Upgrading To A New Receiver And Need Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-20-2013, 03:13 PM - Thread Starter
Willyoung351's Avatar
I currently have an old cambridge audio azur540r reciever which has been great and the sound quality is outstanding ive found. However, I am looking to upgrade to a more powerful 5.1 receiver with at least 140w per channel as all my speakers are fairly large. I considered getting a 7.1 and bi amping the front speakers but is this really worth the extra cost?
I have found the denon AVR x1000 that comes out in may to be a very good looking unit at a very reasonable price. I would like the reciever to have multeq xt so this is why i am thinking this one. Any advice at all would be much appreciated my budget is 500 pounds.
Willyoung351 is offline
post #2 of 4 Old 04-21-2013, 12:49 PM - Thread Starter
Anyone?
post #3 of 4 Old 04-21-2013, 03:14 PM
jevans64's Avatar
Quoted: 194 Post(s)
Liked: 149
Not many receivers will be able to deliver that amount of power into five channels let alone two channels that would meet your budget. Denon's new "X" receivers are just rebrands of their existing xx13ci models. The power output will be the same but there might be a few more streaming apps and maybe a bump in room correction.
The power specs on Denon's AVRs have been poorly-stated for at least 5 years now. They are following the trend that HTiBs have been using for a while. I believe the X1000 is going to be equal, power wise, to the AVR-1913. Those ratings are 70 watts x 5 and 52 watts x 7 into 8 Ohms.
I'd look for something a little older, like a Denon AVR-3312ci/3313ci that also has the ability to add external amps. You will probably only get maybe 90 watts x 5 BUT you can add an external amp later on if you have the rack space.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #4 of 4 Old 04-21-2013, 03:23 PM
mogorf's Avatar
Quoted: 1117 Post(s)
Liked: 714
Hi,
Just a couple of questioons, if you don't mind:
1. Why are so power hungry?
2. What do you mean by "fairly large speakers"? Model no.?
3. What's the size of your room? Care to post a photo or two?
mogorf is online now
