Yamaha reciever options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 05-11-2013, 12:12 AM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
Hello everyone!
I am looking for a new receiver, I was thinking about the Yamaha RX 1800, my only problem is that it is not 3d pass through, I do have a 3d tv and a ps3, I also have a Gbox midnight that can play 3d movies also. I can get this receiver for $350. I have looked at other new Yamahas at about 500, yes they have the 3d, but I really think that lots of other stuff is lacking, such as power and features, I have always had higher end Yamaha receivers, not the cheap ones. just not sure what I should do, I really don't want to spend more then 500, and I do not want a cheap receiver. or should I just get a blueray that has dual hdmi? Any ideas??
Jeff
jrt13 is offline
post #2 of 21 Old 05-11-2013, 12:21 AM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
NewEgg has the Yamaha RX-A820 for $499.
crn3371 is offline
post #3 of 21 Old 05-11-2013, 12:28 AM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
I just went there, don't see that price, its 899
jrt13 is offline
post #4 of 21 Old 05-11-2013, 12:47 AM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
how does the 1800 compare to the a820? the weight of the 1800 is much more then the 820, so I assume there is a much bigger amp in the 1800
jrt13 is offline
post #5 of 21 Old 05-11-2013, 09:08 AM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 768
Price changes regularly. Now it is $549.
Afro GT
afrogt is offline
post #6 of 21 Old 05-11-2013, 09:13 AM
afrogt's Avatar
Liked: 768
Depends what you're looking for.
820 has Dual HDMI outputs, 7 inputs, networking, internet streaming, Airplay, USB inputs, 3D pass though, 4K scaling,
If none of that matters to you maybe the 1800 has a little more power and a cleaner amp section.
vegasbaby likes this.
Afro GT
afrogt is offline
post #7 of 21 Old 05-11-2013, 09:52 AM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
I just don't know if I should buy a higher end one and work around the 3d issue, or buy a lower end one, I have never had a cheap Yamaha receiver, I know its like comparing apples to oranges, I do want those features that the 820 has, but I don't want to suffer with worse sound quality
jrt13 is offline
post #8 of 21 Old 05-11-2013, 09:57 AM
afrogt's Avatar
Liked: 768
The A820 really isn't a cheap receiver. the MSRP is $899 and your RX-V1800 was $999 from what I've checked. The 820 is just on sale but does come with a 3 year warranty.
You could always use the amp section on your 1800 if you really think it is more powerful and sounds better since the A820 has a full set of preouts.
Afro GT
afrogt is offline
post #9 of 21 Old 05-11-2013, 09:58 AM
Splicer010's Avatar
Liked: 39
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115393
Splicer010 is offline
post #10 of 21 Old 05-11-2013, 10:09 AM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
I don't have the 1800, right now I have the 2500 with no hdmi, I was reading that the 1800 was comparable to the 2700 (that is what I was going to get)
and yes, the price changed, I guess it changes a lot lol
jrt13 is offline
post #11 of 21 Old 05-11-2013, 12:05 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
What speakers do you have?
crn3371 is offline
post #12 of 21 Old 05-11-2013, 01:49 PM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
I have 2 klipsch kb 20 and 2 older polks for the rear and a monitor audio center. And klipsch sub
jrt13 is offline
post #13 of 21 Old 05-12-2013, 07:34 AM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
just not sure if I should go with something a bit older that is more high end or something newer lower end. Or even if I should look into denon also
jrt13 is offline
post #14 of 21 Old 05-12-2013, 10:20 AM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
I wouldn't consider the A820 a low end receiver. You'll have to be the judge. Is your older high end used or new?
crn3371 is offline
post #15 of 21 Old 05-12-2013, 10:55 AM
JBWIII's Avatar
Liked: 43
I agree. In fact the "A" means Aventage, which is their high-end line. And there is an A720 which means that the A820 is not even the most basic of the high-end line, if that makes sense.
JBWIII is offline
post #16 of 21 Old 05-12-2013, 11:06 AM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
I have the lowly A720 and it's an excellent avr.
crn3371 is offline
post #17 of 21 Old 05-12-2013, 11:20 AM
ceh383's Avatar
Quoted: 421 Post(s)
Liked: 2585
I was talking to a dealer the other day, and was told with the Aventage series, Yamaha was aiming for superior audio, and that the "A" stood for Audio.
I have the RX-A2020, and can tell you the audio quality is top notch...
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #18 of 21 Old 05-12-2013, 07:00 PM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
I am not saying that the 820, or 720 are bad receivers at all. My first Yamaha receiver was the 3090 (1996) it was the flagship at that time. I kept that until 2005, then I bought the Rx 2500 (midrange, but higher end in that group) Now im looking for something else, with hdmi and 1080p, I do have a 3d tv so I figure I need to get that also, and while im at it, I probably should consider the 4k also. I am really trying to decide if I should get the best one I can get without 3d/4k or just buy a lower model that has both.
jrt13 is offline
post #19 of 21 Old 05-12-2013, 07:25 PM
Quoted: 73 Post(s)
Liked: 112
The 820 is a solid choice in the $500 range. If non-Yamaha receivers are an option, I would check out the Denon 2113. Reliable, not like Yamaha, but still very good; Denon receivers have decent amp sections that perform well on the bench; and Audyssey MultEQ Xt which will also EQ the sub unlike YPAO.
rnatalli is offline
post #20 of 21 Old 05-12-2013, 08:56 PM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
I think I am going to go with the A1090 for $690, Its an open box with a 1 year warranty, think its a good deal?
thanks
Jeff
jrt13 is offline
post #21 of 21 Old 05-12-2013, 09:19 PM - Thread Starter
jrt13's Avatar
Quoted: 17 Post(s)
I mean the A1020, not the 1090 lol.
jrt13 is offline
