Emotiva amp connected to my Yamaha AVR, would this help any? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 60 Old 04-17-2013, 07:51 PM - Thread Starter
RKSKYDANCER's Avatar
Quoted: 73 Post(s)
Liked: 53
Question, Would connecting a Emotiva UPA-500 or 700 amp to my Yamaha RX-A820 receiver running a 5.1 speaker system have any improvement on sound quality or improve the level at what I can play music or movies? Or for that matter any 5 channel amp rated at 65 watts a channel or more with all channels driven. I see the UPA-500 is rated at 80 watts a channel x 5. I am sure this is more then what the Yamaha A820 is capable of. I read a lot about the Yamaha amps running thin with all channels driven causing mid bass to be weak.
Would the improvement be worth the extra $400.00 to $500.00 for the amp? I know it would look cool having a external amp sitting on the shelf above the receiver.
Living room; Samsung PN60F5300B Plasma TV, Marantz SR5008 AVR, Sony UHP-H1 UHD Blu-ray, Definitive Mytho 2's fronts-wall mounted, Definitive Pro Center 1000 speaker, Definitive Di 5.5R in ceiling for surrounds, RSL speedwoofer 10s , Comcast Xfinity HD DVR box.
Garage; Sherwood RX-4105 2 channel stereo receiver, Samsung DVD-C500 CD player, Klipsch KG 2.5 med Oak speakers
RKSKYDANCER is offline
post #2 of 60 Old 04-17-2013, 09:25 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Too many unknowns, including speaker sensitivity, listening level and position, etc.
Check out an SPL calculator like this one: http://myhometheater.homestead.com/splcalculator.html
Chances are you don't need it, cool or not...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 60 Old 04-18-2013, 03:16 AM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 745 Post(s)
Liked: 659
It would look cool but it might not solve the problem. A few things to keep in mind...
1. Are you having a mid bass issue now. If so are you using a subwoofer and have you checked where it's crossed over in relation to your speakers.
2. Has anything changed in your room such furniture placement, new drapes, new wall coverings. If it has have you re-run the room correction software in your Yamaha..
3. What type of music do you play, music can be way more demanding than movies. Large scale orchestral works for example can benefit from good clean power and having a good amount of reserve power.
If you like the way things sound but would like a bit more oomph than try more power. The Emotiva has 30 days to try it out to see it you like it. You might even want to go with one of their bigger amps.
"Oooh a puzzle box, I love puzzles"/ "Are you familiar with 'The Lament Configuration"/ "Actually I'm lousy at puzzles..."
tenthplanet is online now
post #4 of 60 Old 04-18-2013, 12:39 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I'm going to say that the Emotiva UPA series probably won't make a bit of difference since that Yamaha is probably good for 70 watts per channel x 5. It just won't give you the headroom you will need for those volume peaks. I essentially did them same thing but on a larger scale going from 141 watts x 7 to 200 watts x 5 plus 2 running off of AVR -- made no difference in sound quality or volume. I was also going from a 7 channel to 11 channel setup and still needed an external amp. I ended up stepping up to a 400 watts x 5 amp which gave me what I needed for a really strong 5.x setup with the AVR powering the rest of the system. I think the XPA-5 at 200 watts x 5 is probably what you should go with provided your speakers can handle the power. Put your best 5 speakers on the XPA-5 and let the Yamaha power the rest.
