Onkyo TX-NR727, 626, 525 "official" owner's thread discussion - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #451 of 540 Old 04-10-2015, 06:49 AM
Liked: 0
TX-NR626 Video Drop Out - fix?
Is there a solution to the video drop out problem?
Originally Posted by Corbism View Post
I just purchased a brand new TX-NR626 (replaced a 4 year old faulty SR707) and am experiencing an issue.
I have a digital cable box hooked up via HDMI and output from receiver to a Panasonic G15 plasma display via HDMI.
I am experiencing HDMI video drop outs where the TV screen blanks/blacks out for 1-2 seconds and then recovers while the audio comes thru normally without interruption. This happens very randomly maybe once an hour or sometimes will not occur for a couple of hours or more.
I have updated to the latest firmware, replaced all HDMI cables, and changed settings (picture mode set to bypass and resolution set to through) without any change. Also, to test to make sure the cable box or Display haven't become faulty, I hooked the cable box directly to display and issue does not occur.
Anyone else experiencing this issue with this receiver? Any ideas on fixing this?
Dan Huber is offline
post #452 of 540 Old 04-19-2015, 10:04 PM
Liked: 0
Same issue with my Onkyo TXNR626. I am also looking for some help here.
padamata is offline
post #453 of 540 Old 04-20-2015, 08:31 PM
Liked: 0
please follow the link (forum.onkyousa.com/viewtopic.php?t=5360&p=19968)
padamata is offline
post #454 of 540 Old 04-24-2015, 01:52 PM
FBGJR's Avatar
I have the previous year 70" Vizio and can't get the ARC to work either so I can use the apps on the TV. Have you had any luck?
FBGJR is offline
post #455 of 540 Old 04-25-2015, 05:33 AM
Liked: 0
I turned on the pass through on the receiver and connected to the the TV ARC HDMI input. This fixed my issue. I have a Samsung curved 65".
post #456 of 540 Old 05-02-2015, 07:11 AM
jsmiddleton4's Avatar
Quoted: 614 Post(s)
Liked: 208
Son-in-law's 626 FW updated last night. He keeps it current so I was surprised to see it doing so. New FW out?
Onkyo says Dec 2014 last update and I know he updated it then.
http://www.intl.onkyo.com/support/fi.../tx-nr626.html
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
post #457 of 540 Old 05-02-2015, 08:21 AM
RobertWy's Avatar
Quoted: 12 Post(s)
Liked: 27
Evidently, there is a new update because I was able to initiate an update from the setup menu.
Don't know why the web site doesn't have it listed. Guess it will show up sometime.
Robert
RobertWy is online now
post #458 of 540 Old 05-02-2015, 12:35 PM
Quoted: 614 Post(s)
Liked: 208
Thanks for confirming the FW update. I looked on the International site, the US site and the Onkyo user forum and found nothing.
post #459 of 540 Old 05-15-2015, 03:16 PM
Liked: 0
Loving my 626, use it to stream Pandora all the time. But suddenly when I select the NET input, I get nothing-just a blank screen and nothing on the receiver display. Anything short of a factory reset to try?
davidhbroome is offline
post #460 of 540 Old 05-25-2015, 05:18 AM
Mickrick's Avatar
Quoted: 16 Post(s)
Impossible to setup wifi - seems to asave setup randomly
I've had my 626 for about 18 months now and, while very happy with the sound, I have to say the hyped-up wifi connectivity is nothing short of junk. I'll explain why.
My 626 and my wifi router should be very happy bedfellows. For starters, the router is no more than 3ft away from the 626. Secondly, the 626 and the router share the same gamut of wifi connectivity - Open, WEP, WPA/2 TKIP/AES,, and WPS pushbutton and predefined code. So why is it that, 3 different 626's on, I can't get one to store wifi settings? Sure, I can get the 626 to recognise the wireless network and connect (as demonstrated by the whitelight wifi symbol on the front panel), though it steadfastly refuses to connect in either WPS mode. But after steadfastly inputting my wifi details I hit OK, at which point it shows me the status screen and the whitelight wifi symbol comes on, I then hit BACK, which takes me back to the Wireless Setup screen. Its at this point the problems start. I am only offered 3 options here - Search Wireless Network, Push Button Configuration (Select from Router) and Status, which is the one highlighted. But what I want to do here is SAVE the configuration. But to do that I have to press the RETURN button on the remote. At this point I am returned to the 7.4 Network selection screen, the whitelight Wifi symbol goes off and I lose connectivity. To enable wifi again, I have to go through the whole sorry process yet again, leading to ultimate failure.
