Denon AVR-1612 any Alternative to Airplay? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-10-2013, 03:01 PM - Thread Starter
SimonB27's Avatar
Hi,
I have a Denon AVR-1612. Since it's not "Airplay ready", is there any other easy and cheap options to control my itunes library (stored on my PC) remotely using an iphone or ipad for the music to play via the receiver?
In other words, PC is in a different room. Receiver is in the leaving room, connected to TV, cable, PS3 and 5.1 speakers. I would like to play itunes library via the receiver in the leaving room.
As you can see, I dont have much knowledge in audio...
Simon
SimonB27 is offline
post #2 of 4 Old 04-10-2013, 03:06 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Airport Express
http://www.apple.com/airportexpress/
These refurbs are a good deal although they are the prior model:
http://store.apple.com/us/product/FB321LL/A/refurbished-airport-express-base-station-with-80211n-and-airtunes
You could also check craigslist to see if you can buy one locally.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
post #3 of 4 Old 04-10-2013, 04:34 PM
jdsmoothie's Avatar
Quoted: 12152 Post(s)
Liked: 5534
Also consider an Apple TV as well.
jdsmoothie is online now
post #4 of 4 Old 04-12-2013, 12:26 PM - Thread Starter
SimonB27's Avatar
Thanks! This seems perfect for my needs.
SimonB27 is offline
Denon Avr 1612 Receiver
