Denon DRA-395 to computer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-19-2013, 02:27 PM - Thread Starter
farbus14's Avatar
I have a Denon DRA-395 receiver. It is connected to a turntable and a tape deck. I want to connect the output to my computer in order to transfer my LPs and tapes to CD. I know that I need to send it into the microphone input on the computer. Which output jacks on the receiver will allow me to accomplish this?
farbus14 is offline
post #2 of 4 Old 04-19-2013, 03:10 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I'd probably use the CDR/Tape output, which is at the bottom of the ins/outs panel.
With the computer, you will need some type of software that records the mic input and saves the file to WAV. From there you can use something like Audacity ( free Windows software ) to edit and convert to CDA or burn to a CD. You can even use Audacity to record the audio then tweak it, get rid of pops, and then convert to whatever format you need. I would just convert to FLAC and burn those files to an archive CD, or better yet, a DVD-R or BD-R.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #3 of 4 Old 04-19-2013, 03:58 PM - Thread Starter
farbus14's Avatar
I made the connection. It works, but I get a very low input level on the recording software. I'm using Golden Records.
farbus14 is offline
post #4 of 4 Old 04-20-2013, 12:38 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Not familiar with Golden Records. I'd check your AVRs menu to see if it is possible to boost the gain on that output. You might also have to go into your computer's audio control panel and turn the gain all the way up.
jevans64 is offline
