Need a 5ch Amplifier - Parasound Halo A52, Emotiva XPA-5, or something else? - AVS Forum | Home Theater Discussions And Reviews
Old 04-14-2013, 08:04 PM - Thread Starter
xirtam2005's Avatar
Quoted: 146 Post(s)
Liked: 24
I am looking for a solid 5 channel amplifier for a system that will be used both for home theater and music.
The systems consists of:
Marantz AV7005 Pre/Pro
Paradigm Signature S1 x 4 and C1 center
Paradigm Seismic 110 sub with PBK correction
Current Amplification:
Odyssey Audio Stratos (with cap upgrade) for front L/R and old Yamaha receiver to amp the center and surrounds that will be re-purposed.
I was originally considering a Parasound Halo A52, but I cannot seem to find it available on the audioadvisor website. Is it still available? I know the Halo A51 would be great, but I think that would be overkill for my system (as the speakers are crossed over at 80 Hz), and I don't want to spend $4.5k on an amp.
If the A52 is no longer available, I am considering the Emotiva XPA-5 as it is very affordable, but I'm concerned that would be a step down from my Odyssey Stratos. Is the Halo A52 still available, or is there another 5 channel amp you would recommend for $3k or less?
For sound preferences, I highly prefer a neutral minimally colored sound that picks up the details and transients, without being bright or warm - just as accurate as possible to the original recording.
The Odyssey Audio will be re-purposed in a different system.
xirtam2005 is offline
Old 04-14-2013, 08:45 PM
wes182's Avatar
Quoted: 51 Post(s)
Liked: 26
I bought an XPA5 from someone who went with the Halos. He said he did notice a difference. Don't know if it was several grand worth though. I also tried both the XPA5 and XPA2. I thought the XPA2 provided some more pop than the XPA5 which it should given the power difference. I have Studio 100s so keep that in mind.
You can always try out the XPA5 and see if you like it and then return.
wes182 is online now
Old 04-14-2013, 09:20 PM - Thread Starter
xirtam2005's Avatar
Quoted: 146 Post(s)
Liked: 24
Do you know which Halo he went with? I'm interested in the Halo A52, but I have no idea why the Audioadvisor.com website is not showing it anymore. I believe the A51 would be overkill and don't want to spend the $4.5k that it costs.
I'm almost certain the XPA5 would be good enough for HT, but I'm not so sure about music.
So my question is:
What is the best neutral (neither bright nor warm), and highly detailed and responsive 5 channel amp for $3k or less?
Old 04-14-2013, 10:51 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Outlaw 7500, amazing deal at $1600.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
Old 04-15-2013, 04:57 AM
wes182's Avatar
Quoted: 51 Post(s)
Liked: 26
I think he went with the A52.
Emotiva Xpa 5 5 Channel Power Amplifier
