Nuforce AVP-18 Preamp/Processor - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 124 Old 07-27-2014, 11:14 AM
bioforce's Avatar
Originally Posted by jimshowalter View Post
This is a wonderful product!
Anyone with an Oppo 105 and another source (turntable, cable, satellite, whatever) needs one of these.
I'd been thinking about trying to find a used McIntosh C45, McCormack MAP-1, or Switchman, or shelling out for Parasound P7, but now there's no need. I can finally retire our Sony TA-P9000ES.
How does it sound? Like it's not there. Utterly transparent. An unmangled pristine analog signal.
Hi Jim,
It appears, you may be talking about the MCP-18 (Multi-channel Preamp) which is all analog, rather than the AVP-18, which is an all digital Preamp Processor.
Your assessment it right on, it is an exceptional unit.
John
CENTURY CITY AV
bioforce is offline
post #122 of 124 Old 07-27-2014, 12:24 PM
jimshowalter's Avatar
Quoted: 49 Post(s)
Liked: 52
Originally Posted by bioforce View Post
Hi Jim,
Yes, my bad--I had googled for avsforum MCP-18 and it brought me here. I don't see a separate avsforum thread for the MCP-18. Maybe someone can start one.
My system? Google for: Martin Logan 420 CLX Descent Stage Summit
jimshowalter is offline
post #123 of 124 Old 12-11-2016, 11:44 AM
Quoted: 49 Post(s)
Liked: 52
Back after 2.5 years with a question. I bought two MCP-18s (liked the first one so much, figured I'd stock up). Turns out to have been a good idea, because NuForce was then bought. Now I have a problem: The one complaint about the MCP-18 is that it comes with a flimsy little remote, and now the first of the two remotes is wearing out. Before the second remote dies, I want to program the codes into a universal remote. But the codes don't seem to be documented anywhere. Logitech doesn't have them. The NuForce manual doesn't refer to the remote at all. There is an RS-232 manual. I could probably program an RS-232 endpoint to receive different codes from a remote and map them, but I'd rather just program a remote with the original codes. Is there a way to do that? Do learning remotes, with IR receivers built in, actually work?
post #124 of 124 Old 12-11-2016, 05:41 PM
Quoted: 49 Post(s)
Liked: 52
Turns out it's supported by Logitech: https://support.myharmony.com/en-us/...ign=lookuptool
Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Marantz Av7005 Pre Processor