But wait - sometimes the wifi settings WILL stay enabled through randome button pushing giving me wifi connectivity. Until the next time power is completely removed from the 626, at which point I will have to go through the whole sorry episode yet again. And although it eventually shows as being connected to the wifi network, most times no online services are available, not even local network attached storage. This sometimes resolves itself. Most others it doesn't.
This could've been so much easier to implement. But Onkyo has really dropped the ball on this one.
Mickrick is offline
post #461 of 540 Old 05-29-2015, 11:41 AM
Liked: 0
Upgrading from a Tx-ds898
Hey guys, ive had my 898 for about 5 years now, its probably one of the best sounding recievers ive ever heard. I know its pretty old and doesnt have any new codecs or HDMI outs but i was wondering. Is it worth upgrading for any reasons other than that to a 626 such as audio quality and such? Ive seen the 898 go for upwards of 200$ on Ebay and it seems like i can get a 626 with not much more added on.
Onkyo Tx-ds898 (miss my 989 v2), Monster Home Theater Streamline Tower 100's, Boston Acoustics Cs225c I
Jbl Northridge 26 II's, Jbl 12" Sub150, Onkyo Dv-Cp500, Samsung Pn42c450b1d Plasma..
Robert Bjorkman is offline
post #462 of 540 Old 05-31-2015, 10:11 PM
stangage70's Avatar
Originally Posted by Mickrick View Post
...the router is no more than 3ft away from the 626.
So if your router is so close, why not run a physical cable?
I can't comment on the WiFi, as I have always used the Ethernet jack instead, which has been trouble free.
stangage70 is offline
post #463 of 540 Old 06-01-2015, 07:01 AM
Mickrick's Avatar
Quoted: 16 Post(s)
I can't run a cable as the router only has 4 outputs, 2 pc's (1 HTPC), Xbox 360 and smart tv.
As I say, I'm on my 3rd 626 and wifi connection setup has always been hit and miss. I eventually got it to connect again soon after typing my reply up, so I've put a large sticker on the plug saying "Do Not Switch Off!" to, hopefully, save me from having to go through the pain again.
And Robert Bjorkman, I would test your current speakers with a 626 (or any other amp) before deciding to buy. My JPW's sounded awful with it, but I was given an old set of Mission speakers that I was able to save the drivers from and use in the JPW cabinets as they were the same size, and the difference in all frequencies is amazing.
Robert Bjorkman likes this.
Mickrick is offline
post #464 of 540 Old 06-01-2015, 07:31 AM
StephenRC's Avatar
Quoted: 24 Post(s)
That's what they make switches for , like http://www.amazon.com/dp/B001EVGIYG.
StephenRC is offline
post #465 of 540 Old 06-01-2015, 07:59 AM
RobertWy's Avatar
Quoted: 12 Post(s)
Liked: 27
I use three different switches to get my router connected to three desktop PC's and my den where I have a PS/3, a BD DVD, my TX-NR626, and my Samsung LED TV, all with ethernet connections rather than using wifi.
Robert
post #466 of 540 Old 06-02-2015, 10:24 AM
HDNW's Avatar
Video Adjustments- TX-NR525
Quick question on TX-NR525:
Is there a way to do any Video adjustments? If so, where is it in the menu system?
Thank you.
HDNW is offline
post #467 of 540 Old 06-02-2015, 11:40 AM
jdsmoothie's Avatar
Quoted: 12694 Post(s)
Liked: 5818
No, rather the 626 is the lowest model with Picture Adjust settings.
jdsmoothie is offline
post #468 of 540 Old 06-02-2015, 12:57 PM
HDNW's Avatar
Thank you for the clarification, jdsmoothie!!
HDNW is offline
post #469 of 540 Old 06-06-2015, 11:13 AM
Liked: 0
I just set up the 626 and I cannot get it to work with my xbox 360. I have the xbox setup on Game using the HDMI port for Game. The picture that I see is 3 distorted instances of the xbox menu. Does anyone have any suggestions? _Thanks
S Coleman is offline
post #470 of 540 Old 06-06-2015, 11:30 AM
RobertWy's Avatar
Quoted: 12 Post(s)
Liked: 27
Swap HDMI cable with another port's cable? I don't have Xbox; PS/3 here.
