Can someone explain this to me as if I'm a 2 year old - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-10-2013, 08:04 AM - Thread Starter
stamina1914's Avatar
Quoted: 106 Post(s)
What does 192 MHZ 24bit mean. It is advertised on the top my pio receiver. Is there a better ratio out there? If so, should I want it?
stamina1914 is offline
post #2 of 9 Old 04-10-2013, 08:17 AM
hakstone's Avatar
Don't be so lazy, do some research.
hakstone is offline
post #3 of 9 Old 04-10-2013, 02:54 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
It should be 192 kHz, not MHz. Nonetheless, here's a pointer for you to get started. May not be written for a 2 year old, but a 3-4 year old at least! Just kidding! smile.gif
mogorf is online now
post #4 of 9 Old 04-10-2013, 06:46 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
wvu80 is offline
post #5 of 9 Old 04-10-2013, 08:48 PM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
Originally Posted by wvu80 View Post
+1!
old corps is offline
post #6 of 9 Old 04-11-2013, 12:30 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
For a 2-year-old.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #7 of 9 Old 04-11-2013, 02:50 AM
Kilian.ca's Avatar
Liked: 37
No need to be so hard or sarcastic to the OP. If everybody bothers to search Google, read wiki and product manuals >90% of forum postings just wouldn't be necessary!eek.gif
The short answer is, pretty all audio equipment has 24/192 DACs. Japanese mass market products like to put these specs and logos on the front for marketing, to impress the ordinary folk. 24-bit gives 144dB dynamic range, 192kHz sample rate gives 96kHz audio, more than sufficient.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #8 of 9 Old 04-11-2013, 07:59 AM
Michael Sargent's Avatar
Quoted: 179 Post(s)
Liked: 164
And as a two year old, he still may be able to hear something better than 44.1 kHz, 16-bit CD audio. For the rest of us, your ears are so warn out with live rock concerts, headphone MP3's, internal combustion engines without mufflers, and power tools that by the age of 18 normal CD resolution is much better than you will ever hear.
Michael Sargent is offline
post #9 of 9 Old 04-11-2013, 08:55 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Just to elaborate on a couple of digital basics
The sample rate (192KHz) controls the highest frequency that the digital system can "see" and encode. The theory and practice say that if you have 2 samples per cycle, you can accurately represent the frequency. At 192 KHz, then, the system could encode up to 96 KHz sounds. The standard, seminormal expression of human hearing extends to 20 KHz, so the 192 KHz system can encode a little over two octaves that humans will never hear.
As a corrolary, if you feed a digital encoding system a signal with higher frequency than it can handle (say 25 KHz into a 44.2 KHz analog-to-digital converter), ugliness happens, because the system never sees the "whole" 25 KHz wave. It will ineterpret what it can see and spit out some likely completely unrelated lower frequency that's fairly sure to be within the human hearing range, and very likely to be dissonant. So they have to filter out the frequencies that are higher than the digital system can handle before the signal gets to the analog-to-digital converter. It is often said that in early digital, that "brickwall" filter actually was a major source of less-than-pristine sound. Generally much better now.
The bit depth (16, 24 or 32 bits) controls the (digital") dynamic range - - the difference between the loudest and the quietest sound the system can encode. As indicated above deeper bit depth can exceed 100 dB dynamic range. But most of the analog steps that follow conversion the digital to audio have, at the very best, around 100 dB or so of dynamic range above their noise floors. So arguably the extra dynamic range is "wasted" because our systems can't reproduce the quiet end of the scale (assumming they can reproduce the loud end without distortion, compression etc (especially from teh speakers).
JHAz is offline
