Just bought Sony STR-DN1030 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-09-2013, 09:51 AM - Thread Starter
Ken Malinak's Avatar
I havi impared sight and I am having difficulty with the setup, everyone knows that the GUI is bad, and somewhat unresponsive and the manual is even worse, that having been said, can I use 4oHm speakers in the rear. I think the receiver is rated at 8ohms, will 4ohms overdrive the amp?
Ken Malinak is offline
post #2 of 3 Old 05-09-2013, 11:14 AM
M Code's Avatar
Quoted: 731 Post(s)
Liked: 439
4 Ohms loudspeakers should work fine..
Key points are:
1. Brand/Model
2. Specs for sensitivity, should be @ least 88dB/1M, 1W
As long as one keeps the volume levels reasonable.
Just my $0.02... 👍😉
M Code is offline
post #3 of 3 Old 05-09-2013, 12:06 PM - Thread Starter
Thanks for your response.
