Which is the Best Option? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 137 Old 04-22-2013, 05:35 AM
Bond 007's Avatar
Quoted: 2627 Post(s)
Liked: 2090
Originally Posted by RomanBlade86 View Post
Thanks for the tip. I just created the message.
yw I dont know why I didnt think of it sooner.
Licence to Kill
Bond 007 is offline
post #122 of 137 Old 04-22-2013, 05:45 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
There's just too much denial, misinformation and disagreement among people in this hobby that it's hard to decide who to believe.
What is there about the technical posts with facts and figures that keeps them from being more credible to you?
Sighted evaluation, which IME should be immediately consigned to the circular file.
arnyk is offline
post #123 of 137 Old 04-22-2013, 05:45 AM
darenwh's Avatar
I would suggest you take your speakers to a few high end HT stores and hook them up to a few different systems, both receivers and seperates, so you can hear exactly what the differences will be. This way you can purchase what sounds best to you. Of course, they still won't sound as good at home unless you get some audio treatments for the room but at least you will know what sounded best in the show room.
Darenwh
Just getting started. Hope to have some decent equipment within a year or two.
darenwh is offline
post #124 of 137 Old 04-22-2013, 05:48 AM - Thread Starter
RomanBlade86's Avatar
Mind expanding on the last part?
HDTV: Panasonic TC-P50ST50
Speakers: Bowers & Wilkins 685
Receiver: Sony STR-DA80ES
Blu-ray Player: Playstation 3
Power Center: Monster HDP 1800
RomanBlade86 is offline
post #125 of 137 Old 04-22-2013, 12:22 PM
deltadube's Avatar
Liked: 36
How does this compare with the Emotiva amp? Would I need to buy a pre-amp to go along with a monoblock amp? Would the cheapest one they have for sale be enough?
well ive never heard there products or used there services.. so i dont know...
i can recommend emo..
i would think with all the award on there site they make good products as well they are a bit more expensive than emo..
cheers..
deltadube is offline
post #126 of 137 Old 04-22-2013, 12:31 PM
deltadube's Avatar
Liked: 36
audio is very subjective Roman.. we all hear a lttle different.. perhaps why so many opinions eh..
separates and the ability to grow cant beat that to start out..
800 bucks you got great sound
ps that sale ends tuesday
cheers
post #127 of 137 Old 04-22-2013, 01:16 PM
gostillerz's Avatar
He can spend $500 less and get sound just as good. This is for a 2.0 bedroom setup with bookshelves. Going separates for this use is EXTREME overkill. I'm sure Delta, that even you know that electronics are on the lesser side of importance compared to room treatments and speakers. What are you going to say next, tell him to bi-amp?
Roman: The other guy a few posts up had a great idea about taking your speakers to a good store to demo some different setups. There are several people on here trying to help by giving options with different brands, features, etc, while explaining the reasons. There is also another poster on here who blindingly pushes one brand, and says things that well...make zero sense.
Another thing you can do is order the Emo setup, and either borrow or buy a receiver. Test them out and keep the one you prefer. Return shipping wouldn't cost much. Also, Emotiva has their summer sale around July with usually bigger discounts.
It's these cans! He hates these cans!
gostillerz is offline
post #128 of 137 Old 04-22-2013, 01:25 PM - Thread Starter
Thanks for the advice. I suppose the Emotiva equipment is overkill and I got a bit carried away. I have started to look at receivers again and currently looking at an older Sony ES receiver and also looking at some newer receivers as well. The problem I have is there are so many different receivers on the market that almost seem similar from companies like Yamaha, Onkyo and Denon. I want a receiver that's big and bulky so you know there's plenty of power under the hood.
post #129 of 137 Old 04-22-2013, 02:28 PM
gostillerz's Avatar
It's definite overkill. A general rule is to spend twice as much on speakers as you do on a receiver or preamp/amp. Speakers and more importantly, the room have much more influence on the final sound than a receiver. I learned the hard way.
There's just not a huge difference between receiver brands. Pick the one that has the features you need, at a price you can live with.
post #130 of 137 Old 04-22-2013, 03:13 PM - Thread Starter
I'm leaning towards the Harman Kardon HK 3490 at this point. I just wish it was under $300 new on Amazon like it was a couple of years ago. It did get some good reviews from what I've been reading.