I can vouch for a nice, powerful amp when listening to classical, especially multi-channel classical music. I have some nice 5 and 7 channel recordings of Beethoven, Mozart, Holst, etc., etc. that really opened up when I added more power.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #5 of 60 Old 04-18-2013, 07:46 PM - Thread Starter
Quoted: 73 Post(s)
Liked: 53
Thanks for the response. First off I must say I am not one of those guys that needs 5 tower speakers with 2 15" 1000 watt subwoofer in a 15x15 size room to hear or enjoy movies or music. I like how my system sounds now "but" I was just thinking of getting some Amplifier dynamic headroom for certain music or movies as I find a lot of sources are not recorded or do they sound the same. My room is about 1600 sq. ft. with 8 ft. flat ceilings. Right now I am running the Cambridge Minx S325 v2 5.1 speaker system. They fill the room with good all around sound due to the Minx 21 BMR dual woofer speakers. They are very clean and detailed in there output. I have them mounted on the walls as per THX recommendations. Right now with my receiver volume set at -13 db I am seeing about 84 to 85db on a sound level meter in the seating area. As you can see there is plenty of volume left on the receiver to turn it up but i would be concern that it wouldn't be clean power. I have run the YPAO with very good results. All speakers were set close to 0 db on the levels. variable only by 1 or 2 db's up or down from 0. According to Cambridge the speaker sensitivity is 87db with a power rating of 15-200 watts. It's a 5.1 system so I am using a subwoofer with the AVR crossover set at 120 and the subwoofer level in the Yamaha set at +2 which works out fine. No changes in the room. Again, I like the overall sound of the system but i was thinking a separate amp would have that added headroom for those certain dynamic times in the music or movies. I also might get some good bookshelf speakers in the future for 2.1 music listening. Cambridge has a note in the Minx speaker page that says:-
" Using a high power amp lower down it's volume scale results in lower distortion and better sound"
post #6 of 60 Old 04-18-2013, 08:55 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Looking at what your speakers can handle and their sensitivity I definitely say at least XPA-5. You would probably have your AVR set at -20 dB to get that same 84-85 dB at listening position. I can crack test tones at 105dB at my LP at 0dB, so I'm usually set at -30dB when watching TV and -20dB for movies.
No need to do anything if you are happy with sound quality and output. If you want more then get the XPA-5 or something with similar specs. Outlaw makes a nice 200 watt x 5 amp and they also have a 200 watt x 7 amp as well. I just ended up getting a fantastic deal at their trade show ( EmoFest ) on an Emotiva XPR-5 ( 400 watt x 5 ) and went with that instead of the Outlaw 7900. Really wanted a 7-channel amp in one box. but I can probably pick up an XPR-2 at the next EmoFest.
Emotiva also has a Summer Sale around Independence Day and you'll usually see $100 to $150 off the XPA-5.
jevans64 is offline
post #7 of 60 Old 04-18-2013, 08:56 PM
Quoted: 745 Post(s)
Liked: 659
Thanks for getting back to us with all the details. I second the idea of trying the bigger amp that jevans spoke of above, it couldn't hurt.
post #8 of 60 Old 04-18-2013, 10:31 PM
deltadube's Avatar
Liked: 36
an external amp is exactly what you want... xpa 5 it will knock you soxs off just like jeans say xpa 5 or other options... depending your funds for audio..
music dynamics, tighter bass bigger sound stage etc ... only few more dollars over the upa.. i added the xpa 3 wow amazing.. over my denon...
cheers..
deltadube is offline
post #9 of 60 Old 04-18-2013, 10:36 PM
deltadube's Avatar
Liked: 36
is that the denon 4311 ci 7 x 141... it is not!
its for 2 channels... only... the power rating with all 7 channel i bet is around 90 wpc..
denon is very decptive like all other avrs...
my denon 3313ci is 125 wpc x 2 but in 5 is 83 and 7 78 wpc.. at 8 ohm..
xpa is 200 wpc all channels driven all the time at 8 ohm and 300 at 4 ohm plus a little undisclosed extra..
cheers..
post #10 of 60 Old 04-19-2013, 12:41 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
My AVR is an upgraded AVR-5308ci. I used the numbers from the HT Labs testing which put it at 207 watts x 2, 146 watts x 5, or 141 watts x 7, all into 8 Ohms with 0.1% THD.
