Onkyo 818 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-14-2013, 08:04 PM - Thread Starter
rafa1478's Avatar
I'm very new to this but I want to slowly build my sound system. I have an old Panasonic dvd home theatre system with 5 small speakers and I want to know if I can hook them up to the Onkyo as it may be a while before I can invest on some good ones. The back of the speakers say 110W music - 6ohm (front & centre) and 60W Music - 6ohm (surround speakers)
I won't expect much from this set up but I just need to know it won't harm the receiver in any way.
rafa1478 is offline
post #2 of 10 Old 04-15-2013, 10:43 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
I don't know why not, and if you have any money to do the upgrade check out accessories4less.com they have a lot of Onkyo products, several 7.1 sparker system that would work well with what you have.
Phil17108 is offline
post #3 of 10 Old 04-17-2013, 03:40 PM - Thread Starter
rafa1478's Avatar
Code:
Thank you
rafa1478 is offline
post #4 of 10 Old 04-17-2013, 03:45 PM - Thread Starter
rafa1478's Avatar
I have another question...
What should I set my subwoofer phase and crossover at?
There is the option to set the crossover between 40 & 160Hz and the phase @ between 0° & 180°
rafa1478 is offline
post #5 of 10 Old 04-17-2013, 05:48 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Set the sub to the highest set point and run the Audyssey set up. as for the phase try both ways and pick what sounds right to you. I assume that you have a sub but the first post did not state that.
post #6 of 10 Old 04-17-2013, 08:25 PM - Thread Starter
rafa1478's Avatar
rafa1478 is offline
post #7 of 10 Old 04-17-2013, 08:28 PM - Thread Starter
rafa1478's Avatar
Thanks again for your help!
Yes I have a Sub, the settings I was talking about are on the actual Sub not on the receiver so I hope your answer had that in mind.
rafa1478 is offline
post #8 of 10 Old 04-17-2013, 11:54 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Yes, that is what I had in mind
post #9 of 10 Old 04-19-2013, 12:40 AM - Thread Starter
rafa1478's Avatar
rafa1478 is offline
post #10 of 10 Old 05-20-2013, 01:20 PM - Thread Starter
rafa1478's Avatar
Hi there,
My room is 15' x 13' and I'm really interested in the Klipsch RF82II speaker system. I'm wondering if this is too much for my room?
When I say "too much", I mean, will it sound bad?
rafa1478 is offline
