Denon 4520ci remote control RC-1165 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-10-2013, 03:43 PM - Thread Starter
Neil 4576's Avatar
Is anyone having issues with this remote?
My remotes light turns on from the slightest vibration i.e placing a cup on the table.
The remote was fully programmed but when the batteries died all programming was deleted.
After installing new batteries and trying to program the remote it will not do anything.
As an example when i try to program the Cab/Sat button to operate my Cisco PVR all is going well until i try to input the 5 digit code at which point the display switches to AVR and the remote exits programming mode. I tried to reset the remote to no avail even tried inputting the AVR code but nothing works.
Neil 4576 is offline
post #2 of 5 Old 04-10-2013, 03:53 PM
jdsmoothie's Avatar
Quoted: 15096 Post(s)
Liked: 7286
If you are following the directions on p. 157 in the Owner's manual, then try the reset procedure listed on p. 164. Also note there is a dedicated thread just for Denon 4520CI Owner's for more helpful information as well.
http://www.avsforum.com/t/1430049/the-official-denon-avr-4520ci-thread/0_100
jdsmoothie is online now
post #3 of 5 Old 04-10-2013, 04:04 PM - Thread Starter
Neil 4576's Avatar
Thanks I thought I was posting to the 4520ci forum anyway I have tried exactly what the manual says but the remote just won't do what it's supposed to. I have removed the batteries in hopes the memory is not static and will be erased. It's the second remote as the original was D.O.A I purchased it from Bay Bloor Radio who confirmed the original was "dead". The replacement worked fine until the batteries died (as a result of the backlight constantly turning on) now it just won't let me program device buttons however the Macros programmed without issue using Auto Macro. I have several URC remotes but don't want the kids using those. This unit replaced my Pioneer SC 07 and I really like it but need the remote to function properly because I paid for it. Thanks again BTW this is my first time posting anything online so please excuse my ignorance as to site navigation. Neil
post #4 of 5 Old 05-12-2016, 09:41 PM
dangdude's Avatar
I am having trouble transmitting. Yes, the backlight turns on when the volume is too high. However, now it doesn't transmit anything. The red "transmit" light does not illuminate for anything--even going into Setup mode (the Transmit light should blink 3 times but doesn't). There is no interaction between the remote and avr4520ci.
I am 2 weeks out of warranty, and have used this remote maybe 10 times (I generally use Harmonies). I have tried new batteries, and measured voltage to verify freshness. I've "reset all" via the owner's manual and verified both receiver and remote are on ID 1. I've done silly things like press every key with the batteries out to "drain residual charge" or maybe unstick contact bubbles.
This happened once before, but it suddenly started working after some fiddling and I figured I just wasn't smart enough to know why it stopped. Now after a few days I'm pretty sure it's just broke. Not happy, don't wanna spend $$$ on another remote. Any help appreciated.
dangdude is offline
post #5 of 5 Old 05-13-2016, 03:29 AM
jdsmoothie's Avatar
Liked: 7286
Although the AVR itself has a 3 year warranty, the remote only a 90 day warranty; however, I would still give Denon a call to see if they might have an old remote laying around. If no joy, and you purchased with a credit card, check with the card issuer and they may cover the replacement.
Denon Avr 4520ci Receiver
