AVR receivers for living room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-04-2013, 01:58 AM - Thread Starter
kirojon's Avatar
Last two years ago I bought the Denon AVR1312+Lord 5.1 pure acoustic and I gave to my father as a gift, the avr is amazing, but there are lots of speakers that will surely enhance and give more powerful sound.
Now Im buying one and I prefer to buy a avr receiver instead buying the Onkyo 2.1 Envision Cinema LS3100 5.1 (virtual ambiance). Guys, I need your help, which Denon AVR receiver would you recommend for us, our living room size is 3x2 meters.
kirojon is offline
post #2 of 7 Old 05-04-2013, 02:35 AM
jdsmoothie's Avatar
Quoted: 12103 Post(s)
Liked: 5508
If you are looking for a low budget AVR, consider the new Denon E300 which is a networking model and includes Audyssey MultEQ to auto EQ your speakers/sub (a feature the 1312 is missing).
jdsmoothie is offline
post #3 of 7 Old 05-04-2013, 05:01 AM - Thread Starter
kirojon's Avatar
jdsmoothie - the new Denon e300 has same power as the 1312?
kirojon is offline
post #4 of 7 Old 05-04-2013, 05:04 AM
jdsmoothie's Avatar
Liked: 5508
Correct. Refer to the "2013 Denon AVR-E/X Models" thread linked in my sig for more info. Your LR is very small so any AVR from 50W and higher is more than sufficient.
post #5 of 7 Old 05-04-2013, 05:10 AM - Thread Starter
kirojon's Avatar
The salesman told me if your going to buy the 2012 model try ro buy the avr 2113 instead of the 1713.
In your point of view just for a small living room can you recommend me a good avr but a cheap price with a good sound?
my living room area is 3x2meters only. I appreciate your quick reply thanks.
kirojon is offline
post #6 of 7 Old 05-04-2013, 05:56 AM
jdsmoothie's Avatar
Liked: 5508
Either the 1613 or the 1713 would be more than sufficient if you don't need any of the extra features on the 2113CI.
post #7 of 7 Old 05-04-2013, 12:40 PM - Thread Starter
kirojon's Avatar
Thanks mate, appreciated, I while ago I went to the HIFI store and the salesman told me to wait after a month and the new sets of 2013 Denon will arrive, I'll check the E300, E400, E200
kirojon is offline
