Denon 4310CI - OPPO 83 - SACD help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-08-2013, 04:51 PM - Thread Starter
wlcohen's Avatar
When I used to play SACD's in the oppo, the display on the denon would show SACD
Now it shows multi in
What changed in my settings?
Connection is via hdmi
wlcohen is offline
post #2 of 12 Old 04-08-2013, 04:56 PM
jdsmoothie's Avatar
Quoted: 12306 Post(s)
Liked: 5612
The AVR should display either "DSD Direct" or "DSD Multi Direct" if the Oppo is bitstreaming the audio to the AVR to decode, or it will display "Mult CH IN" when the Oppo is decoding it. A setting likely got changed in the Oppo. smile.gif
jdsmoothie is offline
post #3 of 12 Old 04-08-2013, 05:02 PM - Thread Starter
wlcohen's Avatar
I remember the denon displaying SACD in the past
wlcohen is offline
post #4 of 12 Old 04-08-2013, 05:08 PM
Splicer010's Avatar
Liked: 39
Splicer010 is offline
post #5 of 12 Old 04-08-2013, 05:14 PM - Thread Starter
wlcohen's Avatar
Thanks but
I am not that much of an idiot
wlcohen is offline
post #6 of 12 Old 04-08-2013, 07:22 PM
Kilian.ca's Avatar
Liked: 37
You just remember it wrong. It's all clearly set out in the Manual p.72.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #7 of 12 Old 04-08-2013, 09:37 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Yep. Maybe he's remembering it saying DSD DIRECT?
Sam S is offline
post #8 of 12 Old 04-09-2013, 04:32 AM - Thread Starter
wlcohen's Avatar
It's possible I am remembering it wrong, it's been some time since I listened to an SACD
I was sure that SACD came up and not multi
wlcohen is offline
post #9 of 12 Old 04-09-2013, 11:46 AM
Bill Mac's Avatar
Quoted: 1276 Post(s)
Liked: 1467
I have the 4311 and have played many SACDs with it. I've never seen "SACD" displayed on the 4311's display. I see DSD Direct or DSD Multi Direct if my 103 is set to DSD. If my 103 is set to PCM then I see Stereo/Direct or MultiCH on the 4311's display. I would say your memory is playing tricks on you wink.gif.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #10 of 12 Old 04-09-2013, 11:53 AM - Thread Starter
wlcohen's Avatar
Thanks Bill!
What is the preferred out put on the oppo - DSD?
wlcohen is offline
post #11 of 12 Old 04-09-2013, 04:47 PM
Bill Mac's Avatar
Liked: 1467
Originally Posted by wlcohen View Post
Thanks Bill!
To be honest I bounce back and forth between DSD and PCM. I was convinced that I could not hear a difference between DSD and PCM but at times I use the DSD setting. I only use DSD for stereo SACDs as no bass management is needed. When listening to multichannel SACDs I use PCM then the 4311 does bass management and Audyssey as well. So I would suggest trying both the DSD and PCM settings to see which you prefer.
Bill
Bill Mac is offline
post #12 of 12 Old 04-09-2013, 08:15 PM
Kilian.ca's Avatar
Liked: 37
Is the Denon 4310 even capable of direct DSD to analogue decoding?
If yes, you forego BM and EQ as Bill said and you'd need all 'large' speakers. OK for 2.0.
If no, then does it downsample PCM?
Does it do BM correctly?
