2 mismatched subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-22-2013, 08:58 AM - Thread Starter
JDErickson84088's Avatar
Quoted: 21 Post(s)
I have just received my new Klipsch RW12D sub and originally I was going to replace my current Pioneer SW-8MK2 sub.
Would it be advisable to use both subs at the same time considering they are mismatched? IF so what would be the best way. I have a Onkyo Tx-NR818 that uses Audyssey MultEQ XT32
SW-8MK2
specifications
› Frequency Range....................................................38 Hz-150 Hz
› Maximum Input Power.......................................................100 W
› Driver Size.................................................................................8”
› Dimensions (W x H x D) ...........12-3/16” x 14-3/16” x 12-3/16”
› Weight (each)..............................................................20 lbs 4 oz
› Power Consumption............................................................1.0 A
› Power Requirement................................................120 V / 60 Hz
› UPC........................................................................012562906133
Andrew Jones Designed 100-Watt* Powered Subwoofer
*50W FTC Power Output
RW12D
SPECIFICATIONS
AMPLIFIER: BASH digital hybrid
AMPLIFIER POWER: FTC Rated Power: 350 watts continuous @ <2% THD / Dynamic Power*: 825 watts
DRIVE COMPONENTS: 12" (30.5cm) Cerametallic cone, front-firing woofer
ENCLOSURE TYPE: Bass-reflex via front-firing CornerPort
EXPORT VOLTAGE: 220 VAC 50/60Hz
FEATURES: DCS control and feature set w/ 3 system presets
FINISHES: Black Ash woodgrain vinyl
FREQUENCY RESPONSE: 24-120Hz +/-3dB
HEIGHT: 19.2" (48.8cm)
INPUTS: L/R Line-level RCA jacks, L/R High-level speaker binding posts
MAXIMUM ACOUSTIC OUTPUT: 116dB @ 30Hz 1/8 space, 1m
OUTPUTS: None
VOLTAGE: 110/120 VAC 60Hz
WEIGHT: 49lbs (22.2kg)
WIDTH: 14.6" (37.1cm)
JDErickson84088 is offline
post #2 of 6 Old 04-22-2013, 09:07 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
Using 2 subs is almost always better than using 1. You can place them anywhere. Just not really close to each other.
KidHorn is offline
post #3 of 6 Old 04-22-2013, 09:32 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
The small sub may not keep up with the larger one. Set the large one further away and integrate it with the mains. Then level match the smaller one in a nearfield location to match the larger one with an spl meter. Eventually sell the small one and get another 12 in sub.
derrickdj1 is offline
post #4 of 6 Old 04-22-2013, 09:54 AM
myoda's Avatar
Liked: 57
I agree with Derrick about the smaller sub. You can experiment by connecting both to your Onkyo and level match them at 75db when running Audyssey.
myoda is offline
post #5 of 6 Old 04-22-2013, 10:00 AM - Thread Starter
Quoted: 21 Post(s)
Thank you for the info.
Sorry for newbie questions. What is a "nearfield location"?
So are you suggesting setting the RW12D furthest from the listening area and the smaller sub near the listening position?
Also, if this was your equipment would you use both or just use the 1 RW12D? Room is 20x15x9.
post #6 of 6 Old 04-22-2013, 06:21 PM
myoda's Avatar
Liked: 57
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 100
example of Nearfield located velodyne sub and left surround - a speaker close to your field of listening. I would retire the small sub and budget for another RW12D. You would have an easier time of pressurizing the room with 2 12 inch subs. Do you have a picture of your room?
myoda is offline
