How to set-up analogue inputs to use sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-25-2013, 10:12 AM - Thread Starter
bishop200's Avatar
Hi guys,
I am struggling to figure out how to configure my MRX-700 so that my analogue 1 CD input which is set to "stereo", will also use the subwoofer. Anthem said that if you create a music ARC configuration it will use the sub, but it doesn't seem to work. Has anyone else encountered this? Could someone with a similar configuration please screen shot their ARC settings? Thank you in advance.
bishop200 is offline
post #2 of 2 Old 04-25-2013, 05:52 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Does your CD player have hdmi or optical out? If it does, I recommend feeding a digital signal to the mrx as the mrx will have to digitize the incoming analog signal in order to apply ARC.
audit13 is offline
