective, I am going to try to tune the sound on the pioneer since I cannot give up the image quality now that I have experienced it. The Onkyo is going back. The weird thing is that I seem to be getting used to the pioneer sound that it seems to be growing on me.
Hope this helps.
miicho likes this.
petiteface is offline
Old 04-28-2013, 07:08 PM
miicho's Avatar
Originally Posted by petiteface View Post
@miicho
Pioneer Pros
Pioneer Cons
Hope this helps.
Thank you so much for your advice, The Pioneer it is... If i can find it in stock, tried a few costcos earlier with no luck,
miicho is offline
Old 04-29-2013, 07:08 AM
varan's Avatar
I couldn't agree more, I grabbed SC-1522 from Costco @ 599 but I think my Onkyo TX-SR705 sounds much better with MUSIC, the high frequencies of SC-1522 is making my music 'annoying' - hyper-active tweeter - I will try various adjustments and post back. Any thoughts on tweaking higher frequencies? Otherwise, I think SC-1522 is awesome
varan is offline
Old 04-29-2013, 08:22 AM
basshead81's Avatar
Quoted: 219 Post(s)
Liked: 5907
does it have a eq so you can tone down the higher frequencies?
Old 04-29-2013, 08:42 AM
spacecowboy's Avatar
Quoted: 62 Post(s)
Liked: 38
Yes.It does.
"Excuse me...What does God need with a Starship?" (Captain Kirk - Star Trek V: The Final Frontier)
spacecowboy is offline
Old 04-29-2013, 08:54 AM
alnilam1's Avatar
@miicho
Pioneer Cons
3. weight - Onkyo appears to be a more substantial amp since it's heavier with more robust panels.
From my perspective, I am going to try to tune the sound on the pioneer since I cannot give up the image quality now that I have experienced it. The Onkyo is going back. The weird thing is that I seem to be getting so used to the pioneer sound that it seems to be growing on me.
Hope this helps.
1. I switched from an Onkyo also and feel that my Klipschs never sounded better than today. I'm not heavily into audio engineering and sound discernment (not denigrating those who are in the least!) To me this is a bit like wine tasting. But my new Pioneer made me feel I had finally arrived at the listening plateau I have been seeking since I visited a neighbor's house as a kid and was melted by the purity of his pre-stereo sound. I know there is probably better in the world but I don't think I'm worthy of it quite yet. In addition, my Onkyo had a habit of cranking in the L and R speakers as a function of volume, starting at a level too high to be subtle. Never could figure that out!
2. If you are fortunate enough to get the Costco deal, your warranty seems to me to be limited only by the percentage of rust visible on the Pioneer when you bring it back in. After a certain disintegration level you may need to speak to the store manager. No return postage either.
3. Up to the point where I find it difficult to place the device on a shelf by myself, this seems to be more of a "pro." Heavy transformers are worth their weight in iron. This isn't a Walkman.
We made a good choice.
Bob Sackett
alnilam1 is offline
Old 04-29-2013, 10:17 AM
N2AUDIO's Avatar
Quoted: 18 Post(s)
I found something quite interesting with my converted LP music. Half of my LP collection was transferred to 320kps MP3s with my original 1982 Harman/Kardon T40 turntable and AT cartridge, with the other half being transferred with my new Rega RP1 turntable and Ortofon 5M cartridge. Surprisingly, with the Pioneer SC-1522-k's EQ system, the tracks recorded using the older H/K T40 sound much warmer, natural, and have much better low end than does the Rega/Ortofon combination. The high end on the Rega is much more pronounced and/or exaggerated, so much so that I have to turn the EQ off on the Pioneer in order to make it listenable. Now, I was aware going in that the Ortofon cartridge is a brighter sounding cartridge in general, but I didn't think it would be that much brighter. But it's nice that I can tweak the playback sound with my Pioneer to make the overly bright recordings listenable. I'm a bit old school when it comes to audio (I still have a 3-head cassette deck and VCR!), but I have to admit I do like the flexibility and convenience of using my iPod Touch 4G to play my LP library on my Pioneer!
Oh, and one other thing...this past weekend I watched "Super 8" on Blu-Ray with the Dolby TrueHD soundtrack and MAN was that awesome sounding on the Pioneer. WOW! Certain scenes when glass was shattering, it sound like MY windows were the ones that were breaking! This Pioneer does WAY more than I'll ever use or need it for, but what it does right is get the sound right, has a great auto cal/room correction feature, and has excellent sound processing for the money.
