Sony STR-DN1040 Official Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #541 of 1275 Old 11-21-2013, 04:34 PM
ailiev's Avatar
Hi,
I'm still new to the STR-DN1040. I have an EU model and have some issues with the HDMI.
I have a SAMSUNG D6530 TV, and whenever I enable HDMI CEC I cant seem to make everything work fine. For example, when on TV function, the TV's speakers are automatically off, and using the volume up/down bring the Anyone+ volume options, but no sound is heard from the reciever. Any ideas? CEC shows "AV AMP2" - is this correct?
Also, the pass-through is not working properly (i think). I have a set-top box which is connected using HDMI, when the reciever is on, the sound is heard from the speakers correctly, when i turn off the reciever, the audio goes automatically to the TV with the image, but after like 30 seconds a blank screen is shown and audio and video are off. i have pass-through enabled to AUTO (no ON option) and HDMI Control is on. Tried with both automatic standbay but no luck.
Also, does anyone knows if I can stream a custom online station to my reciever (for example one that i want to stream from my pc).
or any other way to stream my PC's audio to the reciever wirelessly (DNLA works fine but only for content that I want) What about if i want to stream youtube's audio?
ailiev is offline
post #542 of 1275 Old 11-23-2013, 10:25 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
So I need to replace my dead Denon, and am considering the STR-DN-1040. One thing that I noticed on review is that this unit, as well as many other newer units, offers menu setup through HDMI (only?).
I have an older Mits SD RPTV (no HMDI)
My question is this:
IF an HDMI connection is the ONLY way to get to the menu setup on the TV, can a HDMI to Component adaptor be used to plug into the TV?
CaptMike is offline
post #543 of 1275 Old 11-24-2013, 08:00 PM
Mattdoc's Avatar
Weird. I had a 5 speaker set up, but ever since the last update it seems I am not using my center channel for voices. Some tv shows sound normal, but then commercials sound distant. Other shows sound distant in their entirety. Tried resetting fields, re testing speakers, nothing helps.
My 5 speakers are 2 front, 2 surround, 1 center front.
PS3 seems fine, this is noticed when on fios.
Any thoughts?
Mattdoc is online now
post #544 of 1275 Old 11-25-2013, 12:34 AM
ngvuanh's Avatar
Press AMP Menu on remote and then use arrows to select options.
ngvuanh is offline
post #545 of 1275 Old 11-25-2013, 03:35 AM
ramses2112's Avatar
hey im kind of new to this home theater stuff but i was looking to create one for a reasonable price will this receiver work with this speaker system
http://www.monoprice.com/Product?c_id=109&cp_id=10906&cs_id=1090601&p_id=10565&seq=1&format=2
and if so what kind of cords would i need to buy if i wanted to buy some speaker stands for the 4 speakers (i dont want to wall mount) thanks for the help.
ramses2112 is offline
post #546 of 1275 Old 11-25-2013, 07:04 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
What are the options?
CaptMike is offline
post #547 of 1275 Old 11-27-2013, 08:43 PM
Mattdoc's Avatar
post #548 of 1275 Old 11-28-2013, 08:20 PM
mikepraba's Avatar
Hello Friends, I became the proud owner of this str-dn1040 2 days ago. I had the Sony Muteki system before and it worked awesome but won't let the 3d pass through. When I hooked up my new STR-DD1040 my subwoofer won't work. My older system had the speperate amplifier for subwoofer connected to my AV receiver via systom control jack. since the new unit doesnt have the system control my subwoofers aren't working. I tried to connect my subwoofers directly to STR-DN1040 Subwoofer out phono plugs and nothing happening. I am not sure If I have to buy an amplifier to get my subwoofer working??? If anyone using this can tell me how did you set up the subwoofer(direct or via another amp) I will be very thankfull.
mikepraba is offline
post #549 of 1275 Old 11-29-2013, 03:06 PM
Bob Fugger's Avatar
Just picked this unit up the other day from the local Future Shop for $439.99. I hooked it up last night and am confused as to how to correctly hook up a 5.1 system. I am using Energy Micros and I have a decent sized room. I initially hooked up the rear speakers into the rear surround ports; however, when I went run DCAC, it gave me a Code 33, stating that I didn't have surround speakers hooked up. I manually test toned and I got hits off of all of the speakers. But it refused to do the DCAC setup. I check Sony's eSupport site and in a roundabout way, it states that if you don't have 7 speakers, then your rear surround have to go into the surround ports - not the rear surround ports.
