Hot Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-08-2013, 11:19 AM - Thread Starter
zebby's Avatar
I have my Blu Ray, two direct TV boxes on top of my Onkyo amp. There is some clearance, but I feel it's not enough.
These components are in a clost that is roughly 8 feet high by 4 feet wide.
There is a shelf the amp sits on and everything else sits on top of that.
Are there any stackable type racks, wires shelves or anything I could possibly purchase so I can gain more clearance above the amp.
I currently have a fan attempting to blow the air out, I keep the closet door open.
Also, looking for a good cooling fan, pad or whatever to place on top of amp.
However, I'm more concerned about creating space between my amp and blu ray and direct tv boxes.
zebby is offline
post #2 of 7 Old 04-08-2013, 12:24 PM
HFXguy's Avatar
You should NEVER have anything on an amp/receiver.
HFXguy is offline
post #3 of 7 Old 04-08-2013, 02:47 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
There are many different types of shelving and racks for mounting home entertainment equipment. People with many devices (amps, processors, players, etc) often use industrial 19-inch "relay racks". Some examples are shown in http://www.avsforum.com/t/788074/show-me-your-rack/1530
You might consider visiting a local audio-video store to see what's available.
Check your receiver's manual, but usually 6-8" inches of clearance is required on all sides. If you can't provide that much, a fan will be required.
Selden
Selden Ball is offline
post #4 of 7 Old 04-08-2013, 03:21 PM - Thread Starter
zebby's Avatar
How about if I just build one level if shelving out of mdf and raising it the required clearance per the owners manual
zebby is offline
post #5 of 7 Old 04-08-2013, 04:59 PM - Thread Starter
zebby's Avatar
I didn't even think about this, but I could put the blu ray on the bottom, build a stable rack and then have the amps it on top, would have almost unlimited heigth above the amp.
zebby is offline
post #6 of 7 Old 04-09-2013, 01:29 PM
Liked: 1494
That sounds like it should work very well!
Selden
post #7 of 7 Old 04-09-2013, 01:49 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I've used wood strips - something like 2 x 2 lumber for that purpose. I have a table saw and just cut stock to suit.
In the end you should restack your components with the hot one on top.
arnyk is offline
