yamaha rx-v 375 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-09-2013, 06:10 PM - Thread Starter
NotInvolved's Avatar
i have a yamaha rxv 375 and the crossover is starting to bug me. my speakers are capable of handling the lows down to 25hz and my receivers crossover only goes down to 40hz. it is very noticeable and it bugs me a lot. is there a way to bypass it? are there any receivers that do not have a crossover like this?
-speakers: cerwin vega vs120s, cerwin vega LS12s, cerwin vega at12s, jbl S36II, pok audio psw10, realistic mc1000, paradigm 7se MKII, sanyo sx600
yamaha rxv375
NotInvolved is offline
post #2 of 15 Old 05-09-2013, 06:31 PM
garciab's Avatar
Quoted: 151 Post(s)
Liked: 69
Why not set your speakers to large? And set 'subwoofer plus' to no. That way sub only gets LFE content, and you won't miss much bass content in the other channels.
bg
garciab is offline
post #3 of 15 Old 05-09-2013, 07:06 PM - Thread Starter
i did set them to large. the sub plus is not on my setup menu. i guess ill deal with it
yamaha rxv375
post #4 of 15 Old 05-10-2013, 10:14 AM
garciab's Avatar
Quoted: 151 Post(s)
Liked: 69
Sorry, it's 'extra bass', but it should default to off. Page 58 of the manual.
What are you listening to when you have the problem? If you have large fronts, and extra bass is off, your sub should only be getting LFE content, and the xover setting does not apply. If the problem occurs during movies, simply turn the sub level down until it sounds the way you like it.
bg
garciab is offline
post #5 of 15 Old 05-10-2013, 10:19 AM - Thread Starter
i have extra bass on. thats the only way i can use my subs too on 2ch mode(90%of the time i use 2ch)
yamaha rxv375
post #6 of 15 Old 05-10-2013, 11:17 AM
garciab's Avatar
Quoted: 151 Post(s)
Liked: 69
If you insist on using the sub listening to music with mains that extend down to 25Hz, then your only option is to reduce the level of the sub to your liking. You can also try setting your big speakers to small, and playing with the crossover point and sub level to see if you can achieve a sound more to your liking. Good luck.
bg
garciab is offline
post #7 of 15 Old 05-10-2013, 12:00 PM
crn3371's Avatar
Quoted: 257 Post(s)
Liked: 206
Setting your speakers to small will engage the sub on 2 channel music as well. You don't have to engage extra bass.
crn3371 is offline
post #8 of 15 Old 03-31-2014, 05:19 AM
frankkeane's Avatar
Is there any way to disable the OSD when changing volume?
frankkeane is offline
post #9 of 15 Old 03-31-2014, 06:01 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
Disable short message.
fatbottom is offline
post #10 of 15 Old 03-31-2014, 06:03 AM
frankkeane's Avatar
How do I disable short message?
post #11 of 15 Old 03-31-2014, 06:09 AM
fatbottom's Avatar
Liked: 520
post #12 of 15 Old 03-31-2014, 06:22 AM
frankkeane's Avatar
I cannot find the option anywhere in the settings or manual
post #13 of 15 Old 04-01-2014, 01:54 AM
fatbottom's Avatar
Liked: 520
Setup, Function, Display Set, Short Message.
At least that's on the 671
post #14 of 15 Old 04-01-2014, 05:44 AM
frankkeane's Avatar
Not on 375. Only Input Rename, Dimmer, Memory Guard.
Thanks anyway :-)
post #15 of 15 Old 04-03-2014, 05:20 AM
frankkeane's Avatar
Thanks for your email and for your interest in Yamaha A/V & Hi-fi.
Unfortunatley our RX-V375 does not have the ability to have the OSD disabled, this feature starts a few models up from your receiver (RX-V675), sorry this was not the answer you were looking for.
Hope this helps and if you have any further questions or queries, pleased do not hesitate to ask.
Many thanks
Yamaha Technical A/V
A/V & Hi-fi Technical Support Team
Yamaha Music Europe GmbH (UK)
Sherbourne Drive
Tilbrook
Milton Keynes
MK7 8BL