How legitimate is the following site?:
http://www.audioholics.com/reviews/receivers/hk-3490
Also, here's a Youtube video of someone with the same speakers as mine using the Harman Kardon HK 3490 receiver. I know it may be hard to tell through video, but how good would you say the sound is using this receiver? What are indicators that a sound is good or bad? I'm no audiophile at this point so I'm asking in the same way as someone without car knowledge asking a mechanic whether their car sounds good:
http://www.youtube.com/watch?v=NFwJO097rI0
post #131 of 137 Old 04-22-2013, 03:25 PM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
RomanBlade86,
I have sent you a PM!
Glenn Baumann is offline
post #132 of 137 Old 04-22-2013, 03:39 PM
gostillerz's Avatar
Impossible to tell with YouTube. Audioholics is okay, but the best reviews you'll get are where there are a lot of user ones (like amazon), but pay more attention to the middle of the road ones, not the one or five stars to get an accurate idea.
My front speakers originally were something like $1000 each. They got discounted down to $300. The point is that they're still worth $1000 to me, regardless of the current market price. The H/K would be a good choice even if you can't get it as cheap as it once was. It was discontinued, people found out how good it was, and demand went up. That's just how it goes.
RomanBlade86 likes this.
post #133 of 137 Old 04-22-2013, 04:52 PM - Thread Starter
That's good to know that it was discontinued and most likely brought back because of demand but going by Amazon reviews this receiver is nearly four years old and I would think it would be cheaper. I'm surprised that this receiver received so many reviews from users and most of them positive. Amazon's pricing is strange. The receiver is $406 on Amazon but a couple of days ago it actually went down to $355 and then shot back up to $406. It's in my cart so I'm watching whether the price drops down again. I would much rather own a brand new item rather than refurbished unit that Harman is currently selling on eBay for $300.
post #134 of 137 Old 04-22-2013, 06:09 PM
gostillerz's Avatar
I'd prefer a direct factory refurb if it has a warranty. If you buy a new, discontinued model from other than an a "approved" dealer, many times, the manufacturer won't honor the original warranty. Like I said before. On an assembly line, maybe 1 or 100 or 1 of 500 get QC checked. A refurb is repaired to original specs and tested for everything. Note that open box and refurb is not the same thing. Email H/K to make sure everything is on the up and up so to speak. If it is, I'd go for the $300 unit.
post #135 of 137 Old 04-23-2013, 02:09 PM - Thread Starter
My main concern with the Harman Kardon 3490 is that there is no HDMI inputs and only an optical input. Will the sound suffer in movies and video games as a result? I want to get a receiver mostly for movies and video games and not music.
post #136 of 137 Old 04-25-2013, 08:48 AM
darenwh's Avatar
I'll say, for movies and video games, you sure are limiting yourself with a 2.1 system. Both of these media's are greatly enhanced with surround. FPS games are so much better as are many other games. Movies are so much more immersive with surround sound. Oh well, good luck on what ever you get.
Darenwh
darenwh is offline
post #137 of 137 Old 04-25-2013, 08:54 AM - Thread Starter
It's funny that someone on another forum just said the same thing and here was my response:
Well, to be honest, I'm not too big into the whole movie theater experience. A pair of solid speakers like the Bowers & Wilkins 685s will be more than enough for me personally. I have a relative that's into this whole thing and just recently spent $5K for only two speakers that look to be a bit over 6 feet tall. He also has speakers on his walls all around for the ultimate home theater experience. That's dedication for the home theater experience but frankly I'm not impressed with sound coming all around you. I prefer a good picture quality and good sound coming straight forward. I tested Robocop on Blu-ray using an old Sony receiver from 1997 obviously without HDMI and my B&W 685 speakers sounded great and I could hear the metal clanking with intensity and the sound was much more than I had hoped for. I can only imagine once I get something like the Onkyo 818 which has HDMI and Audyssey XT32 which should really make the sound shine and will be more than enough.
Onkyo Tx 8050 Network Stereo Receiver Black , Denon Avr 5803 Receiver , Onkyo Tx Nr809 , Onkyo Tx Nr818 , Denon Avr 4806 7 1 Audio Video Reference Receiver , Yamaha Rx A1020 7 2 Channel Network Aventage Av Receiver
