*Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
Old 05-18-2013, 09:48 AM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
How long is the HDMI cable to your TV?
Foxbat121 is offline
Old 05-18-2013, 09:50 AM
Ace2377's Avatar
I think it's 6 feet long. I just can't grasp why it works in out 2, but not out 1. I can hear it, just can't see anything. lol
Ace2377 is offline
Old 05-18-2013, 09:52 AM
117olddude's Avatar
Quoted: 21 Post(s)
I had the same issue last night, where I hit menu and I had no on-screen display (it was on the Pioneer display). I turned it off and then on, then I got display on my TV. HDMI 1 on my Samsung, BD out to the Pioneer.
117olddude is offline
Old 05-18-2013, 10:06 AM
apaulct's Avatar
Ace, have you updated to the latest firmware. I had some funky things happen with the out-of-the-box firmware, they went away when I updated. Don't forget, the update must be via USB, OTA is not available for the latest download.
Allen
apaulct is offline
Old 05-18-2013, 10:07 AM
Ace2377's Avatar
Yes, that was the first thing I did once I hooked the receiver up. Thank you for the suggestion though.
Ace2377 is offline
Old 05-18-2013, 11:28 AM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 397
Try turning the video converter off in Video Parameters for your HDMI source. there may be a resolution setting not compatible. if that restores video, then you can play with the settings to see if that helps but first try disabling it so that there's nothing in the receiver's HDMI circuit path & see what happens.
Steve
ss9001 is online now
Old 05-18-2013, 12:13 PM
Ace2377's Avatar
Nothing is working. Getting worried I have a defective unit or something. REALLY don't want to drive an hour and a half each way to return this thing.
Ace2377 is offline
Old 05-18-2013, 12:22 PM
Needis's Avatar
I couldnt figure out the no airplay icon issues till i disable the IGMP in the router setting.
http://willthethrill.net/get-airplay-working-again-after-ios-6-verizon-fios-routers/
Once i disable the feature the airplay icon appeared on the iphone4s and my itune pc.
Try google your router and airplay issue. For me it wasnt the receiver but the router.
Needis is offline
Old 05-18-2013, 12:35 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Sounds more and more like a faulty receiver.
Old 05-18-2013, 12:42 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I just tried that and no luck. This is so aggravating. Video works fine when it's in out 2, but anytime I put the cable back in out 1, there's no video. Really weird!
May be during the production process they switch the HDMI ports by mistake eek.gif
GusGus748s is offline
Old 05-18-2013, 01:05 PM
Ace2377's Avatar
Really sucks! Picked it up at at Costco for $599, but had to drive an hour and a half to get it and back home. Now if I want to return it that'll be 6 hours of drive time and gas for this dang thing. There goes my savings. lol. Knowing my luck I'll return it and have the same problem; something I have configured wrong. lol
Ace2377 is offline
Old 05-18-2013, 01:13 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Try perform a factory reset before you return it to see if it fixes anything. Instructions can be found inside the manual as well as this thread. Also, if you decide not to pick another one up, you can return it to your nearest Costco.
Old 05-18-2013, 01:40 PM
Ace2377's Avatar
Just did factory reset and tried again. Put the cable in HDMI out 1. The output on the receiver defaults to HDMI out all. Changed it to 1, then tried bringing up the setup menu...nothing. Put the cable in out 2, switched the out on the receiver to 2... and voila...there was the setup menu. Sounds like I have a bad unit. mad.gif Three hours of driving and gas if I want to exchange this thing...BUMMER!!
BTW...what is that "Control" all about that is listed on HDMI out 1?
Ace2377 is offline
Old 05-18-2013, 01:54 PM
sjsufootball's Avatar
Try turning Control off on HDMI 1 and see if that works.
sjsufootball is offline
Old 05-18-2013, 01:59 PM
Ace2377's Avatar
Nope, can hear sound but there is no video.
Ace2377 is offline
Old 05-18-2013, 02:24 PM
f1snob's Avatar
Originally Posted by ss9001 View Post
hey glad you got it back! biggrin.gif congratulations. I figured that was the best shot at getting you back in business. sorry I got preachy but as you found out, modern receivers are complex wink.gif
I know how frustrating it can get when things don't go right and it looks "broken".
Arrrrggggrrrrrr.... Pandora not working again today. No internet radio, no streaming from my phone or computer. It just sits at "please wait..." Was working fine last weekend.
I DID NOT TOUCH A SETTING.
Guess I will just play from the computer also attached to the 1522. That is working fine. The wireless adapter is also working. There's gotta be some setting on the 1522 that keeps turning off the network.
f1snob is offline
Old 05-18-2013, 02:29 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Have you tried using wired connection rather than wireless?
Old 05-18-2013, 02:47 PM
Ace2377's Avatar
Well.. off I go to return this sucker! If the next one has the same problem, I'm going to scream!!!
