Denon AVR-1713 Grayed Out Options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-07-2013, 08:58 PM - Thread Starter
Hawnted's Avatar
Does anyone know why in certain situations the "Dialogue Level" option is grayed out in the Audio menu? Specifically, I am noticing it when using a Roku and it is sending a STEREO signal.
When using a PS3 it seems to not be grayed out. I can usually access it on a Dolby Digital Signal when watching OTA TV as well.
Hawnted is offline
post #2 of 3 Old 04-08-2013, 05:57 AM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
Dialog level is actually varying the sound level coming out of the front center speaker. If the receiver is sending sound only to the front left and right speakers, there's nothing that can be varied, so the option is greyed out. If you enable Dolby ProLogic or DTS Neo surround sound processing for your Roku connection, then the Dialog level option should become available. The sound processing setting is remembered separately for each of the inputs on the receiver, so it probably is on for your PS3 when it sends stereo, but off for the Roku. When the receiver gets a multichannel audio signal, that includes a center channel, so the option becomes available.
Selden
Selden Ball is offline
post #3 of 3 Old 04-08-2013, 05:25 PM
jdsmoothie's Avatar
Quoted: 12082 Post(s)
Liked: 5502
For more helpful information on your new 1713, review posts #3-6 in the 2012 Denon AVR-XX13 thread linked in my sig.
jdsmoothie is online now