That is why the XPA-5 didn't do much for my system since the anchor was a $5500 AVR. Luckily I knew someone that had an XPA-5 and I borrowed it. I heard about Emotiva here on these boards and didn't even realize their HQ was 60 miles from where I live. I then decided that I was going to add two speakers in back and also do front heights. I was thinking again about buying an XPA-5 since I needed 4 more channels of amplification but was looking at other options, like the ATI 3000/Outlaw 7900, Parasound Halo, D-Sonic M2, and Sunfire TG. Went to EmoFest and got a close look at the brand new XPR-5. Needless to say, I had a 110 pound passenger in my front seat ( only place the box would fit ) when I went home. I'm really only running a 9.x setup most of the time, but I still have a pair of speakers mounted up against the ceiling in the back corners of my room, which used to be my old 5.x surrounds. I will use them occasionally when in DSX or in one of the multi-channel "stereo" modes. They are just assigned as a 2nd pair of surrounds.
Dredd is probably best movie I have for DTS Neo.X 9.1 followed by Expendables 2. Skyfall just plain rumbles no matter how many speakers I use and the PQ is outstanding as well.
jevans64 is offline
post #11 of 60 Old 04-19-2013, 02:00 AM
deltadube's Avatar
Liked: 36
did you get a big discount at the emofest?
no xpr 1s looks like the ticket for you ..
cheers..
post #12 of 60 Old 04-19-2013, 03:29 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
cheers..
$1299 for refurbished and $1699 for new. Since the XPR-5 had only been out a few months the refurbs still had 4 years, 9 months left on the warranty. You get $50 EmoBucks for attending ( registration / attendance is free ) which can be applied to anything you buy there except the Area 51 stuff -- stuff that has been deeply-discounted and cash-and-carry.
I think I have enough power, for now. I only have a single 20 Amp circuit still available anyway. I guess two XPR-1 could run off of that and my left/right speakers can certainly handle the power. I do very little 2-channel listening and they would probably just go to waste.
I'm planning on a pair of Stealth 8 and a DC-1 for the next EmoFest. If I have extra cash, then I'll pick up a sub to go with that.
jevans64 is offline
post #13 of 60 Old 04-19-2013, 04:24 PM
deltadube's Avatar
Liked: 36
cheers..
xpr line is a bit older than that .. looks like the price they had a christmas time on the xpr 5 1699 300 off.. secret sale on this wknd...
nice amp .... i waiting for a US dollar visa to show up didnt make it today.. maybe monday.. that way i can do my own conversions of currencies..
sometimes US dollars just show up in my accounts like magic!
cheers..
post #14 of 60 Old 04-19-2013, 08:02 PM
DonH50's Avatar
Liked: 1325
What is the maximum setting? For reference, -13 dB is using 1/20 of the power at 0 dB. Also note adding an amp will often not change the volume setting; when you run the room compensation program it will reset the trim levels so 0 dB remains 0 dB whether the amp is in-line or not.
If you look at amplifier reviews you will find most of them are pretty flat with power, rising at the low end due to the noise floor, flat through most of the range, then a fairly sharp rise as maximum output is reached. Furthermore, the distortion the amp produces is several orders of magnitude below that of the speakers, at least until the amp is driven hard into clipping. The Cambridge statement is true for many amps but not relevant in the real world.
Look at a room SPL calculator program to see what power you might actually need, then you can make a more-informed decision. One example is at http://myhometheater.homestead.com/splcalculator.html
Wanderlust has cost many a pretty penny with nothing gained in the end...
DonH50 is offline
post #15 of 60 Old 04-20-2013, 01:40 AM
deltadube's Avatar
Liked: 36
wow thats alot of misinformation...
wow
over amp your speakers ... better sound quality no distortion.. lower amp power bad sound clipping and risk of burning out your tweeters or voice coils..
cause you turn it up to much one day...
also with music dynamics you need lots of head room.. the dynamic range of music can be large.. and the amp must delievery hugh amounts of power for a micro second.. which they do
other wise the amp clips and you get power sound at the peaks..
cheers
post #16 of 60 Old 04-20-2013, 04:21 AM
jproy13's Avatar
Liked: 26
you mean better sound quality because it's distortion free right?, or do you mean more power (or adding an amp) will equal in better sound quality?
jproy13 is offline
post #17 of 60 Old 04-20-2013, 12:40 PM
deltadube's Avatar
Liked: 36
distortion free on the dynamic peaks..
cheers..
post #18 of 60 Old 04-20-2013, 09:29 PM
DonH50's Avatar
Liked: 1325
Especially on those microsecond peaks, for those of us with MHz amplifier, speaker, and hearing bandwidth...
