A/B Comparing Receivers DOs and DON'Ts? Just spent $2,600 to compare Marantz SR7005 vs Yamaha RX-A2020 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-30-2013, 02:51 PM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
So .... just purchased these 2 receivers to play around with,.
Marantz SR7005
vs
Yamaha RX-A2020
Since I don't feel like spending hours learning a unit I won't keep .... what are some basics and just how you would go about comparing these two? What setting and what procedure would you employ if you were comparing Receivers in your home?
any input is appreciated.
thanks
Sharp LC-80LE650U 80-inch, Denon AVR 4311ci, Ascend Sierra-1 NrT, Ascend HTM-200 (surrounds), Rythmik F12, WD TV Live Media Player, Samsung BD ES6000, Denon DVD-2910 & Sony BDP-S370 SACD/DVDa, Monster HTS 5100 MKI, Monster Z2 Biwire, Logitech Harmony One, Sennheiser HD600, Schiit Modi/Vali
Pianist718 is online now
post #2 of 6 Old 05-01-2013, 01:00 AM
jonfitch's Avatar
I would test how they sound playing the movies you like.
And also test them with the music you like, after running room correction.
jonfitch is offline
post #3 of 6 Old 05-01-2013, 10:34 AM
mjpearce023's Avatar
Quoted: 36 Post(s)
Liked: 38
The most important part of testing 2 receivers is getting them to the exact same volume. If they aren’t level matched then you test will be pointless because the louder one will sound better. You will need a spl meter to level match. Run Audyssey and YPAO first and then level match. Also, if you can get someone else to switch them for you that would help. The test will be more accurate if you don’t know which one is playing.
mjpearce023 is offline
post #4 of 6 Old 05-01-2013, 10:38 AM
dean-l's Avatar
Why not try two units that are significantly DIFFERENT. Try a "non" Japanese brand.
Why not a Cambridge Audio or Anthem, Rotel, Arcam, etc.
It's like comparing a bunch of American car brands, but refusing to try any Japanese, Korean or German. Just ignoring whole gigantic sections of the market place. With cars, few people ever go back.
Moderator harassment is wrong and immoral.
dean-l is offline
post #5 of 6 Old 05-01-2013, 06:04 PM
BobL's Avatar
Liked: 58
The biggest difference is likely to be the room EQ and that can vary from room to room.  So the winner in your room might not be in another room.  How you set up the EQs can change the sound significantly.
BobL is offline
post #6 of 6 Old 05-02-2013, 07:43 AM - Thread Starter
Pianist718's Avatar
Quoted: 142 Post(s)
So ........... sound update ....
Yesterday, changed music to play through all speakers with subwoofer instead of just 2ch stereo without sub.
Also ... changed Crossover from 60 to 90.
On receiver did a -1 on Treble
Result .... sound is great. I am getting delivery of Marantz 7005 and Yamaha rx-a2020 today. Don't even know if I should unpack them. Do you ever upgrade even when you are satisfied with the sound? :-)
Still can't get the upgrade bug out of me.
Compared WAV vs FLAC vs 320Kbps MP3 vs 128Kbps MP3.
128 is out ..... 320 is perfect middle (easy to get, sounds close to FLAC)
Marantz Sr7005 Audio Video Receiver Black , Yamaha Rx A2020 9 2 Channel Network Aventage Av Receiver
