*Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1621 of 1887 Old 09-28-2013, 09:16 PM
ed meyer's Avatar
Has anyone used the SC-1522 with the 4k pass through to a ultra 4K HD TV?
I own this receiver and was looking to purchase a LG-84LM9600 TV and was hoping the 4-k pass through would work fine.
ed meyer is offline
post #1622 of 1887 Old 09-29-2013, 12:38 AM
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
Has anyone tried the icontrol app with the new ios7?
pdxrealtor is offline
post #1623 of 1887 Old 09-29-2013, 12:43 AM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
Yes, works just fine.
GusGus748s is offline
post #1624 of 1887 Old 09-29-2013, 12:47 AM
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
post #1625 of 1887 Old 10-13-2013, 12:38 PM
gasdag's Avatar
Just got a 1522 off EBay. Looks perfect, powered up, have it connected to ps3 and my desktop PC and two speakers for now while I try it out.
1 major problem. The remote does not communicate with the receiver. I changed out for fresh batteries, the red light illuminates on the remote when a button is pressed, Ie the remote has power and is working. The receiver simply does not respond to anything I press on the remote. Volume, inputs, anything.
Does the remote have to be paired with the receiver it was made for? Any ideas? Initial reading in instruction manual does not say anything about pairing the remote to the receiver. You can teach it to "learn" other devices, but I'd think it should be working 100% with the receiver it came with.
# on the remote is AXD7668
Panasonic 60ST60, Pioneer SC-1522-K, Polk RTiA9, PS3 Slim
gasdag is offline
post #1626 of 1887 Old 10-13-2013, 12:53 PM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
You've got to push " RECEIVER" on the remote first to control it. The iControlAV2012 is better.
post #1627 of 1887 Old 10-13-2013, 12:54 PM
skriefal's Avatar
Quoted: 97 Post(s)
Liked: 79
AXD7668 is the correct model number for the remote. Check the remote control setup under Home Menu > System Setup > Other Setup > Remote Control Mode Setup.
skriefal is offline
post #1628 of 1887 Old 10-13-2013, 01:14 PM
gasdag's Avatar
Wow, RECIEVER four rows down, four columns over. THAT receiver button, not the one top left on the remote. I don't know who failed harder, Pioneer for making it that way, or me for missing it. Thanks! I am remoting now. Enjoy your Sunday evening.
gasdag is offline
post #1629 of 1887 Old 10-13-2013, 07:50 PM
jugger's Avatar
Liked: 55
Anyone found a "surround" setting that let's you hear the umpires voice at a reasonable volume on a NFL game? Extended stereo is ok but I'm not found of having all the same sound on all 7 speakers.
RC-64 Center, RF-7 Fronts, RF-82 Sides, RW-12D, QTY=2, RSW-15, RS-52ii Rears, Pioneer SC-1522-K, Panasonic 65VT60, 65"
jugger is offline
post #1630 of 1887 Old 10-14-2013, 04:10 AM
Pioneer_Elte's Avatar
Quoted: 64 Post(s)
Liked: 56
Did you try the Sports setting? If I remember correctly from when I tried it, it put the crowd in the surround speakers and the announcers on the front main.
Pioneer_Elte is offline
post #1631 of 1887 Old 10-14-2013, 08:00 PM
jugger's Avatar
Liked: 55
I just tried the sports setting and didn't really notice any difference. I kept on rewinding a penalty and went through every setting and the only one that made the ref somewhat audible was extended stereo. I feel like there is something wrong with my setup as no one else has complained about it.
jugger is offline
post #1632 of 1887 Old 10-14-2013, 09:11 PM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
Check the settings on your source. In this case the cable / satellite box. The AVR will play whatever audio format is behind sent to it. If setreo is the only source then that's all it's going to play.
post #1633 of 1887 Old 10-16-2013, 04:14 AM
DaveCarrera4's Avatar
Good point. And now for a fun fact: How many of you knew there are videos explaining most of the sound explorer settings in iControl2012?
Why go out to a movie theater?