Sometimes it is not worth it to even try...
Enjoy.
jproy13 likes this.
DonH50 is offline
post #19 of 60 Old 04-21-2013, 08:18 PM - Thread Starter
Quoted: 73 Post(s)
Liked: 53
Thanks guys for all the opinions and information. My speakers have about 6 hours on them now so i re ran my YPAO with very good results plus did a few other tweaks on the my receiver which helped out even more. I adjusted the Volume trim and Subwoofer trim up to +3 from 0 ( default ) which really help out the mid bass and Dynamic's that i thought may have been a little weak because of the amp in the receiver. There is so many adjustments on these new AVR receivers that it sometimes takes weeks to get everything figure out. I am now seeing upwards of 89 db at the listening position with the receiver volume at -17. I still agree that a separate amp would be a good thing and help on those microsecond burst in dynamic's and help protect the speakers from damage. That was my thinking in the first place. Stronger amp with all channel driven, less volume needed, less distortion, cleaner sound, more reserve power for those microsecond peaks and dynamics, help save the speakers. The XPA 5 is to big to fit on my shelf plus more money then i wanted to spend. I was hoping that the UPA-500 with do some improvement but after seeing some of your thoughts it probably wouldn't be worth the extra expense. But with there return policy i might still try it just to see. I still think it would look cool sitting there on the shelf above the receiver. I was just hoping it would improve on the sound as well!
post #20 of 60 Old 04-23-2013, 01:54 AM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
By "Volume trim" do you mean the individual speaker trims? If you raised all speaker and subwoofer trims 3dB, you would have got the same result turning the master volume up 3dB. What you've got is effectively -14dB volume at an indicated -17dB master volume.
If your AVR can cleanly power your speakers at your desired maximum listening level, adding a separate amp will not produce a discernible improvement in sound quality. If your AVR is cleanly powering your speakers, you be at little risk of damaging them. DonH50 has given great advice above (despite the unsubstantiated opinions of an overenthusiastic amp devotee), and you should take note of that, including running your numbers through the SPL calculator he linked. By the way, as DonH50 hinted above, there really is no such thing as a microsecond burst or peak within the audio band. smile.gif
Looking cool is about all it will do if your AVR can cleanly power your speakers now. biggrin.gif You may be disappointed if you're looking for a "night & day" (or even a modest) improvement in sound quality from just by adding a separate amp.
jproy13 likes this.
GIEGAR is offline
post #21 of 60 Old 04-23-2013, 02:39 AM
jonfitch's Avatar
Well when you have an amp that can do an honest 140 W x 7 separates like an XPA-5 isn't going to do it for you, first of all XPA-5 only does 70W/Ch more, by that point its pretty negligible, you are getting what, 1.5db more? At that point you really need to look at using a couple of XPA-2 or XPA-1s.
jonfitch is offline
post #22 of 60 Old 04-23-2013, 07:05 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
"Using a high power amp lower down it's volume scale results in lower distortion and better sound"
Taken to it's logical conclusion that would imply that a 10,000 watt amp would sound better than a 100 watt amp even if you only needed 10 watts for peak power. I have to take exception to that. That simply cannot be true.
Which means the statement is questionable IMO.
Clearly, there has to be a point where more power does not improve sound quality. I can't prove this, but based on my studies of amplifiers, I can't come to any other conclusion.
