Sub not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-03-2013, 10:19 PM - Thread Starter
svoltmer's Avatar
Just got the Yamaha v373 to replace a old box Pioneer 5.1 set up and I can't seem to get the subwoofer to work with only using 2 front speakers. Is there some trick to this?
svoltmer is offline
post #2 of 5 Old 05-03-2013, 11:01 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
Did you run ypao? If it set your front speakers to large you won't get anything from the sub on 2 channel music.
crn3371 is online now
post #3 of 5 Old 05-04-2013, 02:56 AM
jonfitch's Avatar
Set your speakers to small.
Set a crossover frequency (e.g., 80 - 120 Hz).
jonfitch is offline
post #4 of 5 Old 05-04-2013, 09:21 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Have you configured your system as 2.1? Beyond that, what is the source content you are playing? If the source material is 5.1, LFE (the .1 channel) should go to the sub no matter how you configure the L/R speakers. If the source material is stereo, there's no LFE channel and you have to engage bass management so that the receiver will redirect low frequencies from the main channels to the sub. That's done by configuring the speakers as Small.
BIslander is offline
post #5 of 5 Old 05-04-2013, 12:44 PM - Thread Starter
svoltmer's Avatar
Thanks guys. I didn't know that I had to manually tell the receiver which speakers I was using. It was not that way with my Onkyo. Works great now.
svoltmer is offline
