Receiver Decision Under $700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-28-2013, 11:47 AM - Thread Starter
mr1derful's Avatar
Need advice on with receiver. I have narrowed down my options to the following:
Onkyo TX-NR717 $599
Pioneer VSX-70 $649
DENON AVR-3312CI $599
Harman Kardon AVR 3650 $649
I will be paring the receiver up with either PSB Image speakers or HTD Level 3 speakers.
Two questions... Are either of those receivers the best bang for my buck? and Is there better option under $700?
mr1derful is offline
post #2 of 13 Old 04-28-2013, 11:59 AM
afrogt's Avatar
Quoted: 1433 Post(s)
Liked: 982
Best bang for your buck would be the Pioneer SC-1522 at Costco for $599. This is a $1200-$1600 9.2 receiver with a better amp section than the VSX-70.
http://www.avsforum.com/t/1465612/official-pioneer-sc-1522-9-2-network-ready-av-receiver-owners-thread
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/SC-1522-K
Afro GT
afrogt is online now
post #3 of 13 Old 04-28-2013, 12:04 PM - Thread Starter
mr1derful's Avatar
I've already called about the Pioneer SC-1522, and the closest Costco that has it is 250 miles away from me. The only thing about the Pioneer SC-1522, I lose the 4K ability. I am trying to buy for the present and the future...
post #4 of 13 Old 04-28-2013, 12:20 PM
afrogt's Avatar
Liked: 982
Well if the 4K scaling is that important you better drop the HK 3650 from your list.
Considering you'd have to buy a new 4K TV, 4K Blu Ray player, upgrade your cable/sat box to 4K if one supports it, etc. I'm not sure how valuable 4K is at this point.
Afro GT
post #5 of 13 Old 04-28-2013, 01:41 PM - Thread Starter
mr1derful's Avatar
At some point I will probably upgrade to 4K. I understand that I will have to get a new TV and Blu Ray. But that would still beat having to get a TV, Blu Ray, and a new receiver. Any opinions on what is the best option from the choices above (minus the HK3650), or another recommendation.
post #6 of 13 Old 04-28-2013, 01:43 PM
RomanBlade86's Avatar
Have you looked at the Onkyo TX-NR818? Brand new receivers for $799 and $699 for an open box like-new on Amazon sold by OneCall.
HDTV: Panasonic TC-P50ST50
Speakers: Bowers & Wilkins 685
Receiver: Sony STR-DA80ES
Blu-ray Player: Playstation 3
Power Center: Monster HDP 1800
RomanBlade86 is offline
post #7 of 13 Old 04-28-2013, 02:18 PM
afrogt's Avatar
Liked: 982
I'd probably get the Denon 3312 since it has better room correction (Audyssey MultEQ XT) than the other two plus it has a full set of preouts so that you can connect an external amp if you ever need more power.
Or the Onkyo NR818 open box from OneCall since it has Audyssey XT32.
Afro GT
post #8 of 13 Old 04-28-2013, 02:22 PM
afrogt's Avatar
Liked: 982
Or this Onkyo NR809 which has Audyssey MultEQ XT and 4K upscaling for $519
http://www.amazon.com/Onkyo-TX-NR809-Certified-7-2-Channel-Receiver/dp/B00505F01E
Afro GT
post #9 of 13 Old 04-28-2013, 02:51 PM - Thread Starter
mr1derful's Avatar
How important is it to have THX certification?
post #10 of 13 Old 04-28-2013, 04:57 PM
ray587's Avatar
You don't see THX certified recievers much anymore, that was a marketing gimmick anyway. Most any current reciever would pass THX requirements though.
ray587 is offline
post #11 of 13 Old 04-28-2013, 05:42 PM - Thread Starter
mr1derful's Avatar
Okay thanks. Looks like I have narrowed down to either the Denon AVR-2113CI, Denon AVR -2313CI, and there is still something out the Pioneer VSX 70 that stays in the picture.
post #12 of 13 Old 04-28-2013, 06:35 PM
afrogt's Avatar
Liked: 982
you went from the 3312 to the 2113 or 2313, why is that?
Afro GT
post #13 of 13 Old 04-28-2013, 06:40 PM - Thread Starter
mr1derful's Avatar
Mainly price. The 3312 was display unit, and I didn't really feel comfortable ordering a display unit without seeing first. Also I found the 2313 on sale for $599, so I pulled the trigger and placed the order.