DaveCarrera4 is offline
post #1634 of 1887 Old 10-20-2013, 04:55 PM
PetitSinge's Avatar
Quoted: 17 Post(s)
Hey all. I just experienced a strange problem with my SC-1522k I've been using problem free for several months. I turned on the unit (no error messages or other indicators that something was wrong) and no sound was being emitted from the speakers, but I was getting LFE from my subwoofer. I tried turning the unit off and back on several times, cycling the amp (receiver+speaker option on the remote) and even removed the power for ~1 minute. Nothing seemed to work. I even switched over to the MCACC setup screen and tried to adjust speaker levels where I got nothing from anything but the subwoofer. After about 10 minutes of playing with the unit I switched the amps off then on again using RECEIVER+SPEAKERS on the remote. This time there was a 'pop' emitted from the speakers and sound started to play correctly. I've now been playing music for about 20 minutes with no problem.
Any idea what might be going on? Do you think the amp or caps might be going bad?
PetitSinge is offline
post #1635 of 1887 Old 10-20-2013, 05:06 PM - Thread Starter
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
Sounds like amp section is the problem. LFE channels don't go through amp at all.
Foxbat121 is offline
post #1636 of 1887 Old 10-25-2013, 03:35 PM
N2AUDIO's Avatar
For some reason (I don't know why or how), I cannot seem to access or control my iPod Touch at all from the remote or front panel of the receiver. It seemed to work fine a couple of times before this, but now it's unresponsive to any commands. I've tried pressing the "iPod Control" button on the remote, but that doesn't do anything. The receiver seems to connect okay to my iPod Touch and I get the iPod main menu to show up on the TV, I just can't do anything beyond that. Has anyone run across this problem before? I'm afraid to do a system reset, because I don't want to lose all my settings, or will they be unaffected?
N2AUDIO is offline
post #1637 of 1887 Old 10-26-2013, 08:03 AM
jugger's Avatar
Liked: 55
Mine sometimes does this and holding down the power button on the front of the receiver for something like 10 seconds does a soft reset. You don't loose any settings.
jugger is offline
post #1638 of 1887 Old 10-27-2013, 10:51 AM
psamona's Avatar
Hey Guys, I purchased the Pioneer 1522-k receiver at Costco last month (last one in the state) for 540 + tax and it was a significant upgrade over my 7+ year Onkyo receiver.
Around 5-6 years ago I purchased 3 Athena WS-60 speakers used as my fronts/center and a pair of Athena WS-15's for the rears. Here is a link to the WS-60's - http://www.woot.com/offers/athena...ker-mar-28. Also here's a link to an Athena AS-P4100 subwoofer I purchased at that time as well - http://www.woot.com/offers/athena...fer-mar-28
I currently live in an apartment-style condo and can't run my speakers on full blast. With that being said, I feel that there is a lot to be desired from the Athena's. I don't hear everything I should (for instance if I put my ear to the speaker I can hear subtle effects that get lost when I move a few feet away from the speaker). I ran MCACC several times and have tweaked my speakers as much as possible. It's still difficult for my ears to hear dialog at times and subtle effects. I spend 60% of my listening for TV/Movies and 40% for games. I'd like to start listening to more music though.
My question is this. I purchased 2 Monitor 70's from Newegg to replace my fronts (plan on bi amping), and will pick up a CS2 for my center. http://www.newegg.com/Product/Product.aspx?Item=82-290-208&SortField=0&SummaryType=0&Pagesize=100&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
Since the Athenas are are rated at 8 ohms I am likely going to replace my rear WS-15's with the WS-60's I'm freeing up. I may eventually add the WS-15's back in for a 7.1 setup when I get a new home. I feel that my a subwoofer is currently more than adequate unless someone objects. Taking all of this in account, do you guys feel that this will be a good upgrade? Should the Monitor 70's and CS2 (also open to other center channels) sound a lot better than my Athenas? I know these are still budget speakers, but I want to make sure it's a good upgrade or I can hold off for another deal on others.
Any feedback before these puppies ship would be much appreciated!
psamona is offline
post #1639 of 1887 Old 10-27-2013, 12:37 PM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
I've got no experience with Athena' speakers. However, I do own Polk Audio Monitor speakers.
1) Passive bi-amping will not do anything.
