Onkyo receiver and Wii volume issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-04-2013, 05:01 PM - Thread Starter
FORIAMBILL's Avatar
I am having a problem using my Wii with my TX-NR3007 receiver. The Wii is the only device connected by component. Everything else is HDMI, and only an HDMI goes to the TV.
The volume is very loud, and does not adjust with the receiver control. Won't even mute. The receiver shows the volume moving, but the sound is blasting. I have hooked the wii directly to the tv and there is no problem. Ideas?
FORIAMBILL is offline
post #2 of 7 Old 05-04-2013, 06:21 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
So how did you connect the Wii's audio to the avr if not by HDMI? Optical? Assume you assigned the Wii input on the avr for component video but not sure about the audio. If all is correctly connected, could be defective or perhaps needs a firmware update or maybe just try a reset.
lovinthehd is offline
post #3 of 7 Old 05-04-2013, 06:43 PM - Thread Starter
FORIAMBILL's Avatar
the wii Component cable has audio as well. One connection to Wii, component and two audio cables. all go into input 1 on the AVR. yes, component input 1 is assigned to GAME.
also, did the latest firmware last night. no change,
post #4 of 7 Old 05-04-2013, 07:03 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi FORIAMBILL, is this static sound that's blasting or the actual audio from the Wii?
JChin is offline
post #5 of 7 Old 05-04-2013, 07:37 PM
lovinthehd's Avatar
Liked: 4775
I see, the video is component, the audio composite in that case. One input on the avr? with 5 cables? neat trick that smile.gif
You mention component input 1 is game, what did you do with the audio?
post #6 of 7 Old 05-04-2013, 09:56 PM - Thread Starter
FORIAMBILL's Avatar
I am a dumbass. I had the audio cables hooked up directly below the component, which are not the audio inputs, but front outputs. all hooked up properly now. damn dummy.
post #7 of 7 Old 05-05-2013, 06:27 PM
lovinthehd's Avatar
Liked: 4775
Glad you got it figured out. Checking connections is a good start to a problem but we don't always do that because we're sure we did that part right, eh? smile.gif