N2AUDIO is offline
Old 04-29-2013, 04:58 PM
Jim90068's Avatar
Does anyone know if there is a built in DAC (Digital to Analog Converter) to automatically enhance (warm up) digital tracks, from Ipods etc?
Jim90068 is offline
Old 04-29-2013, 05:15 PM
ss9001's Avatar
Quoted: 347 Post(s)
Liked: 415
Originally Posted by Jim90068 View Post
Does anyone know if the is a built in DAC to warm up digital tracks, from Ipods etc?
hope your question makes sense to somebody because it sure isn't worded well. what are you really trying to ask?
Steve
ss9001 is offline
Old 04-29-2013, 05:21 PM
I think the should be "there".
Does anyone know if "there" is a built in DAC to warm up digital tracks...
Old 04-29-2013, 05:42 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 408
The Auto Sound Retriever mode is what you are looking for. It is not a DAC (never heard of the need of any special DAC for that). But rather a DSP processing.
Foxbat121 is online now
Old 04-30-2013, 11:16 AM
toddRiffic's Avatar
Liked: 24
Has anyone else noticed when alc is turned on that the decoding switches to the signal coming in? I.E. listening to pro logic from a stereo signal from netflix works but when alc is turned on the AVR goes to stereo mode and I was listening to the Neo X "enhanced" 7.1 track on The Expendables 2 in a Neo X mode then turning on the alc the AVR went to the standard DTS HD MASTER decoding. Seems that one can not listen to a decoding scheme for heights or wides along with the addition on the alc processing. Anyone else notice this or am I missing something?
toddRiffic is offline
Old 04-30-2013, 11:39 AM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 408
Isn't ALC command on the same button as Auto? So in order to get to ALC (Auto->ALC->Direct->Pure Direct), you need to go through Auto Surround first which will take you out of whatever processing you set on?
Old 04-30-2013, 12:23 PM
Goride's Avatar
Did you try adjusting the EQ in the higher frequencies down a notch or two?
That is something the 1522k gives you that Audyssey receivers do not. You can manually adjust any of the various EQ settings to your liking.
Goride is offline
Old 04-30-2013, 12:27 PM
Quick question...Does anyones speakers pop slightly when powering off their 1522? Also, every time I've run MCACC, my right rear speaker has made a secondary popping during the delay check I believe. Whichever test has the constant popping sounds, it has two or three quieter popping sounds in between the regular sounds about three or four in (almost like an echo). No other speaker does this and then today when I was queuing up a Blu Ray in my PS3, the same speaker popped a few times when the movie was going between menus and previews (would pop when the listening mode was changing). I doubt it's the speaker and I have yet to move another over and try simply because I have towers and it's aggravating. Could this be a problem in the amp? I'm just wondering if I should try and exchange this one before my Costco runs out. Any help would be appreciated.
Old 04-30-2013, 12:42 PM
osv
osv's Avatar
Originally Posted by thatguyhileman View Post
Quick question...Does anyones speakers pop slightly when powering off their 1522? Also, every time I've run MCACC, my right rear speaker has made a secondary popping during the delay check I believe. .
swap rear speaker wires on the back of the receiver, if the problem goes to the other speaker, it may not be a speaker problem.
osv is offline
Old 04-30-2013, 01:09 PM
toddRiffic's Avatar
Liked: 24
Yeah I would like to apply alc to any surround mode like audyssey dynamic eq/vol could on my old AVR.
Old 04-30-2013, 01:18 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 408
It is a hint that ALC button is not stand alone. It appears that it is not possible to do you want above. I have tried using a discrete ALC command and it will turn off all processing.
Old 04-30-2013, 03:39 PM
RichCoate's Avatar
You can set up an account at radio-pioneer.com and make a favorites folder. You receiver will find this and use them.
RichCoate is offline
Old 04-30-2013, 03:42 PM
RichCoate's Avatar
Is anyone else having trouble with Airplay. I can see the receiver on the network and stream files off my PCs hard drive but neither iTunes nor an iPhone will recognize the receiver for Airplay.
Pioneer Sc 1522k 9 2 Channel Av Receiver
