Yamaha RX-V673 Subwoofer Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-04-2013, 09:46 AM - Thread Starter
Korki Buchek's Avatar
I have an issue with YPAO not setting my speakers for best sound ie subwoofer is degraded.
Speakers:
Pioneer "Andrew Jones" series:FS-52, BS-22, C-22.
Sub Polk PSW110
Unsure why this happens. Any thoughts?
KB
Korki Buchek is offline
post #2 of 12 Old 05-04-2013, 09:54 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
basshead81 is offline
post #3 of 12 Old 05-04-2013, 10:05 AM - Thread Starter
THX
post #4 of 12 Old 05-12-2013, 06:27 PM
Joshua Anthony's Avatar
I cannot get the subwoofer on. Can someone plz help? Thank you.
Joshua Anthony is offline
post #5 of 12 Old 05-12-2013, 07:15 PM
crn3371's Avatar
Quoted: 258 Post(s)
Liked: 206
A little more info would help.
crn3371 is offline
post #6 of 12 Old 05-12-2013, 07:24 PM
Bond 007's Avatar
Quoted: 2663 Post(s)
Liked: 2114
Licence to Kill
Bond 007 is offline
post #7 of 12 Old 05-13-2013, 05:21 PM
So I have a active subwoofer, and I plugged it into the receiver in the subwoofer position 1, and then 2 to double check. Yapo does not send a signal through it either. When I do manual set up I can turn subwoofer on, but when I play sound it does not come out of subwoofer. I am wondering if both subwoofer channels are dead? I set all speakers on small, turned up extra bass. Still nothing works... Any suggestions please?
post #8 of 12 Old 05-13-2013, 07:24 PM
Socketman's Avatar
Quoted: 163 Post(s)
Liked: 170
reset the receiver and run ypao. The procedure for reset is in the manual.
Socketman is offline
post #9 of 12 Old 05-15-2013, 11:19 AM
Still yapo does not recognize the subwoofer since no sound comes out during tests. I am thinking the sub channel is dead...
post #10 of 12 Old 05-15-2013, 11:23 AM
Bond 007's Avatar
Liked: 2114
Sounds like it. Are you within your return period? Have you called Yamaha?
Licence to Kill
Bond 007 is offline
post #11 of 12 Old 05-15-2013, 01:47 PM
garciab's Avatar
Quoted: 157 Post(s)
Liked: 72
Just be sure your sub is actually good, as well as the cable. Is the Yamaha a replacement?
bg
garciab is offline
post #12 of 12 Old 05-26-2013, 08:54 AM - Thread Starter
YPAO does NOT work well.
BassHead had the answer 3 weeks ago. Read above. He says:
"set all speakers small manually or turn on extra bass."
Worked for me.
Yamaha Rx V673 Receiver