"But this one goes up to 11"
MichaelJHuman is offline
post #23 of 60 Old 04-23-2013, 08:44 AM
DonH50's Avatar
Liked: 1325
There's also the noise floor to consider as you turn down the volume...
DonH50 is offline
post #24 of 60 Old 04-23-2013, 09:41 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
+1. FWIW, my rellatively loose experiments with a pair of Maggies (said to desire big power) indicated neither measurable nor audible increase in bass response (say from 40 to 60 Hz) at around 75-85 dB when powering with a 50 WPC amp or a 200 WPC amp.
While it's fair to speculate that generally THD+N will be lower at any given power output for the larger amp, it's not guaranteed. Some tweaky high end amps seem to have an odd THD increase relatively low in the power band that then goes away at higher powers until you hit the distortion curve "knee." Either that or abnormally high noise might make the more powerful amp less desireable.
And FWIW, there is a strong contingent of audiophiles who believe the pecise opposite of this myth. They think because (as is undoubtedly true) most of what we hear with typical systems in typical rooms is using a watt or less of power, the complexities and ganged output devices of more powerful amps must, perforce, mean those amps are less musical in that critical first 80 dB or so. So they want low power amps. Not talking about SET folks, but the people for whom even Musical Fidelity, long an high power advocate (simply to reproduce the brief but real peaks in non-dynamically restricted music) built an amp that was like 20 watts or something. Hey, if there's a market niche you might as well feed it.
JHAz is offline
post #25 of 60 Old 04-23-2013, 09:52 AM
Quoted: 266 Post(s)
Liked: 148
Still looking for that musical first watt. I thought I spotted it one day, under the couch, but it was an old rag. I will keep looking
post #26 of 60 Old 04-23-2013, 12:37 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Already bought the XPR-5, which is 400 watts x 5. At the time, I borrowed a friend's XPA-5 just to see if it would make a difference. I knew it probably wouldn't but tried anyway. I was also toying with the idea of adding more speakers after I had the upgrade done on my AVR and would need an external amp for the additional speakers anyway. I went to the Emotiva show planning on picking up an XPA-5 for the additional channels even though it didn't make a difference but got the bigger amp instead, which DID make a difference in the core 5.x setup.
jevans64 is offline
post #27 of 60 Old 04-23-2013, 12:41 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I usually look for it under the couch cushions but only end up finding a few crumbs and maybe some pocket change.
jevans64 is offline
post #28 of 60 Old 04-23-2013, 04:46 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
Absolutely, I mean just look at these two Onkyos. The cheaper one (1000 series) actually measures better than the more expensive one (5000 series) at lower volumes.
astrallite is offline
post #29 of 60 Old 04-24-2013, 01:10 AM
Quoted: 266 Post(s)
Liked: 148
I find it odd how the 1009 hardly has a flat line. Once it hits bottom it goes up at a linear rate until it starts limiting or clipping ( can't say which, but it seems like it works out the same way.)
I am more used to seeing curves like the 5008.
post #30 of 60 Old 04-24-2013, 02:53 AM
jonfitch's Avatar
I think you are probably just used to seeing Stereophile measurements, which doesn't have a linear scale, the first section of their graph is usually in milliwatts, and then the scale keeps shrinking as you move along like this one below of the HK 990:
The Onkyo 1009 isn't that odd looking at the Denon 3312, Yamaha RX-A2000, and RX-Z11 (I picked these randomly) all follow similar paths:
jonfitch is offline
Emotiva Upa 500 Five Channel Power Amplifier , Yamaha Rx A820 7 2 Channel Network Aventage Av Receiver , Emotiva Upa 700 Seven Channel Power Amplifier , Cambridge Audio Minx S325 V2 Home Cinema System , Emotiva Xpa 5 5 Channel Power Amplifier , Denon Avr 3313ci Receiver , Denon Avr 5308ci Receiver , Mitsubishi Hc7900dw Home Theater 3d Projector , Skyfall Blu Ray , The Expendables 2 Blu Ray