Ace2377 is offline
Old 05-18-2013, 03:06 PM
f1snob's Avatar
Great idea and thanks for the suggestion. Yes I tried that last time I had this problem. It did not work.
I know the wireless adapter is working. I unplugged it from the 1522 and into my TV without turning it off, resetting it or anything. The TV instantly went on line. Plugged it back into the 1522 and no network. The on-line manual can not see the receiver either.
Another problem now is I have to shut the TV off when I switch from the computer to the TV. Even when going into the setup and back to the TV, it says "NO Signal" on the TV and I have to shut it off the TV and then back on. Like I said I did not have to do that before. I can turn the receiver off and wait a few seconds and the picture is whatever I was on (stand by works). But switching from cable to computer, setup back to cable or computer with the receiver on and I have to turn the TV off and on to pick up the signal.
I love the sound and capabilities of the 1522, but it just seems to have a mind of it's own.
f1snob is offline
Old 05-18-2013, 03:51 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 397
Try turning off HDMI Control. If your TV also has HDMI Control, having it on in the receiver ties the 2 together so that turning one on also turns the other on, etc. This may be why your receiver seems possessed wink.gif
What you describe sounds like it *could* be from HDMI Control. Worth a try. HDMI Control on/off is in the HDMI setup menu.
Steve
Old 05-18-2013, 03:53 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 397
and your problem also could be a spurious result from HDMI Control. did you try turning it Off as suggested? worth a try before returning it.
Steve
Old 05-18-2013, 04:19 PM
f1snob's Avatar
Great suggestion. It is off, though. When watching a DVD on the projector from HDMI out 2, the DVD player would shut off every 10 minutes. Really annoying. Yet when watching a 3d movie on the TV (goes through HDMI 1), it was fine. Took a while but I figured the HDMI control was the cause and all 3 are shut off.
Too bad it's not that simple for the network.
f1snob is offline
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
If I was having that many issues after troubleshooting, I would recommend to replace it. I can't believe how many people have issues with it. It might be a defective batch.
Old 05-18-2013, 05:34 PM
Ace2377's Avatar
Just got back from exchanging it, over and hour drive each way, and this one is doing the SAME THING!! I am furious!! Apparently HDMI out 1 just doesn't work in my house!
Ace2377 is offline
Old 05-18-2013, 05:38 PM
Ace2377's Avatar
Yes, I turned it off and still no luck. No matter what I try, even exchanging it for a new unit, I cannot get HDMI out 1 to work, only out 2 works.
Ace2377 is offline
Old 05-18-2013, 05:44 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Maybe it's a faulty receiver. You wanna sell it to me?
caloyzki is offline
Old 05-18-2013, 05:48 PM
Ace2377's Avatar
It's gotta be some kind of setting or something somewhere. I find it hard to believe 2 in a row would do this. Unpacked it, made all my connections, turned it on for the first time and tried to bring the setup menu up on my screen on HDMI out 1, and nothing. I moved the cord over to HDMI out 2, pushed the "Home Menu" button on the remote, and up on the screen pops the setup menu. For whatever reason I just cannot get anything to come up on my screen using out 1.
Ace2377 is offline
Old 05-18-2013, 05:50 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Have u try a different HDMI from your TV to HDMI 1 of the AVR?
Old 05-18-2013, 07:03 PM
Ace2377's Avatar
I don't know whether to laugh or cry, but a different HDMI cord did the trick. I totally don't get it, that cord worked fine with the receiver I just stopped using, and it works perfectly fine with the 1522 in out 2, but for whatever reason it didn't work in out 1. Tried the cord I had plugged into my PS3 and it works in out 1. Crazy!
Now another problem...using Full Auto MCACC and it's not detecting my sub. I sure hope this thing is worth the trouble it's put me through, because I am about to explode right now! lol. When I ran it last night with the other receiver everything went perfectly smooth. I went into Speaker Settings and selected YES for subwoofer, chose the 5.1 setup, but when the program runs no test sounds come from the sub and it does not detect it.
Ace2377 is offline
Old 05-18-2013, 07:18 PM
f1snob's Avatar
I feel for you Ace. I am not having the same problems as you, but problems nonetheless. It seems this thing should have a little "smoother" delivery or ease of operation. I needed the HDMI inputs and the 2 HDMI outs. I don't really care for some of the fancy technical stuff, but for the price, this was such a great deal. I am thrilled with the sound, although my 75w/ channel Onkyo 7.1 seemed to be able to play a little louder, and being able to have all my stuff (DVD, computer, WII) plugged in and able to play on the TV or projector, I still like this receiver as frustrating as it is. My mom will be staying at my house this summer while we travel to Europe. I am dreading trying to explain to her how to use it.
Hang in there!
f1snob is offline
Pioneer Sc 1522k 9 2 Channel Av Receiver
