How bad of an idea is this setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 04-07-2013, 07:24 AM - Thread Starter
jugger's Avatar
Liked: 55
Will having the receiver setting directly on top of the sub potentially vibrate solder joints loose inside the receiver?
RC-64 Center, RF-7 Fronts, RF-82 Sides, RW-12D, QTY=2, RSW-15, RS-52ii Rears, Pioneer SC-1522-K, Panasonic 65VT60, 65"
jugger is offline
post #2 of 20 Old 04-07-2013, 07:29 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
jdsmoothie is offline
post #3 of 20 Old 04-07-2013, 07:37 AM
nodnerb's Avatar
Its a very bad thing. What about heat dispersion? That thing is going to cook in there.
nodnerb is offline
post #4 of 20 Old 04-07-2013, 08:13 AM - Thread Starter
jugger's Avatar
Liked: 55
Here is the backside of the unit. It's in a closet in a basement that stays cool. Is heat still a concern? This is my first time going down the home theater road; so I openly admit my experience is limited.
jugger is offline
post #5 of 20 Old 04-07-2013, 08:37 AM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
With that open area in the rear, I'm sure heat won't be too terrible, but there's no way I'd want my receiver sitting on top of the sub, being constantly, shook and vibrated.
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
post #6 of 20 Old 04-07-2013, 08:40 AM
nodnerb's Avatar
Yeah, with the back open like that the heat shouldnt be a problem. I assumed it was closed off. But still, putting it on the sub isnt a great by any means.
nodnerb is offline
post #7 of 20 Old 04-07-2013, 11:46 AM
vzphoneman's Avatar
Quoted: 82 Post(s)
Liked: 78
I would try to rig up a shelve that would be above the sub for the receiver to sit on. Maybe you could have it attached, hanging down, to the sloped ceiling in the closet
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
post #8 of 20 Old 04-07-2013, 01:11 PM
jdsmoothie's Avatar
Liked: 5502
If you haven't already, suggest you do a "Sub crawl" to determine if there is a more ideal location for the sub.
http://www.youtube.com/watch?v=AV3oLLMgS-M
If you determine it's better placed elsewhere than use the current "hole" for a shelving setup of multiple components in addition to the AVR to possibly include a BDP and/or cable/sat box.
post #9 of 20 Old 04-07-2013, 02:47 PM
weez82's Avatar
If anything rattles lose then you have faulty equipment. Having your receiver on top of your sub is no different then putting it on a shelf next to it.
weez82 is offline
post #10 of 20 Old 04-08-2013, 09:37 AM - Thread Starter
jugger's Avatar
Liked: 55
Thanks for the info. I went ahead and hung it from the slopped ceiling and now there is very little vibration as compared to before when it was resting on the sub.
jugger is offline
post #11 of 20 Old 04-08-2013, 11:17 AM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
Really? You don't think having a receiver directly on top of a sub could create a problem quicker than it just being near the sub? You'd call the receiver faulty if something inside of it broke loose after a few months of sitting directly atop a sub? Really?
post #12 of 20 Old 04-09-2013, 03:02 PM
weez82's Avatar
Do you have any evidence to back up the claim that having a receiver on the sub is as bad as you say? Or is it just opinion? I've had my receiver on my sub for long enough to know it's more than safe. And I've known a few others that have the same experience.
weez82 is offline
post #13 of 20 Old 04-09-2013, 05:32 PM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
No, I have no evidence. However, common sense would say, having a sensitive electronic device with tons of small circuit boards, capacitors, glass fuses, and other circuitry inside of it, sitting on top of a sub, constantly slamming out heavy vibrations, certainly can't be the best idea in the world. You could store a stack of dishes on top of your sub too or some glassware... Would it break or damage anything? I don't know... maybe not... but does it seem like a good idea? Again... I don't know...
post #14 of 20 Old 04-09-2013, 06:55 PM - Thread Starter
jugger's Avatar
Liked: 55
I'm not trying to take sides but here was my biased reasoning or excuse for doing what I did originally. I was hoping the receiver would be designed to take a certain amount of vibration since it was designed to have two large subs within a certain distance. I'm guessing the receiver is CE certified which sometimes on some level is subjected to a vibration test. Also, I was hoping since the sub has an amp and LED display with circuitry the circuitry in the receiver would be fine. Who knows if the receiver is designed to handle the same vibrations but a simple move proved to decrease the vibration dramatically.
jugger is offline
post #15 of 20 Old 04-09-2013, 10:12 PM
weez82's Avatar
If receivers where that fragile they wouldnt make it to the store or to your door. The only bad thing about having a receiver on top of the sub is it looks tacky.
weez82 is offline
post #16 of 20 Old 04-10-2013, 12:21 AM
CalebLevArn's Avatar
You should relocate the sub to a corner of the room and build a custom AV stand for the hole in the wall.
CalebLevArn is offline
post #17 of 20 Old 04-10-2013, 12:40 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Just out of curiosity, how much more intense are the vibrations an avr may receive with it being placed on top of a sub vs. on a shelf about 2 feet from a sub (as is in the case of my set up)?
I would think that the receiver would be fine atop the sub, though I have never needed to place mine there. The only way i think it might be harmful is if you have a lighter weight sub on a wooden floor that likes to dance around when pumping out the low notes. The receiver could then be sufficiently jarred affecting its performance or longevity.
In my room listening to bass intense content at higher spl levels i can feel a certain amount of vibrations pretty much affecting every thing in the room, from the sofa, to the walls, to the lamp, to the pictures hanging on the walls (been known to knock a few off here and there) to the tv and audio stand etc. FWIW, my room isn't treated (yet) so the level of vibrations affecting everything in the room may be exaggerated to some extent.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #18 of 20 Old 04-10-2013, 06:43 AM - Thread Starter
jugger's Avatar
Liked: 55
Thanks for the picture, that is nice work. That was exactly what that hole was put there for but until I can afford a wireless sub attachment, that's its home. It helps hide the wires and keeps the kids out of them.
jugger is offline
post #19 of 20 Old 04-10-2013, 06:59 AM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
You're correct, would the receiver be OK? Maybe, probably. I just don't see how anyone could think it's an ideal spot, with all the vibrating and rattling. A few feet away is one thing, but right on top of it? Just don't seem ideal to me.
post #20 of 20 Old 04-10-2013, 07:12 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Whether any of it matters depends on the sub and how you use it.
My DVR is currently sitting on top of my sub and has been there for about 6 months. The worst thing about it is that it rattles when I run some of my bass test tones.
arnyk is offline
