Denon AVR-3321 ER Emitter help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-28-2013, 09:03 AM - Thread Starter
aaarneson's Avatar
We moved into a house with this setup...everything seems to work great....we just want to be able to adjust the volume and the receiver is in a closet in another room. There currently is an IR Emitter, but when I plug it in to the back of the receiver under Remote Control IR it doesn't work. However when I tried to plug it into the dock control it did light up and was ready to go...but obviously still didn't work. Do I need a new IR emitter?
Please help.
aaarneson is offline
post #2 of 9 Old 04-28-2013, 09:13 AM
jdsmoothie's Avatar
Quoted: 12107 Post(s)
Liked: 5510
Was this included with the current setup or you just added it? If it worked for the previous owner then it should work, otherwise you may need to try another brand of emitter.
jdsmoothie is offline
post #3 of 9 Old 04-28-2013, 09:18 AM - Thread Starter
aaarneson's Avatar
The emitter was included in this setup...but it was not plugged in....So I am not sure how he had the emitter setup...maybe he had a repeater?
I am just confused that it powers on when plugged into the dock control and not the remote control ir.
post #4 of 9 Old 04-28-2013, 09:23 AM
jdsmoothie's Avatar
Liked: 5510
Ensure it's plugged into the IN jack.
post #5 of 9 Old 04-28-2013, 09:29 AM - Thread Starter
aaarneson's Avatar
I did...it is strange. It only lights up when plugged into the dock.
post #6 of 9 Old 04-28-2013, 09:46 AM - Thread Starter
aaarneson's Avatar
Do I need a specific ir emitter?
post #7 of 9 Old 04-28-2013, 09:51 AM
jdsmoothie's Avatar
Liked: 5510
Some work .. some don't. Try searching on the word "repeater" or "emitter" in the Denon AVR-XX12 Owner's thread for more info.
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100
post #8 of 9 Old 05-02-2013, 09:59 AM - Thread Starter
aaarneson's Avatar
Well I tried this one and it didn't work. Not sure what to get or really know what will work....seems like they should all work.
http://www.discounthdtvcables.com/hiirreexsyco.html
post #9 of 9 Old 05-02-2013, 11:50 AM - Thread Starter
aaarneson's Avatar
Could it be that the frequency of my remote is the issue?
