Very unhappy with Denon 3313 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 87 Old 04-05-2013, 02:59 AM - Thread Starter
hargutierrez's Avatar
I just bought a Denon 3313 and sad to say I'm very dissatisfied with it. My old amp was an Onkyo 606, unfortunately the hdmi board got busted so I decided to get a new receiver. I chose the Denon 3313 as I read a lot of positive reviews about it, but when I hooked it up to my unit I felt really sad because Im not happy with the sound quality as well as the picture quality. Here are my concerns, maybe users of the same unit can help me.
1. It sounded thin and bright (hollow sounding). I chose this as I thought it would be an upgrade from my previous amp, however it seems that I've downgraded my old receiver mad.gif
2. The sound is not as loud as I expected, to get an acceptable sound level I have to crank it up to 80db (max is 100) and it's still not as loud compared to my previous receiver; at 50db my old receiver is able to shake the room. Is that normal? My room is very small 4 x 4 meters
3. Picture quallity is bad when hdmi is passed through the amp instead of directly to the tv. I'm using a media player and prior to buying the amp, it was connected directly to my plasma tv and picture quality was nice, but with the 3313; it's pixelated and lacked vibrance. even after disabling the upconcersion, it still looks the same. I was under the impression that without upconversion it's just passthrough but it appears it's still being processed by the receiver.
Im using an Mission M70 series speakers (M74 as fronts) and it seems that the Denon 3313 is a very bad match with it, SQ is terrible. I already ran the Audessy setup and tried manual configuration but it's the same. I have a very small room but I would have to crank the volume of the amp close to its peak but still it seems that it can't really fill my room. I chose this model as I know it's already top of the line, but I think I made a very wrong decision.
hargutierrez is offline
post #2 of 87 Old 04-05-2013, 07:51 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
The volume control is denominated in dB, and at 80 out of 100, you're using 1/100 of the power that you'd use at 100. Double or halve power for every 3 dB, 10 times or 1/10 power for every 10 dB.
Make sure that Dynamic Volume is turned off. I uderstand that some receivers default to it being on (a bad choice IMO) Dynamic volume is great when you need it but is quite intrusive, especially at highest settings, when you don't need to limit total volume while still being able to hear dialog. And DYnVOl essentially won't work right on music unless you usee an offset, because while there's no rule for music, they generally have a lower "effective" reference level than the known movie reference.
FWIW, I prefer having my volume display set to show departure from "reference" once the autosetup has set the system to be at movie "reference" (85 dB per speaker with pink noise encoded at -20dBFS).
JHAz is offline
post #3 of 87 Old 04-05-2013, 07:59 AM
snowyo's Avatar
Maybe you have a bad receiver.That Denon should be able to lay the smack down on that 606.Go buy another and test drive it.OR you have something in the settings that is messed.The PQ should be decent as well.Something seems a miss.I have setup a couple of 1913's and 2313 for friends and have no complaints.I myself Use an Onkyo,but im not a fanboy either way.
snowyo is offline
post #4 of 87 Old 04-05-2013, 08:48 AM
deltadube's Avatar
Liked: 36
im not to happy with my denon either 3313 ci... yup take off dynamic volume will help.. you need to set it up for da sound
i did notice a very slight downgrade of picture quality.. but its the power..
125 wpc for 2 channels but dropps to like 79 wpc in 7 channel mode they made it sound like 125 per channel which it is not..
deceptive marketing.. but all the companys do it..
i added an external amp wow what a difference in the sound quality...
cheers..
deltadube is offline
post #5 of 87 Old 04-05-2013, 09:27 AM
mogorf's Avatar
Quoted: 1119 Post(s)
Liked: 714
cheers..
