Denon 2113ci streaming from PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-17-2013, 11:30 AM - Thread Starter
brian313313's Avatar
Hi Everyone. I'm new here and have a question I'm hoping someone can help me with. I have a new Denon 2113ci receiver. I can play music from my PC through the network setting but was wondering if there's any way to control the music from my PC? I would like to set up playlists in Windows Media Player and then run them through the Denon. I also want to play games through this. I know that I can set up an additional cable to one of the inputs that will handle both but if I can do it with one cable it will make the setup cleaner.
-Brian
brian313313 is offline
post #2 of 3 Old 04-17-2013, 05:10 PM
postrokfan's Avatar
Quoted: 521 Post(s)
Liked: 3109
It's pretty simple. All you need is an HDMI cable or optical cable (depending on what you have available with your PC) connection.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 3 Old 04-18-2013, 07:41 AM - Thread Starter
I have an optical cable. What I'm trying to do is use the network connection to avoid running two cables. Is that possible for games? I figured out that in WIndows Media Player I can right click on something and play it on the Denon. I can also save a playlist and then select it from the receiver. I can't see any way to do this other than Windows Media Player though which eliminates games.
Denon Avr 2113ci Receiver