So here's the thing: am I getting true 5.1 sound? Am I getting rear surround sound even if I am in the (side?) surround ports? I've got everything hooked up via HDMI and whenever I switch sources, it never seems like I'm getting a 5.1 signal. Sure, when I play GTA 5 or watch Netflix with a 5.1 soundtrack, it sounds like I'm getting 5.1 sound. However, the display shows Dolby Digital 3.1/2. Is that right? Also, any advice re: crossover levels and equalizer levels would be most appreciated.
Bob Fugger is offline
post #550 of 1275 Old 11-29-2013, 04:15 PM
dailey1986's Avatar
where was it that you bought it for that low? BB has it for 529?
dailey1986 is offline
post #551 of 1275 Old 11-29-2013, 05:00 PM
DreamCatcher's Avatar
Just got my 1040 hooked up and dialed in.....
Setup was a breeze, GUI is a huge upgrade from the 1030?
Once powered back on unit called for a software update, so did that (took about a half an hour).
I've had NO issues besides the normal learning curve of a new/unfamiliar unit.
Wifi works perfectly, AirPlay and Bluetooth as well.
No HDMI issues..
So far very impressed with this unit....
StayThristyMyFriends
DreamCatcher is offline
post #552 of 1275 Old 11-29-2013, 05:08 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
I gave up on the Sony and purchased the Yamaha 6750
For $390
CaptMike is offline
post #553 of 1275 Old 11-30-2013, 09:24 AM
Juggalo23451's Avatar
I have a stupid question,
I bought this receiver on black Friday. I set up everything and I consider myself a tech savy guy. I hooked up both of my polk audio psw505 subs to the LFE but I am getting no bass.
Also in the GUI when setting up the speaker option I see no option to select a 7.2 surround sound set up. I am just wondering if I am missing something here or did I make a simple mistake.
Thank you,
Jason
Juggalo23451 is offline
post #554 of 1275 Old 11-30-2013, 05:08 PM
Thank you,
Jason
Well I'd probably start by checking for a firmware update....
I think you can only use 7.1... The .2 is really .1 as the two sub outputs are exactly the same.
DreamCatcher
post #555 of 1275 Old 11-30-2013, 05:16 PM
Here's another stupid question..... how do I get the Media Remote app to work with the 1040?
I had it working on the 1030 and a sony bluray player but can't figure out the 1040 interface....
edit: well apparently Media Remote app doesn't work with the 1040...
from what I gather there are two other apps that sort of work with the 1040....
oh boy.... that's a little strange
post #556 of 1275 Old 11-30-2013, 07:49 PM
SheepNutz's Avatar
I believe that you're supposed to connect your rears to the ones marked "Surround" if you're using 5.1. You should be fine though if you're getting sound out of all of them and the receiver is showing 3.1/2 That's how Sony receivers display 5.1
Bob Fugger likes this.
SheepNutz is offline
post #557 of 1275 Old 11-30-2013, 08:04 PM
Bob Fugger's Avatar
Awesome, thanks! I know that this is a stupid question, but how should I set crossovers and EQs?
post #558 of 1275 Old 11-30-2013, 09:56 PM
SheepNutz's Avatar
I haven't even got that far with mine. I've only done the basic calibration and haven't messed with anything else yet.
post #559 of 1275 Old 11-30-2013, 09:58 PM
I did the firmware update and messing around the speaker settings in the gui. Needless to say I got it working. Wife was surprised when the subs started working lol
post #560 of 1275 Old 12-01-2013, 08:25 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
A 5.1 system has surround speakers, which belong on the sides, even with or slightly behind the listener. A 7.1 system adds the rear speakers. You can put the surrounds in back if you want in a 5.1 system, but you still connect them to the surround terminals on the AVR.
3/2.1 is correct. 3 = three speakers in front. 2 = two surrounds. .1 = one sub.