Did you re-run Audyssey after adding the ext. amp? If not you should do so, coz surely the gain structure of the internal power amp of the 3313 and the ext. amp are different, thus speaker trims need to be re-calibrated for reference sound, unless otherwise even DynEQ will be thrown off, for sure. smile.gif
mogorf is online now
post #6 of 87 Old 04-08-2013, 03:51 AM
gurkey's Avatar
Quoted: 273 Post(s)
Liked: 168
Denon rates their AVRs like everybody else, 2 channels = X, 7 channels = X * 0.6 (appr.).
There are only very few manufacturers, which provide realistic power data per channel for a larger number of channels combined.
gurkey is offline
post #7 of 87 Old 04-08-2013, 12:51 PM
deltadube's Avatar
Liked: 36
Originally Posted by CrappyGamer View Post
Denon has always rated their Receivers with all channels driven. I'd be extremely surprised if this were not the case with the 3313CI.
As for the sound, as others have suggested it seems very likely that it is in your settings. It could be that the speakers are set to small, it could be the speaker volume, it could be Audessy. Also, if you are using 5.1 speakers it could be your center stage, you can usually adjust this. It could be that too much of the sound is going to your center speaker.
I have owned Denon receivers for a long time and they are difficult to setup. They definitively are not out of the box, it's like you need a degree in Denon 101 sometimes but once you've done the work it should be worth it..That Denon, should be a big step up from that 606.
As for the HDMI, there is no reason this should happen at all. It the conversion is turned off then the picture should look the same, I'm not sure what to say here.
not a chance that the rating is all channels driven... out to lunch statement..
post #8 of 87 Old 04-08-2013, 12:51 PM
deltadube's Avatar
Liked: 36
post #9 of 87 Old 04-08-2013, 01:06 PM
astrallite's Avatar
Quoted: 32 Post(s)
Liked: 32
The Denon is only 1 lb heavier than the Onkyo 606, unless it's using a completely different amp topology, power output is probably similar.
astrallite is offline
post #10 of 87 Old 04-08-2013, 03:22 PM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
The government, here in the US, mandates that consumer amps be rated with all (I think it's ) "related" channels driven. At any rate every amp manufacturer interprets the regulation to mean that they can rate with left and right or any other two channels alone, and they do so.
AFAIK, no receiver has an adequate power supply to support full power output to all channels simultaneously. That would be a real problem if (a) in YOUR room with YOUR speakers at YOUR listening levels you ever need the full rated power of the amps at all and (b) there was any movie or music content that came close to having full output on all channels at the same time. You might qualify for (a) but (b) doesn't happen, AFAIK. Remember if the surround channesl are "one notch" (3 dB) quieter than the mains, they require no more than one half the power the mains are calling for. While the tyranny of doubling power for 3 dB (or 10 times power for 10 dB - twice as loud) is painful and potentially expensive on the loud end, it's kinda forgiving when your SPL needs are lower, as changes that are surely perceptible but hardly noticeable in the heat of battle cut power demands significantly.
In the end, especially since everybody plays the game the same way, either you have enough power to achieve your listening levels without audible distortion or you don't. If you do, whether you'd like to see the power specified differently is pretty much moot.
AAFAIK, the only way to know for reasonably sure how a particular receiver reacts to high power requirements for 5 or 7 simulteneous channels is to find third party testing. It's what I did, once I started hanging around here and got the mesage . . .
JHAz is offline
post #11 of 87 Old 04-08-2013, 06:22 PM
Elmo C's Avatar
Quoted: 48 Post(s)
You have every right to be upset wth Denon, they cheaped out like all the mass mrkt. Look at NAD, Rotel, HK for more realistic numbers.
Elmo C is offline
post #12 of 87 Old 04-08-2013, 06:48 PM
M Code's Avatar
Quoted: 806 Post(s)
Liked: 494
The most recent amplifier statue EIA490 written a few years back specifies that that all channels must be driven @ 1/8th rated power while measuring a single channel. So if the AVR is a 7.1, 6 channels are driven @ 1/8th and 1 channel to rated power output. Essentially it means that (2) channels are driven, then rated THD %, power bandwidth and load impedance are disclosed...