Robert
post #471 of 540 Old 06-06-2015, 01:49 PM
ajstan99's Avatar
If your Xbox 360 works correctly when connected directly to the TV, then it may be a handshake issue when running through the receiver.
If so, try this: Go into the Source Setup, Picture Adjust menu and make sure that Picture Mode is set to "Bypass".
ajstan99 is offline
post #472 of 540 Old 06-14-2015, 08:27 AM
krekc's Avatar
Hi guys. I have the Onkyo TX-NR727 and we have Direct Tv. Sometimes commercials come in way too loud. I know there is a law against this, but that doesn't stop these advertisers. I thought this receiver came with audio control where it would lower the volume if this happens. Am I wrong? How do I stop loud commercials? Thanks.
krekc is offline
post #473 of 540 Old 06-14-2015, 09:44 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi krekc, under Source Setup menu there's Dynamic Volume (Light, Medium and Heavy) setting. This setting is only available after running Audyssey full calibration with Dynamic Eq enabled.
krekc likes this.
JChin is offline
post #474 of 540 Old 06-19-2015, 09:55 AM
DE Theater Room's Avatar
Quoted: 92 Post(s)
Liked: 46
Unplug and plug back in.
DE Theater Room is offline
post #475 of 540 Old 07-01-2015, 07:29 PM
ergalthema's Avatar
Quoted: 109 Post(s)
Liked: 29
I've used DLNA to stream music from my MacBook to my TX-NR626 before, but I moved and it's not working now.
The receiver says it's connected in Network settings. I've been trying PS3 Media Server and Universal Media Server on my MacBook OSX10.10.3. UMS shows the TX-NR626 under "Detected media renderers". The TX-NR626 NET > DLNA says "No Server".
Any idea what's wrong?
ergalthema is offline
post #476 of 540 Old 07-17-2015, 06:39 PM
psilan's Avatar
Anybody know if the NR626 can do 4k @ 60hz?
I have pushed through 4k @ 30hz fine. So I'm thinking no...
SAMSUNG 4K 65" UA65JU6400SXNZ | KEF Q500 | KEF Q200c | KEF Q100 | SVS PB-2000 | ONKYO SKH-410 ATMOS | ONKYO TX-NR747
psilan is offline
post #477 of 540 Old 07-17-2015, 08:47 PM
Steve119's Avatar
Quoted: 18 Post(s)
Nope, apparently able to do this on the 636 as it is listed in the features, 626 only does 30fps apparently.
Steve119 is offline
post #478 of 540 Old 07-22-2015, 07:00 AM
Quoted: 37 Post(s)
Liked: 8
Hey guys, need some help.
I have the NR626, and all of a sudden, the video is starting to cut out every 30 seconds or so. I'm pretty positive it's an issue with the receiver, because I run my cable box through my Xbox One. So if it was the cable box's fault, the Xbox One screen would appear saying "No connection detected". If it was the TV's fault, the blue screen from the receiver would display.
But when it cuts out, it's the TV's screen that pops up showing "no input detected".
Also, I use both HDMI Outputs on the receiver, one for general watching and one for gaming. The gaming output does NOT have this problem. Just the first HDMI Out slot.
Any help would be appreciated. Thanks!
JoE5005 is offline
post #479 of 540 Old 07-26-2015, 06:38 AM
steveknj's Avatar
Quoted: 18 Post(s)
Hey everyone. I'm thinking of pulling the trigger on the NR626 for a really good price to replace my Pio VSX-1023 which I'm just not all that satisfied with. Mostly I'd like to have the bluetooth capabilities it offers so I can stream from the various smartphones and tablets in my house. My one concern is the notorious HDMI issues that these Onkyos seem to have (I have an older Onkyo setup on another TV that mostly works well, but there's one or two HDMIs that are a bit flaky). Have these issues been fixed by Onkyo through firmware and if I buy a refurb from Onkyo am I more or less likely to have them? I realize the model is 2 years old, but it has all the features I'm looking for, sans Apple Airplay which I could probably live without.
Steve
steveknj is offline
post #480 of 540 Old 07-26-2015, 07:32 AM
sytyguy's Avatar
I can't speak for the NR626, but I have the NR727 and NR906, and no problems with the HDMI's.
sytyguy is offline
Onkyo Tx Nr727 7 2 Channel Network Audio Video Receiver , Onkyo Tx Nr626 7 2 Channel Network Audio Video Receiver , Onkyo Tx Nr525 5 2 Channel Network Audio Video Receiver
