Help me pick an Amplifier for Cambridge S30 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-05-2013, 07:06 PM - Thread Starter
UnNamedPerson's Avatar
I will be purchasing Cambridge S30 speakers and I am not sure which Amplifier I need to run them. If you can educate me in this thread that would be great on what kind of amplifier I need and what I need to look for to make sure it can power the two speakers. I would also want a subwoofer. I will be using my Creative Sound Blaster ZxR as the DAC.
I mostly listen to acoustic/alternative music and watch movies on Netflix and television shows on Hulu beside playing video games.
Someone recommended the Jolida FX 10 which I looked into but I am not sure.
I am also looking at the Mordaunt-Short Aviano 2 speakers if anyone has an opinion.
Edit: Sorry I didn't put a budge! $500
UnNamedPerson is offline
post #2 of 11 Old 04-05-2013, 08:14 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Is that a budget for the avr/amp only? Or including the sub? I don't see any choices here except the silly looking expensive Jolida thing...10 wpc? That's your only choice so far? You might look at receivers at accessories4less.com to stretch your $. Cambridge specs the speakers at 4-8 ohm nominal impedance and recommends 100wpc (max).
I have S30s in my bar setup, they're nice speakers, I use some older equipment I already had, check my sig.
For a sub I'd look at the Klipsch RW12d on sale this weekend for $280 delivered at newegg.com.
lovinthehd is offline
post #3 of 11 Old 04-05-2013, 08:16 PM - Thread Starter
$500 just for the amplifier itself, that is the only amplifier someone recommended but there has to be a lot more choices right?
post #4 of 11 Old 04-05-2013, 08:45 PM
lovinthehd's Avatar
Liked: 4775
There are tons of choices. Integrated amps tend to be more expensive because it's such a small niche, avr's are a better deal generally; tube amps aren't even on my radar. Find a suitable avr for bang for the buck (and more capabilities for other applications). Most avrs will come with a suitable DAC as well. IMHO. YMMV.
UnNamedPerson likes this.
post #5 of 11 Old 04-05-2013, 09:06 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
what about a $100 Audiosource
lespurgeon is offline
post #6 of 11 Old 04-05-2013, 09:29 PM - Thread Starter
I'm trying to get the best sound I possibly can that is why I just want to buy a separate Amplifier and eventually pick up a nice DAC to add to my 2.1 CH setup. When I read articles it looks like a completely different language because I don't know what the graphs are actually comparing.
I'm trying to learn but it's a bit difficult jumping into an entirely different technology.
post #7 of 11 Old 04-05-2013, 09:31 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3076
An AVR would provide bass management which is important since you plan to use a subwoofer. Integrated amps sometimes have subwoofer inputs but usually no bass management. There are a few integrated amps that do but they are not within a $500 budget (Outlaw RR2150, $699). The Denon 1713 is $449 and features Audyssey MultEQ XT. The current Yamaha receivers are on sale to make way for the new models. For example, the Yamaha RX-V673 is currently $375 on Amazon.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #8 of 11 Old 04-05-2013, 09:45 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you can spend $500 for a receiver or amp you'll be perfectly fine and will have lots of choices.
If you're planning to expand your speaker setup one day then get a AV receiver.
All of these are available for under $500 and will work fine with your Cambridge speakers.
Yamaha RX-V673, $357
http://www.amazon.com/Yamaha-RX-V673-7-2-Channel-Network-Receiver/dp/B007JF85WE/ref=sr_1_1?ie=UTF8&qid=1365219148&sr=8-1&keywords=yamaha+rx-v673
Denon AVR 1913, $399
http://www.crutchfield.com/p_033AV1913/Denon-AVR-1913.html?tp=179
Pioneer SC-1222, $499
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117412
You could also go cheaper on the receiver and use $280 for the Klipsch RW-12d subwoofer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
Then spend $220 or so on a less expensive receiver.
Yamaha RX-V373, $177
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115373
Denon AVR 1613, $220
http://www.accessories4less.com/make-a-store/item/DENAVR1613/DENON-AVR-1613-5.1ch-Networking-Receiver-w/AirPlay-3D-ready/1.html
If you live near a Fry's Electronics store they have great deals the Harman Kardon AVR 1565 and 1650 plus Yamaha RX-V373, 473 and 573.
Afro GT
afrogt is online now
post #9 of 11 Old 04-05-2013, 09:57 PM - Thread Starter
Thank you very much for the responses and great information glad I came to this forum today. Felt limited with the forum I was on and was close to purchasing a 2 CH Jolida FX-10 biggrin.gif is that Klipsch RW12d that great of a deal right now? I feel like if I pass it up I might miss out.
post #10 of 11 Old 04-05-2013, 10:08 PM
afrogt's Avatar
Liked: 755
It has NEVER been lower than $279. Get it!
Afro GT
post #11 of 11 Old 04-05-2013, 11:27 PM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
Costco pioneer top of the line 1522k for 599.
datranz is offline