Since the tech standards committee was made up of representatives from Bose, Sony, Panasonic and Samsung.. 👎👎
One can kiss these off.. 😄
Just my 💰... 👍😉
M Code is offline
post #13 of 87 Old 04-08-2013, 07:05 PM
ray587's Avatar
My 10 year old Denon 3803 is rated the same way my new 3313 is. It was not rated all channels driven even back then. It is 10 lbs heavier though.
ray587 is offline
post #14 of 87 Old 04-08-2013, 07:47 PM
Ryder125's Avatar
When I ab different avrs Denon came up short to the others with most noticable was sound quality, I guess since you can buy them from the big box stores their popular but if you can do with feature there's better options, IMHO, I'm about to get flamed now from the Denon boys, but I'll stand by that audio first avr companies beat Denons pretty easily.
Ryder125 is offline
post #15 of 87 Old 04-08-2013, 08:05 PM
deltadube's Avatar
Liked: 36
hey bud.. an amp is not a avr or reciever eh...
us mandates it! better get your lawyer and start sueing ....take em to the cleaners...
cheers
post #16 of 87 Old 04-08-2013, 08:09 PM
deltadube's Avatar
Liked: 36
Well, I am out to lunch.... but this is how my 3808CI is rated. Not saying that is the final output but it's likely close.
heres the link to last yrs model 3312ci.. notice how da power drops .. 5 channels 82 7 channels 79 w into 8 ohm no where near 125 wpc all channels driven eh..
wake up.. smell da coffee!
http://www.hometheater.com/content/denon-avr-3312ci-av-receiver-ht-labs-measures
cheers..
post #17 of 87 Old 04-08-2013, 08:13 PM
deltadube's Avatar
Liked: 36
denon amps sound great if you add some power via an external amp.. as the processor dose a fine job.. for ht or stereo play back..
its the power that gives you the sound quality the more power and head room you got for music dynamics the better...
cheers..
post #18 of 87 Old 04-09-2013, 12:44 AM
cesarrpha's Avatar
cesarrpha is offline
post #19 of 87 Old 04-09-2013, 12:47 AM
cesarrpha's Avatar
post #20 of 87 Old 04-09-2013, 04:15 AM
jproy13's Avatar
Liked: 26
cheers..
this is where I stop following a thread:rolleyes:
bfreedma likes this.
jproy13 is offline
post #21 of 87 Old 04-09-2013, 05:27 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
Just my 💰... 👍😉
EIAA is not a governmental entity. MOreover, I am sure that the 1/8 power provision is preconditioning, just like in the Federal Trade Commission rule. You can't actually find 1/8 power until you know the power.
Here's a little FTC blurb on the rule http://www.ftc.gov/opa/2000/12/amprule.shtm.
In it they say. "Under the Rule, all "associated channels" of an amplifier must be driven to full rated power simultaneously during the power measurement tests."
JHAz is offline
post #22 of 87 Old 04-09-2013, 05:30 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
cheers
struggling to grok how any of this makes sense. A receiver contains amps. Receivers are consumer devices. So the FTC rule on rating amplifiers in consumer devices applies to them. Not terribly complicated. As it happens, it seems most standalone multichannel amps are rated by their manufacturere with all channels driven.
If somebody tried to hire me to challenge the way manufacturers interpret the rule, I'd make sure they understood how slim their chances of success were before taking their money.
JHAz is offline
post #23 of 87 Old 04-09-2013, 06:39 AM
ceh383's Avatar
Quoted: 430 Post(s)
Liked: 2893
I too bought a 3313, but, unlike you I am very pleased with it. The sound quality is a big improvement over the Sony and Yamaha receivers it replaced. The Denon is the first avr I have run video thru and the picture quality is as good or better (depending on the source) than going straight to the TV. It is possible you got a lemon, it happens with all manufactures unfortunately. If you can't get it to work to your satisfaction, return it....Get something you will be happy with.