2). I wouldn't consider going for the Polk Audio Monitors an upgrade. They are an entry speaker. If you want better detailed sound you have to buy better speakers.
post #1640 of 1887 Old 10-27-2013, 04:48 PM
psamona's Avatar
Thanks I think you're right. I know that the Monitor 70's would definitely be an upgrade, but I may hold off for a deal on some entry level mids instead. For now I can deal with my Athena's, but would like to eventually put my receiver to some real work wink.gif
psamona is offline
post #1641 of 1887 Old 10-29-2013, 07:09 AM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 62
I could not find an answer to this in the search. So I'm asking here.
My friend has this unit and bought it 6 months ago, but just finished his theater and is using it now. The unit will power off periodically when around -5 dB driving 9 speakers. I'm trying to find out if it flashes the power button.
It does not appear that any wires are near touching, so it does not appear to be grounding. Everything is in 12 gauge speaker wire.
Overheat?
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #1642 of 1887 Old 10-29-2013, 07:18 AM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
Overheat?
I'm thinking more like preventing from blowing up your speakers. Mine did the same, but I am using external amps. It will do it with certain high bass dance / techno music at +7 dB's with +10 dB's gain.
post #1643 of 1887 Old 10-29-2013, 07:22 AM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
I just realized too that I've got all of my tower speakers set to large. The 4 surround / surround back are 6 ohm speakers. So, I am going to set the 4 back speaker and center to small. Let the 4 front towers be large and test again.
post #1644 of 1887 Old 10-29-2013, 07:37 AM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 968
Do you have a subwoofer in this system? If so set all speakers to small. This will take a load off your receiver to produce low frequencies.
Afro GT
afrogt is online now
post #1645 of 1887 Old 10-29-2013, 07:41 AM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
Don't have subs. Sold both of them last week. Thus, the reason why I set my towers to large wink.gif
post #1646 of 1887 Old 10-29-2013, 09:43 AM
Quoted: 167 Post(s)
Liked: 62
He says that the problem happens in dance music when it peaks or in an explosion in a movie. I thought he might have an issue with shorting. New wiring, speakers, etc. I told him to check to ensure that at no point (behind the receiver or behind speakers) is there a chance of a vibration making wires touch.
Theater Build
post #1647 of 1887 Old 10-29-2013, 09:56 AM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
Most of the time it is a short like you've mentioned. I've checked all of my cables, and I don't haven't found anything lose or touching.
post #1648 of 1887 Old 11-10-2013, 11:05 PM
pdawg17's Avatar
Quoted: 13 Post(s)
Liked: 26
How good is the video conversion on this receiver? I just got a VT60 Panny plasma and am trying to figure out if I should turn conversion off on the receiver and let the TV do the work or if I should have the 1522 do it...any opinions?
pdawg17 is offline
post #1649 of 1887 Old 11-11-2013, 06:05 AM
smurraybhm's Avatar
Quoted: 1666 Post(s)
Liked: 2079
As an owner of your display and of a different Pioneer receiver with the same chip - turn off any processing in the receiver and let the Panasonic do it. If anyone is buying a receiver for its video chips, that's very debatable on whether it is really worth it. Love the D3 amps though.
There is no perfect display, quit looking for faults and enjoy
LG B7 OLED 65" (waiting for cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 and other toys
smurraybhm is offline
post #1650 of 1887 Old 11-11-2013, 07:17 AM
psamona's Avatar
I will say this, I own a Samsung LN46A650 TV - http://www.amazon.com/Samsung-LN46A650-46-Inch-1080p-Touch/dp/B001413D94 and ended up getting the SC-1522-K in September. I run all video through my receiver and have to say that it looks fantastic. I heard similar feedback regarding video quality on this receiver. With that being said, part of this is likely due to having an older TV with a maybe not so good upscaler. I also don't know how much scaling my receiver actually does since I'm running a lot of content from my Xbox/PS3, PC, etc. which in most cases upscaling is handled by those devices respectively.
To be honest, the single biggest thing I did to improve my picture quality was calibrating my set using the AVSForum video calibration discs. If you have not done this already (or something comparable), you're really missing out IMO. I LOVE this receiver!
psamona is offline
Pioneer Sc 1522k 9 2 Channel Av Receiver
