Experience with One Call - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-12-2013, 03:27 PM - Thread Starter
06GTOguy's Avatar
Has anyone had any buying experience with One Call? I am in negotiations with them on a Denon avr but would like some feedback.
06GTOguy is offline
post #2 of 6 Old 04-12-2013, 05:54 PM
jdsmoothie's Avatar
Quoted: 15354 Post(s)
Liked: 7508
One Call is just one of many "authorized" Denon resellers that members have posted of using. Don't recall anything negative said about them although you may want to "call" Electronics Expo and avscience.com to see if you can get a lower price.
jdsmoothie is offline
post #3 of 6 Old 04-12-2013, 06:26 PM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
Last thing I bought from them was my HDTV back in 2007. One Call typically only gives a 10-20% discount depending on the list price.
Depending on the Denon AVR, you might be better off just trying to work out a deal with a local shop. You can also go with Accessories4less if you don't care about it being refurbished but make sure you add a 3rd party extended warranty to your purchase. Checking EE and AVScience is a good suggestion as well. Might as well shop around. biggrin.gif
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #4 of 6 Old 04-12-2013, 07:24 PM
M Code's Avatar
Quoted: 814 Post(s)
Liked: 498
One Call is a good dealer we have dealt with them. i would avoid Elctronics Expo as they just filed bankruptcy.
Just my $0.02... 👍😉
M Code is online now
post #5 of 6 Old 04-13-2013, 12:32 AM - Thread Starter
06GTOguy's Avatar
This is for a 4311, there isn't very many of these left. They have given me the lowest price so far and I will probably pick one up today from them.
06GTOguy is offline
post #6 of 6 Old 04-13-2013, 11:43 AM - Thread Starter
06GTOguy's Avatar
Well I just ordered it!! 1329 shipped. Not a bad price I thought. Now I have to wait a week for it.... It will be worth it for the XT32. Now I can get some decent room correction for my PB 12 Plus. Can't wait!!
06GTOguy is offline