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #24 of 87 Old 04-09-2013, 07:37 AM
ray587's Avatar
According to the FTC web site, manufactures only have to rate the 2 main channels, not the surrounds.
ray587 is offline
post #25 of 87 Old 04-09-2013, 07:48 AM
deltadube's Avatar
Liked: 36
Just my 💰... 👍😉
must get away with it cause avr are not amps eh.. they only rate 2 channels mostly and use deceptive statements for the rest ...
the specs on amps are very clear everytime ive good to look up an amp... 200 into 8 ohm 400 into 4ohm all channels driven all the time... etc.. not avrs..
great thing about the 3313 you can add an external amp via its pre outs.. its the lowest model with pre outs...
cheers..
post #26 of 87 Old 04-09-2013, 08:23 AM
M Code's Avatar
Quoted: 806 Post(s)
Liked: 494
Don't confuse the issue..
Note the date on your link 2000 that is the outdated original amplifier statue, EIA490 was done in 2007.. eek.gif
The FTC took the EIA490 directly from the EIA now the CEA as the national trade industry. Regarding 1/8th power again it was to match the all channels driven requirement not preconditioning..
Today's AVR power ratings are BS****...
Just like in car audio, stay with the established brands for more honest performance and specs...
Or go to separate components...
Just my 💰.... 👍😉
M Code is offline
post #27 of 87 Old 04-09-2013, 09:25 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
cheers..
Actually no. IN case it is important to somebody (clealy you're just having fun, which is fine)
The FTC rule is "Rule Relating to Power Output Claims for Amplifiers Utilized in Home Entertainment Products - the 'Amplifier Rule.' "
The FTC rule covers all amplifiers utilized in home entertainment products. That includes, in case it's hard to wrap your head around, standalone mono,, stereo and multichannel "amplifiers" and AVR receivers, because both contain "amplifiers" for home use.
Like I said, most standalone amps don't bother to take advantage of the "associated channels" provision of the FTC rule. But it's not illegal to specify more stringently than the rule requires.
So, the amps in receivers MUST be "amplifiers" because if they're not "amplifiers" the "amplifier rule" doesn't apply to them, right? And they don't even need to worry about interpreting the "associated channels" provision favorably to themselves if the rule simply does not apply to them, right?
JHAz is offline
post #28 of 87 Old 04-09-2013, 09:26 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
Just my 💰.... 👍😉
Assuming your response was to me, I’m just entirely lost, Clearly you did not click on the link, but made an assumption because the number 2000 appears in there. The FTC blurb I linked is related to 2012 changes to the regulation, which were made in 2012 not 2000. The EIA is not the government, and in the end you have to meet the government’s interpretation regardless of where they get the meat of their regs from. Unless adopted by a governmental agency, none of the industry group standards are law. That includes ANSI etc. They’re voluntary organizations developing voluntary standards (although most manufacturers follow them for a variety of good reasons).
At any rate, just to be massively clear the FTC rule says the changes include one to
“reduce the power output requirement during the one-hour preconditioning period from one-third of rated output to one-eighth of rated output . . .;
“One hour preconditioning period” is pretty clear to me . . .
And to requote what I quoted before just in case you might actually bother to think about what it says this time
“Under the Rule, all "associated channels" of an amplifier must be driven to full rated power simultaneously during the power measurement tests.”
Full power just can’t be the same as 1/8 power, now can it?
JHAz is offline
post #29 of 87 Old 04-09-2013, 12:09 PM
ray587's Avatar
Let's just not buy anymore stuff from these folks cause obviously they are all ignorant of the law. And why are these felons not in jail for blantantly misleading us all. And I want my money back for every reciever I've ever bought !!!
ray587 is offline
post #30 of 87 Old 04-09-2013, 01:27 PM
deltadube's Avatar
Liked: 36
cheers..
dont tell me tell denon ...
there the ones that are deceptive... only 2 channels are 125 wpc the other five only bring down the total.... like by 33% as shown before
cheers..
Denon Avr 3313ci Receiver
