Receiver, iTunes, Android App - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-11-2013, 05:44 PM - Thread Starter
IqIndy's Avatar
I have no idea if any receiver supports this situation, but a friend asked me to recommend a new receiver.
He runs all his music from iTunes on a laptop. Currently uses a Apple Airport to stream.
He doesn't have a iPhone, so the Apple Remote app is out.
So.... I was wondering if there are any slick options to get a newer receiver with airplay capabiity, install the receiver's Android app on his phone, and be able to control iTunes from there. Long shot I am guessing!
Thanks for any input you may have.
Just for reference looking at below (excluding airplay as a req). Of course, I am sure lots of threads about the selection in general.
Denon AVR-1713
Onkyo TX-NR515
Yamaha RX-V673
Matt
IqIndy is offline
post #2 of 3 Old 05-11-2013, 07:58 PM
Section 107's Avatar
Quoted: 28 Post(s)
Liked: 107
I hate to be one of those guys that doesn't answer the question asked, but I believe there's an iTunes Remote app for Android:
https://play.google.com/store/apps/details?id=hyperfine.hftunes.release&hl=en
Section 107 is offline
post #3 of 3 Old 05-12-2013, 09:14 AM - Thread Starter
IqIndy's Avatar
Looks like retune is another, and free.
He needs a new receiver in any case as he is moving his current to outdoor pool duty.
I appreciate the input, and it is good advice. I will now no longer consider that part of the equation.
Matt
IqIndy is offline
