Denon 1913 with Energy Take Classic 5.1.. Please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-01-2013, 07:38 PM - Thread Starter
Nafizur's Avatar
Hello guys,
After reading so many reviews, I finally bought a Denon 1913 and a set of Take classic. I didn't set up the set yet because I need to buy speaker wires. But I did unplug my set in the bedroom and hooked up the take classic with my Yamaha HTR-6130 and honestly the speakers didn't sound all that. I had to turn the volume higher than I would with the Yamaha speakers.
So I'm asking for some help as to what kind of speaker wires I should buy (gauge and brand)
Also, could u please advise how I should set up the receiver for the Speakers to work best. (What frequencies and crossover settings and what not)
Any help is appreciated. Thank you
Nafizur is offline
post #2 of 10 Old 04-01-2013, 07:43 PM
jdsmoothie's Avatar
Quoted: 12113 Post(s)
Liked: 5515
16 AWG should be more than sufficient and just use Audyssey to setup your speakers. As those are tiny speakers, the crossover levels will likely be set to about 120Hz. Review the Audyssey 101/FAQ Guide linked in my sig to ensure you do it right (eg. using a camera tripod or mic boom stand to support the Audyssey mic). Also note that for more questions, please review posts #3-6 in the 2012 Denon AVR thread linked in my sig and post any additional setup questions in that thread. smile.gif
jdsmoothie is online now
post #3 of 10 Old 04-01-2013, 08:01 PM - Thread Starter
Nafizur's Avatar
Thank you for your response. I was thinking of going with 8 gauge wire as I don't want to jeopardize any quality or power. Also, why would the speaker sound not so loud with my Yamaha amp? Could it be how it's currently set up to work with the Yamaha speakers?
Nafizur is offline
post #4 of 10 Old 04-01-2013, 08:08 PM
jdsmoothie's Avatar
Liked: 5515
Depends on the sensitivity/efficiency of each set of speakers. Also note that you may find it difficult to connect anything thicker than 12 AWG wire in the speaker posts, although anything below 14 AWG would be overkill if < 50' length.
post #5 of 10 Old 04-01-2013, 08:12 PM - Thread Starter
Nafizur's Avatar
you are right, i'll go with 12 gauge. I'm still reading the guides on your forum. Hopefully everything can be answered.
Nafizur is offline
post #6 of 10 Old 04-01-2013, 08:59 PM - Thread Starter
Nafizur's Avatar
hello,
would any of you recommend these speaker wires? they seem pretty good, but i'm no expert.
http://www.ebay.ca/itm/100FT-Quality-14-Gauge-Ga-14Awg-Speaker-Cable-Wire-for-Sound-System-Subwoofer-/400449672824?pt=US_Audio_Cables_Adapters&hash=item5d3ca91678&_uhb=1#ht_4250wt_986
This cable designed to bring superior sound from all your audio components, ideal for high end home theater systems and car audio applications. These high performance 14AWG cables, with 99.99% pure oxygen-free copper conductors deliver a wide, dynamic range with deep bass and smooth high frequencies. This heavy duty speaker wire can be used for speakers from 50W and up. Connect your audio sound system with confidence in knowing that our speaker cables will deliver quality audio every time.
Features and Specifications:
•Made for high performance audio and home theater systems
•14AWG or 14GA speaker wire
•99% Copper conductors (made to deliver high quality sound and stable voltage)
•Connect home audio speakers to entertainment systems
•Made for car Audio Systems, Speakers and Subwoofers
•Delivers rich, realistic sound even over long runs
•Transparent clear PVC jacket
•Color-coded line for easy wiring
•Stereo wattage rating: 50w and higher
•Lifetime warranty
Package Includes:
1 x 100ft 14GA speaker cable roll
Nafizur is offline
post #7 of 10 Old 04-02-2013, 04:14 AM
jdsmoothie's Avatar
Liked: 5515
Looks like regular speaker wire. Should work fine.
post #8 of 10 Old 04-02-2013, 07:01 AM - Thread Starter
Nafizur's Avatar
Thank you
Nafizur is offline
post #9 of 10 Old 04-07-2013, 10:27 PM - Thread Starter
Nafizur's Avatar
Guys, what kind of wire do I need to connect the sub? The receiver has one line out for the sub and the subwoofer's input if l/r RCA jack
Nafizur is offline
post #10 of 10 Old 04-07-2013, 11:07 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
A 75ohm coax cable terminated with RCA connectors. The same as a standard composite video cable.
Nafizur likes this.
BIslander is offline
