connect wireless mic AVR-2313CI - AVS Forum | Home Theater Discussions And Reviews
Old 04-20-2013, 06:35 PM - Thread Starter
carlos san migu's Avatar
I have a Macbook pro and a DVD player connected, via HDMI inputs, to my AVR-2313CI. I want to connect a wireless microphone and listen to the mic input while watching the macbook pro screen. Is it possible?
Carlos San Miguel
carlos san migu is offline
Old 04-21-2013, 05:13 AM
jdsmoothie's Avatar
Quoted: 12182 Post(s)
Liked: 5549
Sure. If the wireless mic has an output comparable to the 2313CI inputs.
jdsmoothie is offline
Old 04-22-2013, 01:44 PM - Thread Starter
Assuming I find a wireless mic that send the signal to a box that is connected to the AVR with an HDMI cable. The AVR can take the sound from one hdmi port and the video from another? Is that corretc?
Old 04-22-2013, 05:55 PM
jdsmoothie's Avatar
Liked: 5549
Uh no. The mic would have to be connected by a non-HDMI input and then you can change the INPUT MODE of the MacBook Pro to either "Digital" or "Analog" depending on the cable used.
Old 04-22-2013, 06:07 PM - Thread Starter
Ok, so the mic would have to be connected to the mac somehow.
Old 04-22-2013, 06:10 PM
jdsmoothie's Avatar
Liked: 5549
Not necessarily ... what I meant was that the INPUT MODE setting on the AVR for the video source (ie. MacBook Pro) would have to be changed.
Denon Avr 2313ci Receiver