BIslander is offline
post #561 of 1275 Old 12-02-2013, 07:12 AM
Oldtowneben's Avatar
no display on tv.  I have poked every button and every combination of buttons.  older tv with rca type input jacks does not display menus so I cannot adjust anything.  will a an hdmi converter work?
Oldtowneben is offline
post #562 of 1275 Old 12-02-2013, 07:38 AM
mirrorman's Avatar
I'd invest in a new tv.
mirrorman is offline
post #563 of 1275 Old 12-02-2013, 01:15 PM
Bob Fugger's Avatar
You can probably get an HDMI-to-RF and just hook it thru your cable input, BWAHAHA!!
Seriously man, why would you spend approx $500 on an 4k upscaling receiver only to hook it up to a ****** old TV?
post #564 of 1275 Old 12-02-2013, 02:18 PM
why would I buy a new $800 to $2500 tv when I have a perfectly good functioning Sony 52 inch fat body?
the old Onkyo receiver had a reparable issue, but I deemed it more prudent to replace it than fix it.
thanks for the helpful comment.
post #565 of 1275 Old 12-02-2013, 03:36 PM
mirrorman's Avatar
Because it's obsolete and worth less than infected yeast.
post #566 of 1275 Old 12-02-2013, 04:04 PM
its technology may be obsolete, but its functional use is current.  its worth is subjective- maybe worthless to you, but valuable to me.
like your car- I would not give you what you think it is worth, and you cannot replace it for what you think it is worth,  but its technology was obsolete the minute the new model came out.
so the question is:  can I make the new sony 1040 communicate with it and salvage the lifespan of a perfectly functioning machine,?
post #567 of 1275 Old 12-02-2013, 05:28 PM
Bob Fugger's Avatar
Regardless of my sardonic disbelief, I did provide you with a viable solution. You're welcome.
post #568 of 1275 Old 12-02-2013, 05:45 PM
Naka's Avatar
I have this receiver connected to my Sony XBR-55HX929 and I'm trying to understand how Bravia Sync/CEC should be working with these devices. I have my TV connected the HDMI Output A(ARC) on the receiver which goes into the Input 1 (ARC) on the TV. Audio and video are both functioning fine but I don't know that Bravia Sync is. Control for HDMI is set to on in the TV and the receiver. If the receiver is off and I turn the TV on, it will most of the time turn on the receiver too, but this doesn't seem to be 100%. When I turn off the TV, the receiver hasn't ever turned off. I also don't see the receiver listed as a Bravia Sync define when I hit the Bravia Sync button the TV remote. Shouldn't it be listed here?
Lastly, even though I have the receiver set to HDMI audio output to AMP, occasionally the TV speakers will output sound. When this happens, I check the HDMI audio output it says AMP+TV. I manually switch it, but sometimes it gets switched back. If the receiver is on, I don't want the TV to ever output sound through it's speakers. I haven't been able to pin point what operation I've done that causes this to happen, but the most obvious one is if any remote is set to TV and the volume button is hit. Prior to getting this receiver and turning Control for HDMI to on, I just set the TV speakers to off and use audio system. It seems that having CEC turned on overrides this, but when a volume button is pressed in TV mode, it messes things up.
Ultimately I'm trying to understand how Bravia Sync should be working and also why the TV speakers sometimes come on when the receiver is clearly outputting sound. Thanks in advance.
Naka is offline
post #569 of 1275 Old 12-03-2013, 02:12 AM
mirrorman's Avatar
I have a Samsung tv with an option in the sound menu to set it to external speaker or tv speaker.If you have the same option on your Sony make sure it's set to external speaker.
post #570 of 1275 Old 12-03-2013, 03:21 AM
Naka's Avatar
It is set already yes. I've noticed that on occasion though the TV says the audio system is unavailable and switches back to it's own speakers even though sound is already playing through the receiver and speakers.
I feel like the TV is having trouble communicating with the receiver. I was playing around with some of the Internet content on the TV to see if ARC worked and I can't get any sound to play when doing this. I don't see the ARC indicator light on the receiver either. I double checked the hdmi cable and even tried a different cable and the result was the same.
Naka is offline
Sony Str Dn1040 7 2 Channel 1050 Watt A V Receiver
