Reciever or USB DAC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-03-2013, 06:32 PM - Thread Starter
NathanRix's Avatar
Need some help for a computer system, was think of using a marantz 1403 reciever with motion 15 bookshelfs, will this be good or should I get USB DAC to bypass sound card?
NathanRix is offline
post #2 of 3 Old 05-04-2013, 02:54 AM
jonfitch's Avatar
Depends what resolution you plan to use the computer at. 1080p, a receiver is fine, but IIRC most receivers don't support output to 2560x1440 or 2560x1600 resolution, and 4K support is only at 30Hz, which is basically unusable for gaming.
With a USB DAC you'd be free to use displayport for video, which is much better than HDMI.
jonfitch is offline
post #3 of 3 Old 05-04-2013, 05:02 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Have you hooked it up and actually tried it with the audio from the PC?
If you need to bypass the audio in the PC, you can obtain a Behringer UCA 202 for about $30 that will solve any problems.
Tony_Montana likes this.
arnyk is offline
